Team-BHP > 4x4 & Off-Roading > 4x4 Technical
Old 23rd October 2008, 10:03   #31
khan_sultan's Avatar
Thanked: 6,469 Times
....I often have to drive hundreds Kms to reach off-road venues. How did you deal with the on-road handling of your CL340?
A solution (may be expensive/tough -- but a solution nevertheless).
Get one of this trailer attached to your GV to lug your 340 on-road to reach the OTR spot. This way you will have best of the both worlds . (and you can keep different/spare axles also to choose from for your 340 :-))
Cheers,
khan_sultan is offline
Old 24th October 2008, 11:02   #32
ex670c's Avatar
Thanked: 2,170 Times
Wider Front Track
Hi Samurai,
We have fitted Wider Axles on 2 JEEPs in Chennai.
1) Patricks JEEP (XD4.9P + KMT90 + 5.38:1+ 235-75-15 Pirelli Scorpion AT)
2) Dr.Jones Prowler (XD3P + KMT90 + 5.38:1+ 31"-10.50-15 BFG AT-KA)
The Conversion is bolt on and there is not cutting or welding involved, i.e the CJ3B/CJ500D/MM540 (Non-NGCS) have the same Chassis width and also the same Leaf Springs Lengths / the spring pack count differs)
The Advantages
1) Improved turning radius
2) The Wider Front Track prevent the vehicle from wandering on the road (pulling left-right due to road undulations)
Disadvantages
1) Increased un-sprung mass of the wider axle & Housing.
However I must add that, we have not felt any suspension or steering related issue with these mods. (Patrick has Gas-Charged Shock-Absorbers in the front)
2) Front Wheel Sticking out of the body.
To improve the handling of the CJ3B I would suggest
1) Level Your suspension (Check your Leaf Count)
military CJ3B Front 10 Rear 11
CJ340 Front 8 Rear 9
MM540 Front 9 Rear 10
Mr.Behram Dabhar can correct me on this.
2) Use a shock-absorber with a bigger bore (Force Traveller Rear Shock Absorber)
3) take a How to Drive a JEEP like a Maniac classes from Suresh Stephen or Giri Tirumale. -- Will make you immune the rolling and pitching.
4) Carry Nitrous, madan80 and Me in your JEEP when ever you travel
Arka
ex670c is offline
Old 24th October 2008, 16:55   #33
Samurai's Avatar
Thanked: 49,720 Times
Yes, I recall that from our earlier talks. I was attracted towards this mod because of no cutting/welding business.
Disadvantages
The first one can be countered to switched to alloys, right? The second one, any structural issues coming out of that?
Which will result in loss of height.
Won't that make the ride rather harsh?
I haven't seen them on-road, only offroad. Will watchout next time.
Fastest way to flatten the leafs?
Samurai is offline
Old 31st October 2008, 11:57   #34
Cyrus43's Avatar
Thanked: 230 Times
Hello all - Behram Dhabhar here - Dear Sharat - on how I managed my CJ340s onroad handling to reach Great Escape spots? Simple, I flew down to the nearest airport, got picked up in Scorpios etc and took over the CJ only at the start line. After all, what are drivers for? My driver is so careful with the 340 that he takes 3 days to come from Jaisalmer to Mumbai. So? No problem for me. I just fly back. Simple.
On the subject of wider axles, please provide more data.
Best regards,
Behram Dhabhar
Cyrus43 is offline
Old 31st October 2008, 17:33   #35
Thanked: 321,729 Times
Sorry but I couldn't resist. I have seen how Mahindras drivers ABSOLUTELY TRASH Jeeps on their way back from the Great Escape. Yup, witnessed it first hand since all of us used to leave pretty much around the same time. IIRC there was also an incident where a reckless official driver turned a custom Jeep turtle on the way to a great escape (Silvasa? Goa? Dont remember).
GTO is offline
Old 31st October 2008, 18:51   #36
headers's Avatar
Thanked: 564 Times
Originally Posted by nitrous View Post
Once, I've had a sudden braking situation in a CJ3B shod with Pirelli 215mm wide AT tyres. Scary would be an understatement.
When was it nitrous?
Originally Posted by U.B.Singh View Post
Hello Sir,
not to be confused by all the above posts.
All the jeeps (not SUVs) made by Mahindra have almost the same knuckle, spring, spindle,etc.
Once you put the 3 inches wider MM540 axles, your 340 get the specs of the Mahindra Classic. Rest is all well known to Classic owners, about stress, stability, strength etc.
