Old 22nd May 2009, 12:26   #91
Fountainheader's Avatar
Thanked: 13 Times
Originally Posted by chiragh_bir View Post
What's the price of infinity in India?
17500 for the 475a and 25000 for the 1600a. These are MRPs.
You'll get discounts I guess.
How much for the Rockford ?
Fountainheader is offline
Old 22nd May 2009, 13:04   #92
chiragh_bir's Avatar
Thanked: 74 Times
Rockford is like 16 including shipping !!
It will come with Box, Bass Knob, Test certificate , Extra Fuse!!
chiragh_bir is offline
Old 22nd May 2009, 13:26   #93
Thanked: 74 Times
more info is here !!
Rockford Fosgate Punch P6001 (p6001bd-RED-BOX) Mono Subwoofer Amps Car Amplifiers Car Audio and Video - Sonic Electronix
Old 22nd May 2009, 14:19   #94
rider60's Avatar
Thanked: 56 Times
after you get a 600W RMS mono what sub-woofer are you planning to run on this amp? is it one or two subs?
also like i asked you earlier my friend got this 7001 amp and is now really bugged out for he has to make a choice between brands and number of subs to run, i would like to see how yours would come along.
rider60 is offline
Old 22nd May 2009, 14:21   #95
Thanked: 74 Times
Only one Sub i.e is my old Blaupunkt V SPL which 600w rms and 4 ohms DVC
Old 26th May 2009, 20:07   #96
abhinav.gupta88's Avatar
Thanked: 325 Times
4 Ohm DVC.
Why not go for the one razor1411 has got.
It would be around 16-17 from USA
abhinav.gupta88 is offline
Old 27th May 2009, 00:40   #97
razor4077's Avatar
Thanked: 298 Times
Originally Posted by abhinav.gupta88 View Post
4 Ohm DVC.
Who's this 1411 guy??
razor4077 is offline
Old 27th May 2009, 00:41   #98
frankmehta's Avatar
Thanked: 3,577 Times
hahahhahhaha. evil twin of the original razor4077!!
sorry chiragh, couldn't receive your call. anyways, the amp I spoke to you about, I shall find out about it and let you know..
frankmehta is offline
Old 27th May 2009, 00:49   #99
govigov's Avatar
Thanked: 1,092 Times
How do you plan to run the rockford fosgate p6001 ? the specs are 300wrms @ 4ohms and 600wrms @ 2 ohms. the velocity DVC can only be fixed at 4 ohm and 1 ohm config. at 4 ohm config, you will hardly be getting half the rated power of the sub.
govigov is offline
Old 27th May 2009, 00:56   #100
Thanked: 325 Times
his is a 4 ohm dvc. So it'll be powered at 2ohm /8 ohm. He will run at 2 ohm.
Old 27th May 2009, 01:02   #101
govigov's Avatar
oops! my mistake. apologies.
OT: can the impedance of the coils be measured using a multimeter?
i am not sure if mine is a 4ohm dvc or a 2 ohm dvc.
govigov is offline
Old 27th May 2009, 09:50   #102
DerAlte's Avatar
Thanked: 2,919 Times
The coil resistance, not impedance. Should show about 1.4-1.7 ohms for 2 ohms impedance coil, 3.0-3.5 ohms for a 4 ohms.
DerAlte is offline
Old 27th May 2009, 09:55   #103
Thanked: 74 Times
There is also one Audison Lrx Mono Block Lying with someone!!
Is it a good buy , which is used for like 7 months !!
900w RMS @ 1 ohm ( am not sure about how much actual it produce)
But brand Audison is bubblling my mind
JBL am not Buying nor RF!!
Final Choice is between Kenwood 9104d or Audison Lrx !!
Old 27th May 2009, 12:07   #104
razor4077's Avatar
Thanked: 298 Times
If it's in good shape and the price is right, then the audison is a good choice. How much is the asking price?
Old 27th May 2009, 13:17   #105
Sam Kapasi's Avatar
Thanked: 2,380 Times
If those were my choices I'd take the Audison quite easily.
Sam Kapasi is offline
