Thread Tools
Old 3rd May 2006, 21:29   #16 (permalink)
venkatrx's Avatar
Originally Posted by Lukeskywalker
my car has a tacho (optra 1.6), agreed there is a load on the engine once the a/c is switched on, proof is increased rpm when idling, but my doubt is if i consciously make sure that i drive at a constant rpm say 2.5k, with or without a/c, my fuel consumed should be the same as the engine is revving at the same speed in either case. Pls enlighten my dumb soul
If rpm=2500 and your accelerator pedal pressed = constant (say 25% pressed) then the 'fuel consumption' is constant regardless of AC being on/off.
but remember that part of fuel consumed will go towards driving AC if it was on hence your 'fuel efficiency' will go down.
__________________
Lexus IS 200, the best looking sedan of all times.
venkatrx is offline   Reply With Quote
Old 4th May 2006, 00:50   #17 (permalink)
speed0mania's Avatar
Post
hey guys interesting debate!! but what i feel is that the rpm is directly proportional to the rpm but it isnt the only thing right if that was the case then overloading your car with an extra 100kgs and driving at the same rpm wouldn't give you any FE loss !! but as we all know that is not the case!! hence the car maybe at the same rpm but the engine is doing extra work to keep it at that same rpm range!! its simple a motor with no load might givea certain speed output but to give the same output when it is ladden with some load will consume more power!!
also the rpm goes up during idle as it is set to the minimum on idle (just sufficient from keeping the engine from stalling) when an additional load of the ac power is added to the alternator it has to increase the rpm so asto generate sufficient power for the ac and to keep the engine running !! we do not notice this while driving but if we equate the speed at a particular gear at any rpm with the ac on and off , we will see that at the same rpm and gear the speed is lower (maybe marginally depending on the car) when the ac is on!!
and as per what i understood the question to be originally ,
yes it is possible to save on the FE loss due to the ac if you drive with a lighter foot obviously you cannot go anyfurther if you usually drive with a light foot in the range of around 2000 rpm as too low a rev would give you a further loss inFE ! but if you usually drive above the 3k rpm mark then you could cut down on the loss by driving in the 2-3k range depending on your engine!!
speed0mania is offline   Reply With Quote
Old 4th May 2006, 10:35   #18 (permalink)
Pardon me if this sounds naive but, my understanding is- At idling, when we switch on the AC, the increase in rpm to sustain the added load is done by the ECU (like the computation of how much RPM to increase depending on the speed of the blower presumably?). All that is ok in an mpfi (any car with an ecu). But what in my good old carb zen? Are we saying here that if i further reduce my idling rpm by some means, and then i switched on my AC, the engine would stall?
__________________
Quench my thirst with gasoline --- Fuel, by Metallica
zen-ith is offline   Reply With Quote
Old 4th May 2006, 10:55   #19 (permalink)
naveendhyani's Avatar
Originally Posted by supremeBaleno
"The fuel consumption in the final speed of blower will be marginally higher than when the speed is at the lowest. This is due to the fact that the compressor cut off at higher blower speed is minimum or almost nil and hence the AC compressor load on the engine is relatively constant. Whereas in lowest blower speed the cut-off pf compressor is frequent and hence the load on engine is lesser intermittently."
seems very logical. now on after first 10 minutes of running on full blower my blower wud come down 2 slower speed
naveendhyani is offline   Reply With Quote
Old 4th May 2006, 14:55   #20 (permalink)
Lukeskywalker's Avatar
Even then, engine rpm is related to work done by the engine, higher rpm more work done, so keeping rpm constant means keeping the work done by engine constant too, right?
So, (correct me if i'm wrong) at constant rpm, your performance might go down, in terms of acceleration and pick up, but as you are holding the throttle constant, you are effectively controlling the amount of fuel being injected, hence the theory that you might have the same amount of fuel consumed with the a/c in "on" or "off" position. my hypothesis really
Lukeskywalker is offline   Reply With Quote
Old 4th May 2006, 15:30   #21 (permalink)
speedsatya's Avatar
if i consciously make sure that i drive at a constant rpm say 2.5k, with or without a/c, my fuel consumed should be the same as the engine is revving at the same speed in either case. )
but the effort required to maintain a 2.5k rpm with AC will be more ...which means more fuel will be spent when AC is on ...and hence lower FE
speedsatya is offline   Reply With Quote
Old 4th May 2006, 15:48   #22 (permalink)
Ivor and luke,
You guys are right about that. Running the blower (fan) at the lower speeds would give you more FE than running it full blast. I had this doubt myself and wrote to MUL. I am quoting below what their engineer replied to me :
let us take the example of an auto climate control car. Assuming we set the temp at 21 degrees, wouldnt the compressor work till that temp is reached at first and then continue to maintain the same. If this is correct, isnt it true that the irrespective of the fan speed, the compressor will work on cooling the cabin to the required temp.? the higher the fan sped, the greater the reach and cooling capacity and when the fan speed is lower, the time required to cool the entire cabin is more which means the compressor has to run for a longer time.??