Sir, you are the BOSS of all jeeps/jeepers, so we should abide by your advice. Sir, why not post some pictures of your amazing collection - I'm told you have 43 or so in all!
headers is offline
Old 31st October 2008, 21:42   #37
DirtyDan's Avatar
Thanked: 1,664 Times
Hi Samurai,
Disadvantages
Arka
Samarai, I think the greater concern here is the effect the increased weight of the axle will have on the old springs especially when dropping into a hole, articulating. The alloys and bigger tyres would add to the problem, if there is one, more weight on the end of a lever, in effect. So would the increased width inasmuch as the wider axle could drop just a little bit farther, e.g. longer lever. Perhaps it simply is not a problem but that is what I meant before and, I think, is what Arka means.
DirtyDan is offline
Old 19th November 2008, 22:28   #38
headers's Avatar
Thanked: 564 Times
The cardinal rule is to go fast / float over obstacles.
Wonderful post Behram, very informative for the less informed. And I love your cardinal rule
headers is offline
Old 21st November 2008, 09:41   #39
trammway's Avatar
Thanked: 482 Times
Behram, generally I don't make any changes unless I understand all the pros and cons. I am however curious of the following statement by UBS.
Does that mean CJ340 has a shorter axle than CL340?
Yes, CL340 aka Mahindra Classic is 3 inchs wider than the CJ340. The Classic shares the same wide track with MM540. Also the spring plate count in CL340 is of same with MM540. 9 in the front and 10 in the rear.
If I can share this info, Mahindra overseas MM540 (at least what I have seen from internet parts catalogs were marked the images exactly or similar to CL340 of India )
One more information to be cleared here, Please make a note that there is no spearate CL340 DP and CL340 Classic. It is misleading information, as CL340 is nothing but Mahindra Classic.
CL340 DP simply says the engine is XDP 4.9 2112cc engine.
I will explain the more insight of CL340 DP aka Mahindra Classic identification and bit of technical information when I progress my Jeeping exercise story in the same forum.
http://www.team-bhp.com/forum/4x4-of...excercise.html
I'm ready and welcome critiques and comments now.
trammway is offline
Old 21st November 2008, 11:16   #40
Samurai's Avatar
Siva, you are contradicting some very well established facts. CJ340 and CL340 are same, but CL340 and CL340 Classic are different. The former has drum brakes and latter has Disc brakes. There are some more changes, there is a thread on that.
https://www.team-bhp.com/forum/4x4-o...sic-cj340.html
Samurai is offline
Old 21st November 2008, 12:31   #41
trammway's Avatar
Thanked: 482 Times
Well, I still have reasons to say no or defend for it. In fact the Classic (truly) which I own is mfg in 1996 with all the specs as mentioned in the thread.
I can even add some more information about identifying the classic from CJ340 or other Jeeps. My observations will following my own thread which is going in episodes.
Please check my other thread about Jeeping exercise where GTO posted the pics of his owner's manual. You can see the Classic manual stating CL 340 DP 4 wheel drive (very prominent) not CL340 Classic.
trammway is offline
Old 21st November 2008, 14:22   #42
Samurai's Avatar
Look at the what Behram says:
Dear all - let me clear all queries. The original vehicle was known as the CJ3B about which I am not writing here. It became CJ340DP when the Peugeot XDP4.90 engine and the 4 speed KMT90 transmission were dropped in it. In 1995, the CJ became the CL as the nomenclature CJ was owned by Chrysler and therefore M&M changed over from CJ to CL. The CJ/CL340 was made from 1993 upto 1997 when the CL340 classic was introduced.
Why was the classic born? - the CL340 classic is a domestic version of the CL340RHD classic sold by M&M in England and other RHD countries like South Africa etc. It's LHD version was sold in France. Export vehicle was given in India also, the only difference was that European specification lights etc (E marked) were not given inthe domestic version. That's why.
According to him, the Classic came out in 1997, but you have a 1996 Classic?
Let's wait for experts like Behram/UBS/Arka to clarify this.
Samurai is offline
Old 21st November 2008, 18:44   #43
Classics were definitely available in 1996. The first one I saw in person was a '96 build. The owner & I eventually became friends after I got my Classic and we had many an offroading trip together.
GTO is offline
Old 21st November 2008, 19:35   #44
Samurai's Avatar
Thanks for the clarification, so it started in 1996. I think Behram and RedMM340 have the 1995 version CL340 which was not Classic. Let's wait for their response, they can clarify whether all CL340 were classic or not.
Samurai is offline
Old 21st November 2008, 20:00   #45
trammway's Avatar
Thanked: 482 Times
I'm still sticking to my words, after CJ340 DP the version produced was CL 340 DP aka Mahindra Classic.
I'm in doubt if I can post my Jeeping exercise episode in weekends, if I can I will include the most important aspects (nearly 30 points) identifying a Mahindra Classic.
That post will sure tell you the way identifying of Mahindra Classic.
If you can do all of those modifications in your CJ 340 DP it can be called as CL 340 DP aka Mahindra Classic.
trammway is offline
