Old 31st August 2024, 19:33   #16
Thanked: 336 Times
Re: Use Rpi Zero as a cheaper alternative for Wireless Android Auto | Cost under 2,000 rupees
Originally Posted by ashkamath View Post
How does a non technical average Joe go about getting it done for his car? Would the local FNG be able to manage the installation?
A non technical Joe can do it too, just order the parts and follow the instructions. You will be able to do it.
From a Non Technical Joe.
Wait do I see a opportunity in assembling these and selling them
kvamshi04 is offline   (2) Thanks
Old 1st September 2024, 07:15   #17
Thanked: 95 Times
Originally Posted by gischethans View Post
[*] RPI Zero 2W, RPI camera, heatsinks from Silverline Electronics[*] RPI Zero case from Robocraze[*] Card reader from Amazon[/list]
Hi, Can you please advise why did you buy the RPI Camera module?
carlover86 is offline
Old 1st September 2024, 09:10   #18
gischethans's Avatar
Thanked: 862 Times
The camera module was not necessary for this Android Auto project. I wanted to try out this camera project
However, it failed due to two reasons -
  • The heat sink I had stuck on the processor was not allowing me to close the lid as it was interfering with the camera board
  • I was not fully aware of the power requirements for the board and the charger I plugged in initially failed to power it on. I later moved on to Android Auto installation and left this one for now.
gischethans is offline   (2) Thanks
Old 1st September 2024, 10:25   #19
jithin23's Avatar
Thanked: 3,214 Times
Lovely post and this is a breakthrough! The explanation and working of quite simple. Reminded me of my project work days during my engineering course. Would love to experiment with integrating apps which can be used on the move as well with raspberry pi.
Congratulations on the mod!
jithin23 is offline   (2) Thanks
Old 1st September 2024, 22:02   #20
akash_v12's Avatar
Thanked: 3,030 Times
Small Query: Our Tiago has a noticeable lag when connecting to Android Auto. Will having a wireless system eliminate the lag by any chance? I'm looking forward to doing this, thanks for the mod!
akash_v12 is offline
Old 1st September 2024, 22:40   #21
Thanked: 95 Times
https://www.Youtube.com/watch?v=ll5d342QaCY
Thanks and from your response, its quite evident that you also ordered the Camera Module. I will have to deep study if we could use Smart Life/ Little If Smart platforms to list these cameras there. It will help in setting up a consolidated app which can host all these cameras together for a better vieweing experience!
carlover86 is offline   (1) Thanks
Old 2nd September 2024, 09:17   #22
dipdawiz's Avatar
Thanked: 1,087 Times
Ideally it should behave same as your wired AA. In some cases there is more lag in wireless than wired - due to obvious reasons that data now passthough another system(the dongle). If the lag is due to head unit, this dongle will not solve it.
dipdawiz is offline   (1) Thanks
Old 3rd September 2024, 08:25   #23
Thanked: 89 Times
Works perfect. I had to find a good micro USB cable but no issues after. This is the cable I used. Duracell USB A to Micro Cables,... https://www.amazon.in/dp/B0BCQMY3W5?ref=ppx_pop_mob_ap_share
But any data transfer cable should with just as well.
Shrek8421 is offline   (1) Thanks
Old 3rd September 2024, 11:01   #24
Beerus's Avatar
Thanked: 144 Times
Tired it with VW RCD340G. Using the pi 2w, with a 32GB card and a very old usb cable that I found at home. The initial connection takes around 40 seconds to a minute.
Pro's:
- Wireless connection
- Very cost effective
- Thrill of DIY
Cons's:
- Noticeably laggy/higher latency compared to the wired AA(have ordered a new data cable to see if that resolves it. There are also some fixes recommended on Github, will try those too)
- Every 40 mins or so, there is a lag in the song playing(will update if it is solved with the new cable)
- Doesn't switch off after the car is switched off
- Battery drain on the phone
Verdict:
It was fun to execute the DIY project, and a cool feature to unlock. But because of the battery drain on the phone you will have to connect to a charger in the car so might as well use the wired AA which is much more smoother and responsive.
Beerus is offline   (2) Thanks
Old 3rd September 2024, 14:32   #25
dipdawiz's Avatar
Battery drain issue would be always there. Hence having wireless charger makes more sense with wireless AA/CarPlay. Also, that is another reason I always have saved maps of my city and download maps of a destination before I leave for a trip. Prefer to download songs in YT music, that way mobile hardly gets heated up, less network related issue and battery drain is in check. And when required I put the mobile in wireless charging (or at times connect to cable that comes from back seat's USB port keeping console area wire free).
Old 3rd September 2024, 19:40   #26
Thanked: 95 Times
Thank you, Dipayan for the input. I took the plunge and ordered the following items on 26 August from different portals as not all the items were in stock at one place -
  1. RPI Zero 2W, RPI camera, heatsinks from Silverline Electronics
  2. RPI Zero case from Robocraze
  3. Card reader from Amazon
Just one question, when you move out of the car, after locking it, did you see that the Raspberry Pi light remains on? Could this become Aux Battery Drainer?
Old 3rd September 2024, 19:53   #27
Thanked: 862 Times
In my Punch, the light stays on for some time after which the port stops supplying power and the device turns off. The device was not visible over Bluetooth / WiFi. The same used to happen when my dashcam was plugged into that port.
gischethans is offline   (1) Thanks
Old 3rd September 2024, 20:28   #28
Thanked: 95 Times
Ok Cool, I tried that for seconds. Let me try it for 15 mins and see if Tata has designed the USB power supply same for Punch and Nexon EV Max
Old 5th September 2024, 17:47   #29
Thanked: 75 Times
Hello gischethans,
Can you please let us know if the case cover closes or not if the heat sink is used but camera module is not used ?
Also, how did you attach the heat sink on the processor ? Was a thermal paste provided with the heat sink ?
Thanks in advance.
TheGodfather is offline   (1) Thanks
Old 5th September 2024, 19:45   #30
Thanked: 862 Times
Yes, the case cover closes fine with only the heat sink present. I guess there could be other kinds of heat sinks that might work even with the camera.
It had a peelable tape, presumably a double-sided one stuck onto it. I removed the protective cover and stuck it on the processor. Without a screw-based setup, I don't think it would hold on top of thermal paste.
