Old 27th March 2012, 16:13   #9496
coolclouds's Avatar
Thanked: 519 Times
Re: The DSLR Thread
Originally Posted by navan49 View Post
Gone through all the DSLR cameras of Nikon. I could find that none of the SLR is with in my budget range. Thinking of going for a used one. If any of our Teambhp members want to sell I would give the first preference to them. If some one can suggest a reliable website for used goods,
I just PMed you some links since I an not sure if I can share links to third party sites.
coolclouds is offline
Old 27th March 2012, 16:45   #9497
Gandhi's Avatar
Thanked: 209 Times
Re: The DSLR Thread
Need some help folks. A friend owns 550d with 18-55 kit lens and now wants to purchase a telephoto lense. His budget is around 10k and plans to get it via a friend in US. There are couple of lenses available in his budget on Amazon, but he is not sure which one to go for.
Any suggestions?
Gandhi is offline
Old 27th March 2012, 16:55   #9498
HellwratH's Avatar
Thanked: 57 Times
Re: The DSLR Thread
Any suggestions?
In that budget I'd recommend the 55-250IS. I love this lens. It's much better than 75-300mm. If he can afford, ask him to look at 70-300mm IS. He might get a used one for about $350-$400.
HellwratH is offline
Old 27th March 2012, 17:03   #9499
Gandhi's Avatar
Thanked: 209 Times
Re: The DSLR Thread
There are two versions of 55-250 lens. One is IS and other is IS II. What is the difference between the two?
IS II version - Amazon.com: Canon EFS 55-250mm f/4.0-5.6 IS II Telephoto Zoom Lens for Canon Digital SLR Cameras: Electronics
IS version - Amazon.com: Canon EF-S 55-250mm f/4.0-5.6 IS Telephoto Zoom Lens for Canon Digital SLR Cameras: Electronics
Gandhi is offline
Old 27th March 2012, 17:09   #9500
KSM-Vtec's Avatar
Thanked: 447 Times
Re: The DSLR Thread
Guys there is a 16GB SD card offer on Sulekha.com for INR 499
Get Sandisk Memory Card SDHC 16GB - Sulekha Deals
But the only issue is that its a Class 4 card.
My question is - will it work alright on a Canon 500D? or will it slow it down?
Is anybody using a 16gb class 4 card on a Canon?
KSM-Vtec is offline
Old 27th March 2012, 17:13   #9501
HellwratH's Avatar
Thanked: 57 Times
Re: The DSLR Thread
I have not used the IS MKII version, but supposedly it has better IS (gives you more stops). Not sure about it though, a bit of research on google gives me this:
Flickr: Discussing Canon EF-S 55-250 IS II in Canon EF-S 55-250 f4-5.6 IS
EF-S 55-250mm f/4-5.6 IS II VS Canon EF-S 55-250mm f/4.0-5.6 IS ?
Old 27th March 2012, 18:43   #9502
shamik.bose's Avatar
Thanked: 133 Times
Re: The DSLR Thread
Originally Posted by SPARKled View Post
Only AFS lenses will work i.e. AF with these bodies. To make older D lenses or earlier AF lenses work, you need a D90 or D7000 atleast or one of the older D50,D70,D200,D80,D100 or earlier bodies.
AF with the bodies meaning? The lens need to have the AF motor?
shamik.bose is offline
Old 27th March 2012, 19:06   #9503
sachinj12's Avatar
Thanked: 169 Times
Re: The DSLR Thread
As far as I know, the older lens don't have an in-built focus motors. Hence, to autofocus, you need a camera in which the AF motors are in built. The D90, D7000 and higher models have these. The lower bodies don't have an internal focus motor which means the lens will be a manual focus lens.
Others might be able to provide a better explanation. This is the best I could put, sorry.
That is what I thought too. A manual focus lens is fine by me; what I want to know is whether they can be used with the D3100 body
P.S. Thanks
Don't you have the manual with you? I think the manual gives a list of all the compatible lens. Else, google baba is always there
I am guessing the lens will act as a manual one on a D3100.
