Old 10th January 2009, 09:45   #1
hotstuff's Avatar
Thanked: 120 Times
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????
Normally I listen to music in my car with the volume set at 'sane' levels. But once in a while I get this urge to crank up the volume towards the 'are you deaf?' mark for a song or two. I don't use a sub-woofer, but with a custom amp set-up and good speaker boxes, I get a good amount of bass; almost reaching SW levels.
The problem with all the bass in a Santro boot is that there was quite a lot of jarring, vibration and body panel resonance (JVR) that distorted the sound. All the 'drrrr..'s and 'brrrr..'s that accompanied the music ensured that I would quickly lower the volume. This went on for well over a year till one fine weekend in Dec 08 when I decided to do something about the JVR and went down to the car.
First thing was to take out everything from the boot, including the mats, toolkit, spare wheel etc. Next I loaded up a song which was guaranteed to produce the jarring and resonance. There is a tune called 'Thump of Daud' from the RGV movie 'Daud'. The song has no vocals, but has a variety of beats and low frequency sounds that produced some really great 'drrrr..'s and 'brrrr..'s :-)
I cranked up the volume till I started hearing the distortion, noted the volume level where the JVR was bad, put the song on 'repeat' and shut the door to start identifying the areas which were vibrating outside. First culprit was the number-plate, which was a quick fix. Just unscrew the number plate, apply double sided gum-tape liberally behind the plate, along the edges + some strips in the middle and stick it back to the car and tighten the screws well. Nothing else was vibrating outside.
Next I moved onto the rear-seat to check the boot area. [I don’t use a parcel tray in my car].
The first thing I saw was that the plastic lid covering the high-mounted stop light inside the car was vibrating at some frequencies. Pulled it out and realized that it is not a 'must have' after all.
Next I saw that that plastic moulding on the inside of the boot hatch was vibrating. First I tried tightening all the screws holding it, but they were already fully tightened. So I unscrewed the moulding and took it off. By now there was a significant reduction in the JVR. The only vibrations I could still hear were from the boot hatch. The panel area around the number-plate depression was resonating with each beat. So I figured out that damping was required in two areas, one was for the plastic inside-moulding and secondly for the rear-door / hatch.
I researched on the damping materials available in the market and read-up on the related threads on T-bhp too. Depending on the extent of damping done and the type of material used, I found estimates of anywhere between 5k to 25k etc. So I thought about DynaMat, FonoMat etc., planned on getting the damping done some day. I was also interested in a fellow BHPian @adityamunshi's approach of using neoprene + natural rubber sheets and that was my inspiration for a DIY. A DIY that I had planned for some lazy weekend.
One evening we were shopping at MK Ahmed's in Indiranagar and I found rolls of 'Yoga Mat' put up on sale. MRP was around Rs.500 and they were on sale for Rs.249. It is made of some kind of rubberish-synthetic material and each roll is around 5ft x 2ft. It felt quite dense and heavy too. [I think it is made of either soft PVC or Polyurethane]
On a whim I picked up a roll of the material. I also picked up a tin of Fevicol SR998 synthetic-rubber adhesive and a brush for applying the same from a hardware shop.
Total cost of material used: Rs.249 for Yoga-Mat + Rs.145 for the gum + Rs.15 for the brush. = Rs.409/-*
* Half a tin of the glue is still left over, so I should factor in some discount for that. :-)
Considered the pros & cons of this Yoga-Mat approach... if it worked, good! Else I would end up with this material stuck all over the insides of my boot door. Though it would be totally invisible from outside, it would be really tough to take out once stuck and render any further damping attempts difficult. But looking at it logically, it thought that it should work. It will absorb some amount of vibrations and in any case, it will add mass / weight to the body panel and the plastic moulding. It may not be as good as the bitumen based damping sheets, but should suffice for my purpose. Decided to take the plunge.
Used a news-paper to prepare some rough stencil-patterns of the plastic moulding insides and used the patterns to mark and cut the mat. Applied rubber gum liberally on both the mat + the moulding and stuck them when the gum was almost dry. [Read usage instructions on the gum box]. Apply pressure with a cloth and it sticks fast. Repeated the process again to add in a second layer of the material. The plastic moulding now felt heavier and produced a lot less noise when tapped on. Left it to dry and moved onto the car.
Before you start 'sticking around', take a good look and understand the wires, moving parts and any other electrical - mechanical components inside the hatch and ensure that you don't interfere with their movement or accessibility.
