Old 16th May 2024, 11:01   #31
dkaile's Avatar
Thanked: 8,409 Times
Re: DIY: Get Android Auto in any Car/Bike for Free (or under 10k)
Originally Posted by Self Driven View Post
Your thread got me going, did some reading and bought the Real me pad mini for 7499/- 3GB RAM and 32 GB ROM extendable through SD. Installed the HU reload app and followed the Youtube video. worked on the first attempt with my Vivo 27 Pro phone
Now deciding on the holder for the tab and ordered tempered glass for protection
Nice to know this thread helping members, as I had intended it to be. You can always look at the holder for the Tab, that I had posted. Though it is slightly on the pricier side, it has fantastic build quality and the required sturdiness to hold the weight of the Tab and it also has very good reviews on Amazon India (4.4 Rating).
Cheers...
dkaile is offline
Old 16th May 2024, 21:48   #32
Self Driven's Avatar
Thanked: 214 Times
= it has fantastic build quality and the required sturdiness to hold the weight of the Tab and it also has very good reviews on Amazon India (4.4 Rating).
Actually I was looking for a magnetic and a smaller footprint holder. Hence ordered this - https://www.amazon.in/gp/product/B0C...?ie=UTF8&psc=1
Will write about the effectiveness of the holder after i use it
Self Driven is offline   (1) Thanks
Old 18th May 2024, 09:12   #33
Joe367's Avatar
Thanked: 377 Times
Originally Posted by dkaile View Post
Heat can definitely be a concern in the motorcycle scenario, with direct sunlight pounding on the navigation phone, but it will still be usable on the motorcycle, for at least 9 months in a year.
In the Air Condioned Car, heat should be a non issue, as far as my limited testing goes. If you are chilling at 20~25 degrees in the car, why would your tab have any problems, especially when it's location too, is just above the AC vents?
Will keep it further updated.
Cheers...
Actually it is more of a concern in cars than in motorcycles. We cannot park the car somewhere and leave without removing phone or tablet from the car. Once I left my phone inside the glovebox and it had turned off due to extreme heat when i got back. This is also the reason why most dash cameras have wired connection or use capacitors instead of lithium batteries.
This can vary according to the region though.
Joe367 is offline   (1) Thanks
Old 18th May 2024, 09:19   #34
dkaile's Avatar
I have clearly mentioned that you can easily remove and take away the Tab in a jiffy IF you feel that excessive heat will cause issues while storage or parking. While operating the Tab in a Air Conditioned vehicle will be a NON ISSUE as the car should be at a cool ambient temperature while driving. Kindly try not mixing operation and storage of the tab, in this context.
Cheers...
dkaile is offline   (1) Thanks
Old 20th May 2024, 12:53   #35
Jaguar's Avatar
Thanked: 2,804 Times
Cheers...
Actually it is an issue. Even if you are taking a half an hour break, you would need to remove the tab and carry it with you. Otherwise it will tend to get overheated, especially if it is mounted on the windshield with direct radiation. Talking from personal experience. Regular phones and tabs are not designed to be usednin direct sun for long periods.
Jaguar is offline
Old 20th May 2024, 13:03   #36
dkaile's Avatar
Then I guess this solution is not for users like you. I have found this solution quite useful for my use case scenario and so have many of my friends. Like I said before, at the risk of repeating myself -
The convenience of this setup outweighs the inconvenience of a few standard hand movements required to remove it from the cradle
Cheers...
dkaile is offline
Old 20th May 2024, 14:41   #37
Jaguar's Avatar
Cheers...
No need to get personal. Some of us have pointed out a concern based on our personal experiences. You may choose to disregard it but many others would find the info useful.
Jaguar is offline
Old 20th May 2024, 14:58   #38
dkaile's Avatar
It was not personal at all mate nor was that my intention. Of course, once you have placed your opinion on an open forum, members are free to take their decision based on facts. In peak summer months, like it is nowadays, of course the car interiors will get hot. That does not stop manufacturers or users to own cars with big panaromic sunroofs, when even a moving car with ac on, becomes an oven at 45 degree ambient temperature. Does that stop manufacturers from giving the option of sunroofs to people, NO! Even though I am a big opponent of panaromic sunroofs for hot climate countries like India. In the same way, in these 2~3 months of extreme weather, it is advisable to immediately remove the tab when parking the car in peak heat. So either you can adjust your usage style or not use this solution at all, is totally up to you. For anyone, not ready to adjust to this peak heat usage pattern, this solution is not for you! That was my humble submission.