And, you are welcome, :-)
sachinj12 is offline
Old 27th March 2012, 19:22   #9504
Thanked: 133 Times
Re: The DSLR Thread
Originally Posted by sachinj12 View Post
As far as I know, the older lens don't have an in-built focus motors. Hence, to autofocus, you need a camera in which the AF motors are in built. The D90 and D7000 above have these. The lower bodies don't have an internal focus motor which means the lens will be a manual focus lens.
P.S. Thanks
Old 27th March 2012, 19:35   #9505
SPARKled's Avatar
Thanked: 664 Times
Yes AFS lenses. Lenses with built in motors.
SPARKled is offline
Old 27th March 2012, 19:44   #9506
nilanjanray's Avatar
Thanked: 2,946 Times
Re: The DSLR Thread
In my opinion a 5MP+ cell phone camera does 90% of the job for travel photography, of course as long as the light is right. I have shot tens of thousands of photos with cell phone, mostly for documenting site conditions, and nothing beats the "always available" factor of a phone camera. My latest Nokia Windows phone has an excellent "Macro" capability, hard to beat in a normal DSLR without a macro lense.
+1 to that. Ever since I bought the SGS2, I use its camera for landscape pictures. Always available - in your pocket.
One can avoid changing lenses or can travel with just one lens - usually 70-300mm in my case.
nilanjanray is offline
Old 28th March 2012, 08:27   #9507
vsathyap's Avatar
Thanked: 1,669 Times
Mod Note : Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another!
P.S. Thanks
Are you sure you want to do manual focusing? Believe me, it's not as easy as it sounds... and even if you're off by a bit, your images turn out to be out of focus. If I were you I'd not be risking taking pictures of some unforgettable event/experience/location with a manual focus lens. Sure, over time and practice, you will get it right, but to jump off auto focus and say I'll be fine with manual focus is not something I'd be confident about.
One trick to lower your focusing errors if you go on manual focusing - try and use a small aperture, around f/15 or smaller. This way, you are increasing your depth of field and chances of missing out on focusing are reduced. Similarly, I'd not try manual focusing on a f/1.8 or f/1.4 prime lens with the aperture anything bigger than f/5.6.
Gone through all the DSLR cameras of Nikon. I could find that none of the SLR is with in my budget range. Thinking of going for a used one. If any of our Teambhp members want to sell I would give the first preference to them. If some one can suggest a reliable website for used goods, I would be grateful to them. I realized how much I missed the DSLR during my last tour to the South East Asia. Any how I could manage with my Iphone and the quality was not up to my satisfaction.My preference is Nikon D90 or D48 in reasonable price with good condition.
I have a Nikon D50 with a 18-55mm kit lens. I have another 55-200mm lens and 2 spare batteries (total 3 batteries). I have not yet thought of selling my equipment but I am surely looking at upgrades. If you feel this is something you can try your hands at, PM me and we can take it ahead. Other goodies include UV filters, lens pouches, remote shutter trigger, etc.
Last edited by GTO : 29th March 2012 at 11:48. Reason: Please use the EDIT or MULTI-QUOTE buttons instead of typing one post after another!
vsathyap is offline
Old 28th March 2012, 08:40   #9508
SPARKled's Avatar
Thanked: 664 Times
Re: The DSLR Thread
P.S. Thanks
Yes these lenses will mount and i guess even meter but believe me its not easy as it sounds. Unlike the huge viewfinders of manual focus SLRs, the viewfinders of new consumer SLRs are small and dim so manual focusing is going to be a huge task.
SPARKled is offline
Old 28th March 2012, 10:00   #9509
Thanked: 133 Times
Re: The DSLR Thread
Thank you for your input. I had that I-can-do-anything feeling that newbies have, but looks like it is quite difficult
I checked with my dad, and it turns out that the lens is an AFS one. So manual focusing fears are gone. Now to get my hands on those lenses
Old 28th March 2012, 11:02   #9510
Racer_X's Avatar
Thanked: 117 Times
Re: The DSLR Thread
I am a complete noob at the DSLR thing and have been using a digi cam till date. I am planning to graduate to an DSLR and have a budget of around 50-55k. The brand I have in mind is Canon as my FIL has a Canon & collection of lenses which I can use
I need advice on the model and kit which would be most appropriate for regular travel photography to begin with and one of visits to National parks.
Also please suggest decent camera stores in Pune where I can get a good deal along with freebies if possible.
Racer_X is offline
