After reading multiple posts on people cutting the gear lever and labelling it as a short shifter, i decided to make my own design.
So, one lazy afternoon, i opened up the whole shifter section with the linkage rods, and studied the shifter.
The Shifter Rod.
The Shifter ball. The rod moves in this.
The full System
The Shifter Ball.
The shifter rod was cut 4 inches on the upper part of the ball, and 2 inches were added to under section of the ball. Basically the ball and linkage length was increased.
The Ball assy was then exteneded by 2 inches to aling the shifter linkages to the gearbox.
Final Assembly and testing.
This is 3rd gear engaged.
And this is 4th gear engaged. See the throw is really small. And Shifts with an Awesome mechanical clunk.
After this succeded, i worked on to align the assembly, and the crude welds were done with. It has been rewelded with MIG welding, with a CNC cut 3mm Ms plate as base, and 12mm Ms rods as extenders. I also replaced all the bushes. The whole system is completely reversible anytime, in just about 2 hours. No body panels cut, no linkages modified, everything stock.
Feels good to be an engineer.:I Rule:
Originally Posted by V-16
(Post 2803502)
So u reduced the linkage length to come up with the shorter throws. I didnt want to tamper the linkages, so modded the Lever and Mounts.
As u said earlier, the pics are gone. Will be very helpful if i saw them. i have dropped a PM.
Sure thing buddy. Am out of town for the next two days. Will email the pics to you on Monday
@racerdabba: Nice DIY. One of my friends want to do a short shifter on his Eon - I will forward him this link.
@V-16: If it is not much of a bother, can you upload the pics in this thread? It might help others also.
Originally Posted by racerdabba
(Post 2803497)
Nice DYI
Did the original panel/housing has the space for the raised assembly?
Pictures will do the Talking.
Good DIY . Basically any DIY rocks :D .
Coming to point , as I understand , it reduces the throw of the stick right ? . Good to ppl with short hands .
It's supposed to enable you to shift faster
Nice DIY, the throw looks really small from 3rd to 4th, hows it with reverse or 1st gear? Did you maintain the angle of the rod?
Nice! Is this possible on a safari?
Originally Posted by black12rr
(Post 2804208)
Coming to point , as I understand , it reduces the throw of the stick right ? . Good to ppl with short hands . |
Its not about the length of the hands; its for quickening shifts, like a rally car does.
Anyway Black12rr gave it a whole new perspective. lol:
Btw, Nice DIY job racerdabba
Originally Posted by autotranny
(Post 2810833)
Btw, Nice DIY job racerdabba |
I know .Just was thinking about other benefits. This is a short shifter right ? . Not a serial shifter , like 1-2-3-4-5 and 5-4-3-2-1 ?
Originally Posted by motomaverick
(Post 2809425)
Nice DIY, the throw looks really small from 3rd to 4th, hows it with reverse or 1st gear? Did you maintain the angle of the rod? |
Same goes with 1st/Reverse. Yes i did maintain the angle of the rod. The sideways movement has not been altered. Will have to modify the linkages for that. Let me find another Sunday.
Originally Posted by somubj
(Post 2809933)
Nice! Is this possible on a safari? |
Definitely. The same principle can be applied to any car having solid linkages to the 'Box. For Wire linked shifters, a different approach is needed.
(Post 2811058)
I know .Just was thinking about other benefits. This is a short shifter right ? . Not a serial shifter , like 1-2-3-4-5 and 5-4-3-2-1 ? |
No. Not a Serial shifter. Just a Short Shifter.
(Post 2811444)
As i understand this you have shifted the fulcrum of the lever ( ball joint) towards the top end to achieve a short throw. So this should act sideways also. Is it so?