Ajay is offline   Reply With Quote
Old 4th May 2006, 16:29   #23 (permalink)
Smile
Hi Luke,
the compressor is connected to the driveshaft so as soon as it is switched on the ac draws power to run the compressor and hence the increase in rpm to maintain idling or even while driving no matter what FE wud be compromised by how much is hard to say.
secondly when the fan is at lower speed the air from the vent is cooler(have experianced it) and since the air is cooler the thermostat keeps switching on and off to maintain temp. whereas vice versa fan at top speed is pushing more air thru the fins and hence to maintain temp. the thermostat keeps the compressor on hence the resultant lower FE on full blower and higher FE on lower fan speeds.
amit mohan is offline   Reply With Quote
Old 4th May 2006, 17:52   #24 (permalink)
As far as my understanding goes ,the ECU dosent do anything . when the Ac is switched on ,the accelerator position is slightly increased ,so as to sustain the AC load .
For a Maruti 800 car the AC compressor load is approximately 7hp . so deducting 7 hp from 45 bhp does make a lot of difference in the acceleration and revving levels .
Running the fan motor (blower) also consumes energy as ,the blower runs from battery and the alternator charges the battery . when the alternator is charging the battery the alternator needs more energy ,than when the alternator is not charging the battery.
The engine revs faster when the AC is switched on as the compressor poses a load on the engine ,and for the engine to stop stalling under load ,the engine is set to run a bit faster ,especially when the AC is switched on and you are driving the car ,the car might stall when you try starting from a stand still .
just my 2 cents ..
Old 4th May 2006, 18:09   #25 (permalink)
Ivor and luke,
supremebaleno ..Are you sure you got a reply from a maruti engineer ?if so ,i wonder what kind of engineers produce maruti cars ...lolll .
The blower has different speeds as ,a car has varying passengers . there might be various no of configurations . for example there may be only front seat occupants or rear seat occupants . inorder to reach the rear seat occupants ,the blower has higher /faster speeds .
Infact ,faster blower speed would cut in the compressor earlier ,as the cooling by convection is much better and heat transfer is much faster ,as more volume of air passes than when the blower is at a slower speed . when the blower is at a slower speed ,it gives more room for condensation to take place,thats the reason for water droplets ....
Old 4th May 2006, 18:29   #26 (permalink)
Originally Posted by amit mohan
Hi Luke,
Doesnt the thermostat detect the temperature when the blower is at full speed coz if it pushes in more air, the faster the cabin is cooled off isnt it?
Old 4th May 2006, 19:12   #27 (permalink)
ivor's Avatar
Actually, this makes a lot of sense and this is something that is validated on my old Zen. On a manual AC, it doesn't matter how many are in the car, when the blower is on at full blast the compressor never cut off.
Sorry, greatmana2000 but the engineer makes far more sense than your explanation, which seems to be referring to auto climate control.
ivor is offline   Reply With Quote
Old 4th May 2006, 19:13   #28 (permalink)
ivor's Avatar
At least in my old Zen, it didn't matter what the cabin temperature was--if the blower was at full blast, the compressor never cut off
Old 5th May 2006, 11:38   #29 (permalink)
In my car which is not auto climate controlled as well, The compressor cut off is quite fast when the blower is at full speed.
Old 5th May 2006, 13:09   #30 (permalink)
ivor's Avatar
Do you have a Zen too? Perhaps what I described is restricted to Marutis--or perhaps your thermostat is set to cut-off at a particular temperature while my thermostat was set to never cut-off when blower was at full blast.
Thread Tools
Will A/C blower speeds affect the Fuel Economy? arunkumar_rec Technical Stuff 12 19th December 2007 13:07
Alto Fuel Economy Woes ScarySkulls Technical Stuff 148 11th November 2007 17:50
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 33 14th June 2007 01:52
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 22:31
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459
