Originally Posted by tsk1979 no such recommendation in the manual, but if you don't depress clutch while starting it should not lead to vibrations |
thats right
but u should also not step on gas at time of cranking it causes a flood situation and idle goes for a six causing a shudder due to transmission turning load and the shudder will get off the next time u blip the throttle "gently" a couple of times(more fuel less air)
