Old 29th June 2021, 19:24   #1
PatchyBoy's Avatar
Thanked: 2,161 Times
DIY - My Fiat Linea T-Jet gets more ambient lighting
I came across a pic of the door pad of an European version of a FIAT. It had ambient lights in the door handle recess. How convenient. People coming along in your car now don't have to fumble around to locate the door handle. FIAT in all its wisdom, decided to leave this feature out for the Indian variants & I wanted it real bad. Not that a lot of people travel in my car and fumble around for the door handle, but I wanted it. They have it. So, I must have it.
This is how it looks OE
Here is an aftermarket install
My conditions were - It shouldn't be "in your face" loud. The color should match OE ambient lights & button backlight as closely as possible. The LED must be concealed & look as OE as possible. Replacement of any components on this circuit, if ever needed, must be relatively easy. This meant a modular install. The thought process was - If the LED goes bad, easy to replace. If the resistor goes bad, still easy to replace. If the window switch panel needs to be removed, easy to do. Just one more connector to disconnect. If the door pad needs to be removed, same as now. If the OE PCB goes bad - you are on your own.
So, as usual, I started doing the homework. I found Cree 5 mm LEDs in Amber to be the closest match. Special thanks to fellow FIAT owner Anil TG, for not only recommending them, but also sending a few over for this project. Then I experimented with resistor values - ranging from 1KΩ all the way up to 22KΩ. The recommended value for maximum brightness is 625Ω, when running on a 14.4V power source. After much consideration & lot of experimentation, I decided to go with 5.6KΩ, based on how I planned to mount the LED. For good measure, I connected the LED to a battery pack & left it on all night. Next day morning, neither the bulb, nor the resistor was even warm to the touch. The resistor value may differ, depending on the mounting approach used. In my case, the LED is a good 25 mm above the roof of that recess.
First step is to remove the door pad. It is described in another thread (DIY: Puddle lamps & Footwell lights for the Linea T-Jet) of mine. So will not repeat here.
Here are the steps -
Step 1 - The lighting window -
Make a hole in the roof of the door handle recess. Apply a piece of masking tape to the exterior covering the hole we just made & fill the hole with hot glue, from the other side. Press a coin to the other side, to get a nice flat filling. Remove coin & tape after the glue hardens. Takes just a few seconds. Now you have a slot filled with translucent glue - diffuses the light a bit & prevents dust ingress into the door pad.
After taking the door pad out, I first cut a slot in the roof of the recess. On the first door I tried using a Dremel, with not so nice results. For the remaining doors, I used an old soldering iron to melt the hole, with much better results.
Step 2 - Wiring
For this, I decided to solder wires directly to the OE PCB, instead of splicing wires.
The driver door PCB has switches for all four doors & a switch for disabling rear windows. Ignition power is supplied on pin 3 (+ve) & pin 5 (GND) to that PCB. Near the pin headers, there is conveniently placed hole. So, I soldered wires to those pins, routed them through the hole & assembled the PCB back in its enclosure and soldered a JST 2 pin connector (dismantling is very easy. Anyone who looks at it, must be able to figure out how to take it apart)
The rear door has a very simple circuit & gets power on pins 1 (GND) & 3 (+ve). In this case, there are no holes available. There is ample space above the PCB in the enclosure. So, I made a hole in that area, soldered two wires to pins 1 & 3 and routed them outside the enclosure and soldered a JST 2 pin connector. The connector is then hot glued to a spot near the OE connector. This will allow the switch panel to be detached, by disconnecting one additional connector.
Step 3 - Preparing the LED
I cut small strips of perfboard, soldered the LED to one end, then the resistor & a 30 cm length of wire to the other end of the perfboard. The counterpart of the JST connector is on the other end of the wire. The entire perfboard assembly was covered in heat shrink, for added protection.