Since it is quite difficult to get a single stretch of sheet stuck along the insides, I decided to cut the mat into patches of around 5 inches x 10 inches and started covering the insides of the rear panel. Apply gum liberally on both surfaces and stick while the gum is still wet, this gives you opportunity to slide and correct the alignment of the strips. I continued the process till I completely used up the material. Wherever there is not enough space, cut the material into smaller strips. In the central areas around the number plate depression, I used two layers.
Let the gum to dry overnight with the windows slightly open (The solvents from the gum have to be let out of the car).
Next day I found the material was stuck fast, I fitted back the plastic moulding and tightened all the screws. With my fingers crossed I played the same 'Thump of Daud' song again at the same volume levels and viola! No JVR !!! I cranked up the volume a little further and I still did not notice anything. Stepped out of the car and there was no vibrations that I could hear from outside, only the song was audible.
Only when I cranked up the volume close to max, I could hear a little resonance from the outside, but it was from near the C-pillar / Roof areas. Besides, if I were to listen to music at these levels for more than a few minutes, I would be rendered deaf and the resonance / vibration problem would be solved permanently, wouldn't it? ;-)
My next thought was to repeat the Yoga-Mat treatment on the C-Pillars & Roof etc. But realized that it would be a pointless exercise since there was no JVR now at the volumes I wanted to crank up to and then some more. So why overdo it?
Some cons from this exercise:
[1] You will end up 'sniffing glue' for quite a while when doing the stick-up job and also for a couple of days thereafter till the glue in the car dries up completely. [Drove around with windows down for a couple of days]
[2] If you don't do a good job in the first shot, removing – re-sticking the material is quite a pain.
[3] If some day you decide that you need to go in for all the Wurth / Dynamat stuff... the Yoga Mat will probably be quite difficult to get rid of.
[4] This will work only up to reasonable levels of JVR, if you are using a SW and believe in SPL over SQL, then you are probably better off with the professional stuff.
[5] With the additional weight added inside, the hatch will feel heavier, will not get pushed up automatically from the same levels as earlier and the hinges may creak a little at times.
Disclaimer: If you do decide to try this out in the spirit of DIY, I may not be held responsible for any negative after-effects, including and not limited to your car ending up with colorful hard-to-remove rubbery stuff stuck on the insides and erratic behavior by yourself / your passengers after sniffing all the glue for the next couple of days. :-)
Pics follow :
See this plastic hood that covers the High-Mounted-Stop-Light at the top of the rear glass? This was vibrating badly with every beat and singing its own song…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-1.jpg
It does not have any screws; it is just fixed with two Snap-clamps (white). Pulled it out horizontally. [The snap clamps had turned brittle with age and I broke one while playing around]
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-2.jpg
The Rear-stop light does not look bad without the cover…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-3.jpg
The hatch plastic moulding is fixed with 5 screws and two plastic ‘press’ pins near the top. To remove, just depress the dot in the middle with a screwdriver, it will pop in by around 5mm then insert a screwdriver along the outer edge and pry the entire thing out. While putting it back, keep the middle plug out by around 5mm, press the pin into the hole completely using the outer edge and then press the middle dot till everything is at the same level.
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-4.jpg
Started with these…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-5.jpg
Use patterns made from news paper to ensure minimal wastage…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-6.jpg
The material can be cut easily with a scissors. You can also see the cross-section & thickness of the material…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-7.jpg
Clean both surfaces, apply gum on both surfaces, allow it to dry a little, stick and apply pressure with a cloth…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-8.jpg
One layer is done…
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-9.jpg
Repeat previous steps for second layer.
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-10.jpg
See how I have stuck patches of the material firmly all over the inside of the rear panel? I used a second layer in some places, overlaid equally over two underlying strips, ensuring that enough weight is added onto the panel. If you have any of the stuff leftover, use it to tightly stuff the gaps between the first and second layers of the body panel.
A DIY (Damp It Yourself) story: DynaMat, FonoMat...Yoga-Mat ????-11.jpg
Let me warn you, working on the rear hatch is a pain in the neck, as you will have to open it out fully and work from below.
Next project for some other weekend… try the Yoga-Mat approach on the insides of the front doors, to get a heavier ‘thunk’ when I shut the doors…
hotstuff is offline   (7) Thanks
Old 10th January 2009, 12:08   #2
DerAlte's Avatar
Thanked: 2,920 Times
Wow, that's a real profi DIY job. Keep up the good work, @hotstuff!
DerAlte is offline
Old 10th January 2009, 12:10   #3
badboyscad's Avatar
Thanked: 483 Times
That is a clean DIY. Good pictorial representation too.
badboyscad is offline
Old 10th January 2009, 12:43   #4
Bass&Trouble's Avatar
Thanked: 137 Times
Very nicely implemented and illustrated! Those yoga mats however dont have the best damping properties.
