Re: Tata Nexon DIY: HID Bi-Xenon projector foglamps installation Quote:
Originally Posted by raghp74 Hi, instead of using new switches, can we make use of the existing central panel switch bar? next to the boot opening switch. |
Hello raghp74 - no not really. They are all integrated into a single coupler, that is connected via the BCM. If you really want to reuse this - you'll need to remove the single module that houses all the panel switches, open it & solder wiring into the particular button, separately. Then take this wiring out via a 12V source and connect to the new fog lights. I had contemplated this a bit - but that definitely would void the warranty & the hassle is simply too much for very little real gain. So dropped the plan. Off topic update
Rats struck again  . The high-beam solenoid wires of the RHS projector, were a bit inaccessible and I couldn't spray the rat repellent spray on this pair. And the rodents have managed a clean cut on these! So the high beam flap is now non functional on the RHS projector. Another 1-2 hours to be spent now over some weekend, to remove the fog-light and replace the wires + cover them with conduit. Since the lights are working fine & I hardly ever use high-beams, just being lazy about this repair.