Step 4 - The bulb holder
I searched a lot of 5 mm LED holders which will allow mounting of the LED, without jutting out through the roof of that recess. Couldn't find any. Then I found a few bottles of eye drops (Suzan recently had a cataract surgery & these were empty bottles, which never got thrown out). These caps were the ideal size and shape. So, I drilled a 5mm hole through the top. The LED fits there snugly. However, these caps were white, which means a lot of light spillage into the door pad. So, I painted them black. I always keep a bottle of black nail polish handy, just for such occasions
So the now black eye drop cap gets stuck to the door pad with hot glue, directly above the slot we created in step 1
Step 5 Finishing up
Just insert the LED into the hole on the holder, route the wires to somewhere near the switch panel opening. Fit the door pad back in the car, reach through the opening where the switch panel goes, get the OE connector & the newly added connector, plug them in & push the switch panel into place. Job done.
This is how it will be connected in the car -
This is how it looked, when lit up on the bench, powered by a battery pack
Here are some pictures after completing the install in the car. Now I hope anyone travelling in my car, who is getting dropped off late at night, can locate the door handle easily. Jokes apart, I like to do these things, just for the joy of doing it, even if the feature will be seldom used.
Driver door closed as viewed from the driver seat
Driver door open, lit only by the dome lights in the car
Rear door closed as viewed from the rear seat
Rear door open, lit only by the dome lights in the car
Thanks for reading
PatchyBoy is offline   (47) Thanks
Old 30th June 2021, 06:34   #2
Thanked: 86,505 Times
Re: DIY - My Fiat Linea T-Jet gets more ambient lighting
Aditya is online now   (2) Thanks
Old 30th June 2021, 14:24   #3
clevermax's Avatar
Thanked: 2,898 Times
Brilliant DIY and excellent end results I would say!
Since I've been following this project in the background, I am aware of the amount of time you've invested in research, circuit finalization, and the components to be used. Enjoy the brand new ambiance inside the Jet.
Now I am inspired to do this in my Verna.
clevermax is offline   (1) Thanks
Old 30th June 2021, 14:29   #4
blackwasp's Avatar
Thanked: 27,192 Times
Looks great. Despite being such an old car, the hidden features are still being discovered.
The DIY is class as usual. It just shows that how advanced the car was for its time, and how lazy was Fiat India.
blackwasp is online now   (1) Thanks
Old 30th June 2021, 14:54   #5
Thanked: 5,892 Times
very neatly done. I particularly like the attention to detail perfecting the assembly and modularizing the connections, in areas hidden from sight ; and not just only focusing on perfecting the light throw portion of the install (which is the only thing usually given attention to by a lot of us, whenever implementing such a DIY).
Looks very OEM
venkyhere is offline
Old 30th June 2021, 16:11   #6
Thanked: 1,804 Times
Excellent DIY as usual. Love how you never tire trying to improve your car, and when you decide to go ahead you make sure it's the best job possible. Looking forward to seeing the final pics
keroo1099 is offline
Old 1st July 2021, 13:07   #7
Astonishing DIY
Thank you for sharing such a remarkable DIY
I will execute this DIY this coming Sunday
Krishnaa4700 is offline
Old 1st July 2021, 17:31   #8
Thanked: 70 Times
@PatchyBoy - Thanks for sharing your DIY. Looks clean and awesome.
Can you please share the links of the items that are required for the DIY?
It will be helpful for me to procure and try it sometime!
nax04 is offline
Old 1st July 2021, 21:37   #9
PatchyBoy's Avatar
Thank you. Your inputs during the research phase were very helpful.
Thank you. It bothers me to think that Fiat thought of us as second class citizen & decided to delete these features. But every time I get behind the wheel, all is forgiven
Originally Posted by venkyhere View Post
very neatly done. Looks very OEM
Thank you. Your guidance was invaluable. I know zilch about electronics.
Thanks Buddy
Originally Posted by Krishnaa4700 View Post
Astonishing DIY.
Thank you & all the best with your install
Thank you. My usual sources for these components is either Robu (dot) in or electroncomponents (dot) com
PatchyBoy is offline   (1) Thanks
Old 2nd July 2021, 17:20   #10
Thanked: 299 Times
This is so awesome@PatchyBoy
I shall try this on my multijet. Just love the Linea.
acestormtrooper is offline