Cheers...
dkaile is offline
Old 23rd May 2024, 10:24   #39
dkaile's Avatar
Testing the Tab at 44 Degrees'C for temperature and battery - 22-05-2024
Had to go on a short leisure trip to Noida and the Tab was well tested in the extreme blistering heat that North Indian summers can throw at you -
Started from home at 10.41am at 34 degree -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520241.jpg
38 degrees at the Expressway. Zero visibility issues -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520242.jpg
Finally by 12 noon, the temperature reached 44 degrees. The car was chilling 24.1 degrees (Auto AC set at 24). Nice fuel efficiency of 11.8kmpl on this trip -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520243.jpg
Tab and Android Auto worked flawlessly with zero lags -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520244.jpg
Finally reached our destination at Noida -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520245.jpg
Safely parked in the underground parking. Left the Tab as it is, no power off -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520246.jpg
Enjoyed at Imax -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520247.jpg
Got some 'Gyan' on Irish diplomacy at the bar -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520248.jpg
Started back home around 6.30pm. Temperature still hovering in high 40's in this long rush hour traffic. Car was chilling at 25~26 degrees with music blaring through Spotify on the car's stereo -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-220520249.jpg
Finally reached home around 8.30pm hearing the 'Cult of Snap'. Ambient Temperature still at 37 degrees. Return FE was 10.5kmpl due to heavy traffic -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-2205202410.jpg
Battery was still at 58% with a full day's usage without charging. It was last charged 12h 47min ago, as is evident in the photo. So I easily foresee a 10 hour screen on time without charging, with this Tab -
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-skoda-superb-tab-testing-44-degrees-2205202411.jpg
Zero issues whatsoever. And really thankful for the increased visibility on this higher screen size than a typical phone.
Cheers...
dkaile is offline   (23) Thanks
Old 24th May 2024, 11:02   #40
maheshm619's Avatar
Thanked: 912 Times
Originally Posted by mayank0782 View Post
I need to pick my phone up every time I want to do something.
Any suggestions would be really helpful.
These products might be useful in your case.
https://www.amazon.in/Portronics-Blu...53&sr=8-7&th=1
https://www.amazon.in/Tantra-Fluke-P...s%2C453&sr=8-2
maheshm619 is offline   (2) Thanks
Old 24th May 2024, 12:23   #41
Thanked: 184 Times
Originally Posted by maheshm619 View Post
I have used both the above but am really happy with the Tantra Fluke ..zero lags doesnt go off or cut off when the car moves over rumbler strips or bad road on the highway ... ( the rumbler strips ...Gosh those approaching into pune from satara highway 48) . Connection to both is seemless also .. but I lean more towards Tantra Fluke.
ToothyPetrohead is offline   (1) Thanks
Old 24th May 2024, 12:40   #42
freakmuzik's Avatar
Thanked: 1,485 Times
Your setup looks incredibly good and I can imagine the relief and comfort you'd be getting from this. I have been looking for a similar solution for my Altis and yours look amazing and am inspired. But, I use an iphone and hence wanted to know are there any apps that support Carplay on an android tablet and where i can simultaneously use bluetooth audio connected to the car audio?
freakmuzik is offline   (2) Thanks
Old 24th May 2024, 13:28   #43
dkaile's Avatar
Kindly see if this video helps you out, though I don't use Apple and have not tried out this solution personally. I believe you need some additional hardware like a Carlinkit CCPA kit (around 7k) to get it going along with Autokit apk app and a OTG usb a to c connector to connect it to the tab & it should work. But then the cost factor could come in play - https://amzn.in/d/ed3HjZU
Kindly go through other YouTube videos of some Indian users also (though I take no responsibility of these videos) -
Cheers...
dkaile is offline   (3) Thanks
Old 24th May 2024, 14:09   #44
Thanked: 2,407 Times
Buddy you didn't really test the tab at 44 degrees. The outside temperature was 44 degree but the tab was always inside where you were maintaining much lower temperatures.
JediKnight is offline   (1) Thanks
Old 24th May 2024, 14:25   #45
dkaile's Avatar
Yeah, right, buddy!
That is the exact usage pattern for the vast majority of car users, at 44 degrees 'ambient' temperature, inside an AC car.
