Old 1st April 2012, 13:26   #9541
altius's Avatar
Thanked: 104 Times
Re: The DSLR Thread
May be a bit OT with respect to this thread, but I am posting it here to get some advice from the camera experts. I have a Nikon Pronea 6i APS SLR camera, also known as 600i and which is supposedly the APS equivalent of N70 SLR. I have 20 - 60mm and 60 - 200mm IX Nikkor lenses. I have not used the camera for quite a while and planning to get a entry level DSLR. My question to the camera gurus is that if it is possible for lenses can be put to use in a Nikkon DSLR body? Thanks in advance.
Moderators: If this post is completely irrelevant to this thread, please move it to a appropriate thread.
altius is offline
Old 1st April 2012, 14:47   #9542
gd1418's Avatar
Thanked: 729 Times
Re: The DSLR Thread
IX type lenses cannot be used on 35mm film or digital bodies. They were specifically made for the Pronea.
gd1418 is offline
Old 1st April 2012, 18:40   #9543
architect's Avatar
Thanked: 783 Times
Re: The DSLR Thread
Originally Posted by KSM-Vtec View Post
Anyways the imp point i want to make is that the body is a onetime investment so one should not compromise within the available budget. you can always add a lens later.
On the contrary, most really good lenses cost as much or even more than an entry-level body. For people who are starting off on a limited budget, I would suggest buying a used / entry-level body and keep adding good quality lenses. Once you reach a certain level, the lenses can stay and a better body can be bought. That's just my point of view.
architect is offline
Old 1st April 2012, 19:55   #9544
clevermax's Avatar
Thanked: 2,902 Times
Exactly. I upgraded the body keeping my lenses!
clevermax is offline
Old 2nd April 2012, 16:00   #9545
white-rabbit's Avatar
Thanked: 35 Times
Re: The DSLR Thread
Some try with kit lens and 550D.
Please,Comments are welcome,as I am just not satisfied.I know there is a lot to work on.Please point out those for me.
white-rabbit is offline
Old 2nd April 2012, 17:39   #9546
thelightening's Avatar
Re: The DSLR Thread
Originally Posted by govigov View Post
@thelightning. Is that a TTL flash or a non TTL FLash? Never heard of proplus. hence asking.
Its a manual flash, not TTL, but a nice one for the price and wonderful stuff. I am using it now.
thelightening is offline
Old 2nd April 2012, 20:42   #9547
Thanked: 35 Times
Re: The DSLR Thread
Guys,which will be the best cheap Macro lens to start with?
What is this 'MACRO' button on Tamaron 300mm lense?Is it good to buy a Tele lens with macro ability or a Macro lens alone?
Old 2nd April 2012, 21:48   #9548
navan49's Avatar
Thanked: 73 Times
Re: The DSLR Thread
Great Photos. Congrats white rabbit. You did well. There may be some great photographers, who can do wonders. But for my eyes your photos are superb.
navan49 is offline
Old 3rd April 2012, 23:52   #9549
nilanjanray's Avatar
Thanked: 2,946 Times
Re: The DSLR Thread
Would someone know the grey market prices for:
1. D7000
2. D700
Have been eagerly waiting for the D400, but no news of it.
nilanjanray is offline
Old 4th April 2012, 12:38   #9550
motomaverick's Avatar
Thanked: 989 Times
Re: The DSLR Thread
Macro lens are usually of longer focal lenght e.g. 90mm or 100mm but fixed, these are expensive. And inexpensive solution would be a telephoto zoom lens with Macro options. Again you have to see the minimum focusing distance and magnification ratio.
motomaverick is offline
Old 4th April 2012, 12:53   #9551
Thanked: 35 Times
Re: The DSLR Thread
I didnt exactly understand about minimum focal length here.Tamaron says macro functionality from 135MM at 1:2 ratio.What does this exactly means?
Old 4th April 2012, 13:07   #9552
Thanked: 989 Times
Re: The DSLR Thread
Minimum focusing distance is how close you can go towards the subject, since insects are shy creatures it would make sense to get a lens with longer focal length so that you can get a life size magnification from a distance.
A macro lens is classically one lens capable of reproduction ratios greater than 1:1, although it now refers to any lens with a large reproduction ratio, despite rarely exceeding 1:1. The best macro lenses are the latest autofocus mount models, typically in focal lengths ranging from 50 to 200mm. Each lens will focus continuously from infinity to 1:1.
Focal Length
Macro lenses come in a range of focal lengths from 50 mm to 200 mm. The closer you can get to your subject, the smaller focal length you will need. If you are taking pictures of things that might move or fly away (insects) if you get close, you'll want a lens with a longer focal length. Since most macro lenses have a fixed focal length, you will want to make sure to get one that fits your needs.
Depth of Field
As you get closer to your subject, the depth of field will decrease, meaning less of the photograph will be in focus. The depth of field can be increased slightly by increasing the f-stop, but this will decrease the amount of light that is let in.
Read more: What Is a Macro Lens? | eHow.com
Old 4th April 2012, 14:51   #9553
Thanked: 35 Times
Re: The DSLR Thread
Thanks!that helps a lot.
What about this 'Lense reverse technique'?
Old 4th April 2012, 16:01   #9554
Thanked: 989 Times
Re: The DSLR Thread
Thats basically fixing your regular lens lets say 18-55mm in reverse, you get mounts for the same. But the problem with using like that is the lens then gets prone to getting dust inside as you are using the unprotected portion of the lens.
Old 4th April 2012, 16:14   #9555
clevermax's Avatar
Re: The DSLR Thread
A reproduction ratio of 1:1 means the lens is capable of casting an image of the subject in the sensor which is of the same size as that of the subject itself. Imagine how magnified the photo will appear, say for example we are focusing on a big Ant and it fills the entire sensor area of an APS-C sensor.
Super macros are those with a higher magnification than 1:1. That means the image casted on the sensor will be bigger than the actual size of the subject itself.
