Old 30th January 2009, 12:37   #31
ex670c's Avatar
Thanked: 1,951 Times
Upgrade - Part II
Once the dates were finalized for Munnar OTR, I decided to upgrade my MM540XD a bit more.
The Following Work was done
1) Strip the old rusted body
2) Strip/Prime/Paint the Chassis
3) Install a new Tub (old 1987 MM540DP) and new Body beds.
4) Change the rear Axle to Bolero
Arka
ex670c is offline
Old 30th January 2009, 12:49   #32
Samurai's Avatar
Thanked: 45,606 Times
Only to complain later that Munnar trail was not challenging enough.
Samurai is offline
Old 30th January 2009, 13:44   #33
Blue Thunder's Avatar
Thanked: 386 Times
...3) Install a new Tub (old 1987 MM540DP) and new Body beds....
Arka, that tub looks familiar ??
Blue Thunder is offline
Old 30th January 2009, 18:30   #34
DirtyDan's Avatar
Thanked: 1,565 Times
Hi Arka, are you going to rust proof it after painting? What will you use to do this if so?
Why did you change to Bolero axles? Wider stance?
DirtyDan is offline
Old 31st January 2009, 11:39   #35
ex670c's Avatar
Wider Axles
Hi Dirty_Dan,
I will sand blast the body and do the minor tinkering and then considering one of the following Primers
1) Polyurethane Primer
2) Expoxy Primer
3) Zinc Sulphate
4) Red Oxide
While tinkering I have given strict instruction not to use Bondo/metal Paste.
Because the metal paste absorbs water and rust the sheet metal.
Bolero Axles.
After the Front OKBJ conversion the track difference was 6".
1) Vehicle was looking very funny
2) I wanted to switch to One Piece FFRA. The older setup the outer flange develops play/slack and cuts the axle splines. ( suffered that twice)
Also wrt NGCS MM550XD (post 2004). They use 53" Front and Rear Track.
ex670c is offline
Old 5th February 2009, 10:54   #36
ex670c's Avatar
Chassis Painting and Body Swap
The Following work was done
1) The Old body was removed from the chassis
2) The chassis was scrapped of old paint
3) Chassis was washed with washing soda
4) Chassis was primed & painted
5) New Body (1987) was fitted with new body beds/mounts
ex670c is offline
Old 5th February 2009, 11:05   #37
starter's Avatar
Thanked: 903 Times
Hi Naren,
Could you please specify on which New or Old M&M vehicles these Diff-Ratios are used.
3.73:1 = 41/11
Arka
Dear Arka,
I've been researching quite a lot on 4X4s available in market currently (affordable ones though). I think the new Major (CL550) comes with the differential ratio of 3.73:1. I am a real rookie in this, so maybe, i am wrong. If so, please excuse me.
Cheers,
Deepak
starter is online now
Old 5th February 2009, 11:42   #38
vinod_nookala's Avatar
Thanked: 430 Times
wonderful arka,
You are practically doing a mini restoration project. Work happening at lightening pace i suppose!! What tyres are you planning to replace your current NDMS?
Long time since we met...let us meet up some time!! :-)))))
P.S- Must appriciate your sourcing ability, you sourced rare bolero 4wd axles and now a complete body which seems to be in good condition!
vinod_nookala is offline
Old 5th February 2009, 12:12   #39
ex670c's Avatar
Rear Differential
Since my front track was 57" and Rear track was 51".
I decided to change the rear track to the Bolero Differential.
The Only catch was the Bolero Differential was off-set to the left where as the MM540 differential is off-set to the right.
So I had the Bolero Differential Axle Tubes switched around.
The First Batch of Pictures -
LSD
Differential Housing and switched tubes
Inner Oil Seal
Pinion Yoke replaced the Companion Flange.
ex670c is offline
Old 5th February 2009, 12:21   #40
Thanked: 430 Times
so, now you have a right offset diff?? What is the length of bolero rear axle? 53inch?
I thought MM550 NGCS came with 53 front and 51 rear. 57 inch of your isnt too broad?
Old 5th February 2009, 12:39   #41
ex670c's Avatar
Ngcs Mm550
Hi Vinod,
I was under the impression that the NGCS was 53" Front and 53" FFRA.
Arka
ex670c is offline
Old 5th February 2009, 12:48   #42
ex670c's Avatar
1 piece FFRA
The New 1 Piece FFRA.
Pictures of
1) Drum 139.7 PCD
2) Hub 139.7 PCD
3) Comparison of the Spindles
4) FFRA Assembly
ex670c is offline
Old 5th February 2009, 13:50   #43
Thanked: 430 Times
Now you will have clean rear rims without oil stains!!:-))))
Old 5th February 2009, 14:41   #44
fk7
fk7's Avatar
Thanked: 160 Times
i can see that you have army rims, what tyres are you putting on those?
FK
fk7 is offline
Old 6th February 2009, 11:01   #45
ex670c's Avatar
Tyres
FK
MRF Sand Grip 7.50X16 for Sand and Rocky terrain
MRF NDMS 7.00X16 for Muddy Terrain.
I'm looking out for good Mud-Terrain (Maxxis/BFG) in 235-85-16/245-75-16/255-85-16
ex670c is offline