Bass&Trouble is offline
Old 10th January 2009, 12:54   #5
ASHISHPALLOD's Avatar
Thanked: 346 Times
nice work.
i am facing same problem in my alto.
6x9 speakers are fixed in boot door. when volumes are high, there is resonance from boot from lock area. lock assembly vibrates badly. it is not much felt while inside but outsider will be irritated. i hope, i will do something like this.
ASHISHPALLOD is offline
Old 10th January 2009, 13:03   #6
greenhorn's Avatar
Thanked: 4,910 Times
great job. you inspired me to work on my rear LED stoplamp and IRVM rattles, and with a bit of help from Double sided foam tape ( my favourite damping material ) sucessfully took care of them both
greenhorn is offline
Old 10th January 2009, 13:31   #7
hydrashok's Avatar
Thanked: 19 Times
Very cleanly done!!! You have some serious skills with scissors! Great DIY job, very nicely explained & illustrated.
hydrashok is offline
Old 10th January 2009, 13:35   #8
sai_ace's Avatar
Thanked: 779 Times
Originally Posted by ASHISHPALLOD View Post
nice work.
exactly the same problem. My problems are further compounded by the presence of the rear wiper assembly .
sai_ace is offline
Old 10th January 2009, 13:47   #9
Thanked: 42 Times
this is really kool, nice DIY. no one could even think of yoga mats being used for sound deadning. lol
monty9991 is offline
Old 10th January 2009, 14:26   #10
mnhegde's Avatar
@ hotstuff: thats a very clean DIY job with a good pictorial representation.. Keep up the good work friend.
mnhegde is offline
Old 10th January 2009, 14:29   #11
asethi's Avatar
Thanked: 353 Times
I would really like to try this out on my swift, on all 5 doors. It has got door speakers and there's high vibration even with these. There are already some foam pieces inserted by MASS, but they are not fully effective. And boot inside makes noice whenever the clamps get lose.
asethi is offline
Old 10th January 2009, 17:58   #12
hotstuff's Avatar
Thanked: 120 Times
Thanks for the positive feedback !
- Thank you guys !
- Agree with you B&T. While this 'Yoga Mat' stuff worked just fine for me, there are materials with better damping properties out there. Apart from the Wurth, Dynamat etc. specifically meant for automotive damping, I understand that there are other materials used for architectural uses, which can be adapted for cars too.
The reasons why I went with YogaMat are easy availability, very low cost and easy to work with. If I can lay my hands on the stuff used for sound-proofing / insulating buildings, I will certainly use it for any further damping. (Though I think it might be too thick and interfere with the mechanisms inside the doors.)
One more aspect I considered was heat deterioration over a period of time. What gave me the confidence to go ahead with this YogaMat is that I had a sheet of similar material as a boot-mat in my previous car and it did not deteriorate even after 2 years, with the car being parked in the sun everyday.
As I mentioned in the post, this stuff works for normal usage, but for cars with seriously high-powered systems, they are probably better off with the professional stuff.
To put things into perspective, I will put up the specifications of the system I use in my car.
nice work.
- Probably a round of tightening the innards, generous use of double sided gum-tape, along with the damping should work for your car. Just try the 'Thump of Daud' song, identify what are the things that are contributing to the noise and go after them one by one.
- My car has a rear-wiper assemply too, but it seems to be quite firmly fixed and causes no vibrations. You might just want to tighten all the fasteners / screws on the assembly. With no flat surfaces, the assembly per-se may not be resonating. But if it is loose, then it may be vibrating / rattling.
- Just tighten everything, including the speaker mountings, clamps etc. first and be careful while trying this out. First start with one door, see how it works and if you are happy, then continue with it. As I mentioned, once stuck, it is quite difficult to take out.
hotstuff is offline
Old 10th January 2009, 19:17   #13
phamilyman's Avatar
Thanked: 4,675 Times
Boss,
I would suggest changing your nick to Scissorhands. You are a cat. Alternative employment in case the recession hits!
That said, Congrats. Which car do you have? Alto/Swift?
phamilyman is offline
Old 10th January 2009, 19:19   #14
shreyasma's Avatar
Super super super!!
I love the finishing...its very neat.
shreyasma is offline
Old 10th January 2009, 20:25   #15
Thanked: 579 Times
This is a wonderful DIY, mate! You got skills!
I sure could have used it during the approx 1 year of rattling that I had to bear from my cars' door, that too driver side door.
And, OMG, a red mat! Hope JKDas does not see this else he might get more ideas to use his floor mat!
HappyWheels is offline
