Old 6th January 2008, 01:40   #76
Gill's Avatar
Thanked: 16 Times
Originally Posted by low_bass_makker View Post
Going active has it benefits but it involves lots of money also. I can adjust the levels, slopes, Cut-off freqs to suit my tastes. and to extract full from my setup.
If one has used a active setup he cannot return to a Passive setup.
Lbm Bai ji, your last line gives a strong indication,what it's like running active setup!
Moreover i am planning to change the amps n front spkrs in near future.
Cost wise i feel it's cheaper if one has HU n Amp to do it,as good set of speakers with good crossovers comes at a cost,moreover in active setup,ne can select the midbass-tweeter of liking!!!
Cheers!
Gill is offline
Old 6th January 2008, 18:24   #77
clipto333's Avatar
Thanked: 7 Times
Clip's enthusiasim to DIY should be encouraged.
thanks navinji )
had i been living in delhi or mumbai, the threads i start would mostly be in diy section :-)
why? because where i live, nothing is available.
cheers
clipto333 is offline
Old 6th January 2008, 21:48   #78
ScarySkulls's Avatar
Thanked: 36 Times
Worry not Uncle ji. We are going to Delhi soon. Right?
ScarySkulls is offline
Old 25th March 2008, 13:54   #79
MillionSwords's Avatar
The *Active* ICE Discussion Thread
Changing the phase of the tweeter takes cares a lots of disjoints if wired in a passive network as I have personally observed and done in Zucherro Safari which has the 242.
It may be basic, but pl consider to explain - Active vs Passive!!
MillionSwords is offline
Old 25th March 2008, 15:38   #80
Thanked: 306 Times
In lame man terms in a active setup there is individual amp for tweeters, and midbass and in a passive setup there are cross over which filter out the signals.
In a active setup one can change slopes and levels from the HU. But in as active setup the filtering is done by the passive crossover so the majority brands only offer tweeter level only rest is preconfigured.
low_bass_makker is offline
Old 25th March 2008, 22:14   #81
BHAGWAN's Avatar
Thanked: 13 Times
please explain this !!!
How ?
Please do explain.
I do not know how this can be done ?
Please do bear in mind, we are talking about HU & not a processor.
A processor will allow you to configure the Mid-Bass & High & Bass.
However, I want to understand how you will do it from a Top of the line - Pioneer or Alpine or any other.
Does the HU give your 12 pre outs ?
Front High Out - Left
Front Mid Out - Left
Front Bass Out - Left
Front High Out - Right
Front Mid Out - Right
Front Bass Out - Right
Rear High Out - Left
Rear Mid Out - Left
Rear Bass Out - Left
Rear High Out - Right
Rear Mid Out - Right
Rear Bass Out - Right
Maybe I am off track.
Sir, please do explain.
Appreciate it.
BHAGWAN is offline
Old 25th March 2008, 23:05   #82
Thanked: 306 Times
Originally Posted by BHAGWAN View Post
How ?
Please do explain.
Rear Mid Out - Left
Appreciate it.
God Ji I was talking of 4 way active. Only speakers+ subs, 3-way front and subs. The one HU I came across is Clarion HX-D2. Alpine HU+ PXA combo, Pioneer P9 combos can do it.
If one want the above combo one put to PXA for the same to get 16 channels with include 12 full range and 4 sub woofer.
Old 26th March 2008, 20:34   #83
BHAGWAN's Avatar
Thanked: 13 Times
With a Processor - yes - but HU doing it ???
Hi LBM !
With a processor - yes - sure.
However, direct HU doing it.....
You did mention the Clarion, but I have not been exposed to it, hence no comments.
The other 2 options are HU + Processor.
Else, one has to buy the Steg power Amps and put in the 'chips'
I am sure you know what I mean !!! All the Best !!!
BHAGWAN is offline
Old 26th March 2008, 21:56   #84
Thanked: 306 Times
Hi LBM !
You dont know about HX-D2..that is strange. Anyways here is some info about it...
Clarion India | HX-D2
Clarion HX-D2 Head Unit : Equal to McIntosh/Nakamichi/Pioneer P9 etc? - Talk Audio Forums
Ya with Steg amps the possibility are endless
Old 27th March 2008, 12:54   #85
Technocrat's Avatar
Thanked: 2,705 Times
B the Audi TT install which I had intially directed to uses HXD2 HU:
Here is it:
http://www.team-bhp.com/forum/sound-...-tt-setup.html
Technocrat is offline
Old 27th March 2008, 17:21   #86
clipto333's Avatar
Thanked: 7 Times
Bhagwan,
The Alpine 9887, pioneer p880 can do 3 way active. i.e. High, Mid, low. you can do a 2 way front plus sub.
The clarion HX-D2 which gunbir is using right now can do 4-way active. i.e. 3way front stage with sub. this is one of the best head units available.
The clarion hU has 4 pairs of preouts. It can't play mp3 or any other compressed format. it only plays Audio cds. Plus it doesn't have a built in amp. I dont know if the pio has it. the 9887 has an internal amp which can be switched off.
Re. alpine processor, it either needs the rux controller or a compatible alpine HU. The other alpine processor(650) i think is independent.
i hope im clear.
cheers
Old 27th March 2008, 18:08   #87
Technocrat's Avatar
Correction the HXD2 can play MP3. I saw it play a recorded CD
Old 27th March 2008, 18:14   #88
Thanked: 306 Times
I think it can only play Audio CD.
Old 27th March 2008, 18:16   #89
Technocrat's Avatar
Just checked with EVO6 I stand corrected yes it can not play MP3 since the cd was recorded I thought it was mp3
Sorry for the confusion
Old 27th March 2008, 22:10   #90
sk456's Avatar
Thanked: 7 Times
hx d2 no mp3 for sure
Last edited by Technocrat : 28th March 2008 at 12:16. Reason: Please dont post with dots & hyphens
sk456 is offline
