Old 28th February 2006, 15:19   #1
shazikon's Avatar
Default fungus on my canon 28-80 mm lens
Guys,
the most unfortunate thing has happened after the long wet weather in Bangalore last year, i forgot to dry my lens and observed last weekend that one of my canon 28-80 mm lens is affected with a fungii.. Any tips on how to clean this lens. Any reliable camera shop i can approach in Bangalore to get it cleaned..
shazikon is offline   Reply With Quote
Old 28th February 2006, 15:22   #2
Thanked: 24 Times
Originally Posted by shazikon
Guys,
try to keep the lens under a table lamp (may be 100w bulb) for 30 minutes or so. heat radiated may help in removing the fungus.
tifosikrishna is online now   Reply With Quote
Old 28th February 2006, 15:27   #3
tsk1979's Avatar
Thanked: 4,606 Times
Look here
http://www.chem.helsinki.fi/~toomas/photo/fungus/
Tells of prevention solution etc.,
Old 28th February 2006, 15:36   #4
shazikon's Avatar
Originally Posted by tsk1979
Look here
I couldnt get much useful info but only hypothesis.. will try keeping it in th sun lets see..
thanks tifosikrishna, i will try your trick too keeping it under a 100w bulb..
looks like the growth is in advanced stages as i can feel the hard ness on the external lens surface..
Old 28th February 2006, 15:37   #5
shazikon's Avatar
does it help cleaning the lens surface with a mild alcohol solution?? or is the lens coating sensitive for this?
Old 28th February 2006, 15:41   #6
tsk1979's Avatar
Use a lens cleaning fluid. You get them in camera shops. But you have to open the lens for the cleaning and its not really recommended unless you are trained. I suggest you go and visit fotocircle in chamrajpet or RK photo video near national market. they stock lenses and repair photography equipment
Old 28th February 2006, 15:42   #7
Considering that it is in "advanced stages", it would be prudent to get it cleaned immediately. You may take your lens to Mr. K P thomas, an elderly gentleman who does a good job of removing fungus for a reasonable cost at Bangalore. 277, 2nd cross, cambridge layout, Bng - 8. #5115 9135 / 2555 3787.
S Pathak is offline   Reply With Quote
Old 28th February 2006, 15:44   #8
shazikon's Avatar
Thanks for the lead tsk1979..
will do it over the weekend.
Old 28th February 2006, 15:46   #9
shazikon's Avatar
That was very useful info Mr.Pathak, thank you..
Old 28th February 2006, 15:52   #10
You are welcome.
He is recommended by Mr. Naresh Raheja of RK Photoguide. Mr. Thomas did a good job for one of my lenses, while the Nikon authorised service centre tried to rob me.
Old 28th February 2006, 18:18   #11
Rudra Sen's Avatar
Thanked: 1,133 Times
i forgot to dry my lens and observed last weekend that one of my canon 28-80 mm lens is affected with a fungii...
Lens was wet? If not, what’s the idea of drying a lens?
Fungus in Bangalore is rare. At least that’s what I see. You’ll give your lens for cleaning but what’s the guarantee that it won’t come back again?
Fungus cleaning (if deep) from lens may remove (read damage) your lens coating.
You can probably consider a few steps to prevent further damage. These are of course, after you clean the lens:
1. Do not keep your camera/lens in their respective pouch. Use them only when you’re carrying them.
2. Camera lenses need light to pass through. That’s what they’re meant for. At times allow them to feel the sunlight. Even if you’re not shooting anything.
3. Always use some sort of glass filter (Skylight 1A/UV) to protect your front element. You may not like them using but they protect lens to a great extent.
4. Use manual focusing once in a while (in case of auto focus lens). It will prevent lens lubrication to stay healthy, not sticky or dry.
5. Use a good quality blower brush. Preferably a big one.
You may already know all these…but old man’s blabber is a common problem anywhere.
Old 28th February 2006, 19:21   #12
ritik123's Avatar
To prevent the issue from recurring again: Always keep a few pouches of "SILICA GEL" inside your cameras and lens bags.
ritik123 is offline   Reply With Quote
Old 28th February 2006, 21:31   #13
Keeping pouches of silica gels with the lenses in a "camera bag" does not help. That's because the camera bags are not airtight. For perfect prevention, in addition to what Rudra said, follow these :-
1. If you do not plan to use the lenses for a long time, store in dessicators, with silica gel packs. The silica gel absorb moisture from the air inside the dessicator and after sometime (couple of weeks depending on the moisture level), shall turn white/magenta. Check after a couple of weeks and warm up the silica gel in a frying pan (not being used for cooking purposes). The silica gel shall turn deep blue and can again be reused. This process should not be repeated for infinite number of times and it would be wise to replace the pack of silica gel with a new pack after few months.
2. Lenses that are frequently used never attract fungus. Ensure they get air and sunlight at regular intervals, open up and close the apertures, do some shooting.
3. Too much use of silica gel might affect lens lubrication. Be careful.
Hope this helps.
Old 1st March 2006, 10:57   #14
shazikon's Avatar
Well, i had been trekking in some very moist places last year, although the lens was not wet, i am sure the moisture might have crept in to the lens barrell..and i must say the silica gel in my pouch is old and not doing its job..
I use manual focusing most of the time....
i really appreciate and respect your advices after all wisdom comes from age and experience..
thanks,
-shashi
White fungus patches on Art Leather covers diyguy Modifications & Accessories 2 15th December 2011 13:43
Fungus in Carpet - Solutions ? bullboy Technical Stuff 27 4th October 2010 12:07
MM Major Dashboard on a MM 540 yamaniac 4x4 Technical 3 15th February 2010 15:01
Looking For a Camera Lens SCARLET Gadgets, Computers & Software 6 1st March 2006 13:55
