Old 27th March 2008, 11:47   #31
Thanked: 463 Times
Naah! I have known the tulsient name for many years now since they are into NAS/ storage solution.
DM is another branch of their business. Check here
But you can write to them and ask for payment on delivery method, it might be available.
Originally Posted by Steeroid View Post
And I suppose you have to pay in advance before they courier the 'Magic Pill' to you.
Dadu, no offense meant, but this does sound like a Nigerian 419 Scheme.
dadu is offline
Old 28th March 2008, 19:23   #32
Thanked: 463 Times
The blister pack was delivered to me within 2 days of order & payment, so the Nigerian angle is ruled out.
In the meantime I researched/digged deep into this pill to find out whats the background. So here's my findings.
This pill is sold across the world and moreso in the EU and AP region. I also found that they call it as a Fuel conditioner than an additive.
Manufactured and packaged in New Zealand by Bioactive Technologies ltd. for New Image International Ltd and Ubiee Corporation and sold through its distributors in each region.
You can find this pill by many names in the regions like dyno-tab , Firepower , MP6ty , powerpill etc etc. But they are all the same with similar marketing, graphs and statistics. For EU/AP distributor is RingSMS - UBiee powerpills.
Now I can understand why they sell in different packaging and brands in various regions, although selling under a single brand name would have given them more leverage but I guess thats what DM is all about. And yes, it doesnt have a brandname as STP and Elf.
Now more on the technical part, Power Pills contains:
  • Ferrocene to raise the power output from a given volume of fuel, provide additional lubricating properties and thus reduce the overall emissions.
  • A detergent to clean the fuel system, break down and remove carbon deposits and thus restore the overall efficiency of the engine and fuel system to that of a new vehicle.
  • A binding agent to enable the production of Power Pill in a safe, stable and easily handled product.
Read the technical specifications here.
Chemically talking in its native state, Ferrocene has many applications(the ones from our point of view):
  • Used as fuel catalyst for rocket (aeroplane) propellant, it can improve combustion speed by 1-4 times, lower the temperature of exhaust pipes, and avoid infrared chase.
  • It can be used as petrol antiknock (in place of tetrasthyl lead) to produce unleaded petrol.
  • Used in fuel oils such as diesel oil, heavy oil, light oil etc, It can eliminate smoke, save energy and reduce air pollution.
  • Adding 0.1% Ferrocene to diesel oil can cut down the consumption of oil by 10--14%, eliminate smoke by 30--70%, and improve power by more than 10%. And no deposit is left at the spray.
So it plays a dominant role in the development of fuel oils and improvement of their moderate conditions. The above are published by a chemical manufacturer in USA.
Also read some more FAQ's on this, if you are in doubt.
I think it will benefit those smoking diesels more than anyone else due to the chemicals inherent properties and in combination with the other agents of the pill.
Although its existence is not without controversies with some people claiming that it doesnt work, marginal increase etc etc but just like any of such product you cannot hit a 100%.
Just like some premium fuels brand that work in some engines but not with others.
dadu is offline
Old 28th March 2008, 22:14   #33
tsk1979's Avatar
Thanked: 23,494 Times
So its something you add to diesel to make it better.
Does not really make it different from things like STP/SystemD/HP Power/BP High speed diesel etc., right?
tsk1979 is offline
Old 29th March 2008, 13:23   #34
Thanked: 463 Times
It does see here
Primarily, you will not find Cetane/ Octane boosters and anti-knock agents in most of these detergent based cleansers.
dadu is offline
Old 22nd April 2008, 13:11   #35
condor's Avatar
Thanked: 16,902 Times
@dadu, how is the pill ?
And for the petrol burners, check this out: 5ml per 10 litres. 20ml pack.
Octane / Cetane booster - MP6Ty-elfp905.jpg
condor is offline
Old 22nd April 2008, 15:50   #36
Thanked: 463 Times
Waiting for the needle to touch half-mark, atleast then we can some reasonable level of stats based on that.
dadu is offline
Old 22nd April 2008, 15:54   #37
condor's Avatar
dadu : Waiting for the needle to touch half-mark ..
What have you been doing with the truck ? She's not meant to be sitting idle like that. ... Unless the FE has improved phenomenally !
condor is offline
Old 24th April 2008, 07:33   #38
Hi, dont know about the chemistry behind it but I have been using the pill in my santro and tavera since last 6 months and have found the following difference
1.) In the tavera, there was a definite lowering of engine clatter / sound and the pickup has improved a lot. Overall the vehicle feels a lot smoother to drive needing less gear change than before (Increase in Torque ??). Mileage too has improved but not much maybe to the tune of 10-15%.
2.) The santro feels like a verna - huge improvement in pickup and smoothness of the engine (MAKHAAN !!!). Feels so smooth to drive. Mileage has improved by around 2-3 Km / lt.
Now I am not connected to TULSINET in any way, these are my observations after using their pill. Their sales guy visited my tea garden and convinced us to buy 100 pills (10 X10 strips) for use of the Gensets (580 KvA) and even gave a demo on these monster engines. Fuel consumption reduced by 25 % and there was a huge reduction in engine sound and visible smoke. Unfortunately these engines were modified to run on GAS, so I thought why not use it in my cars.
I am happy with it.
Lifewater is offline
Old 24th April 2008, 09:43   #39
Thanked: 463 Times
I do not differ with lifewater on the engine performance.
For the Safari:
- Engine is quiter and lesser of the 'krrr' knocking noise, while pickup
- Low end torque seems to have improved, power delivery feels crisper.
- FE values will have to wait till half tank for the calculations.
PS: Perhaps it would have been a good thought to distribute the pill (still 9 left with me) in the bangy team meet for some more genuine feedback from ppl willing to try.
dadu is offline
Old 24th April 2008, 11:14   #40
Kaizer Sozay's Avatar
Thanked: 7 Times
Contact Details
I wasnt able to find any contact details ont he website. can anyone post them
Kaizer Sozay is offline
Old 24th April 2008, 11:28   #41
Thanked: 463 Times
See post #24
dadu is offline
Old 25th April 2008, 14:52   #42
Thanked: 7 Times
I went to their office at East of Kailash, and purchased it.
I broke one tablet into 4 pieces and put it in my tank (Approx 25 Litres remaining in the tank) drove to Noida no immediate difference, guess will have to wait for the drive back and then post again.
Old 26th April 2008, 17:37   #43
Thanked: 463 Times
Okay, following is the FE.
With Normal Diesel + System D(only 20-30% AC) : 9.4 kmpl
With Normal Diesel + MP6ty (100% AC) : 10.7 kmpl
If you negate the AC usage %, FE increase is about 14%
If you assume that the Increased AC usage ate up 1 kmpl, FE increase comes to around 24%
This is in peak hours city driving, no highways.
I also forgot to mention that the cranking time also reduced while starting and so did the stopping shudder too.
dadu is offline
Old 26th April 2008, 19:10   #44
kailashnj's Avatar
Thanked: 384 Times
Hi Dadu,
I am interested in getting this magic pill. I also wrote to the email address that you had given but to no avail. Can you help me buy this product in Mumbai. I want to use it for my Baleno.
kailashnj is offline
Old 27th April 2008, 09:29   #45
Thanked: 463 Times
Initially I had also contacted one of their agents in mumbai but he replied very late and I had already bought it by then. He is based out of mumbai only so you can save the postage etc.
gopala krishna murthy karamcheti, biofuels india-mumbai, gopala49@yahoo.com
Originally Posted by kailashnj View Post
Hi Dadu,
dadu is offline
