Old 14th April 2009, 17:04   #46
Sam Kapasi's Avatar
Thanked: 2,480 Times
Originally Posted by deepug View Post
A question here. Would one require In Wall Speaker wires if the wires are going to be concealed?
Best regards
Deepu
There's no such thing. Just take regular speaker wires and run them in a conduit pipe.
Sam Kapasi is offline
Old 14th April 2009, 17:27   #47
Samurai's Avatar
Thanked: 49,933 Times
Check out the user manual, page 12 of the document.
http://www2.yamaha.co.jp/manual/pdf/...400_e_kai2.pdf
It talks about banana plugs but with an exception for UK, Europe and Asian models. Mine is an Asian model bought in Bangalore.
Samurai is offline
Old 23rd June 2009, 23:21   #48
Samurai's Avatar
Originally Posted by Sam Kapasi View Post
You bought the wrong plugs. Guaranteed. The sizes of the terminals are standardized. Or you're putting it in the wrong hole, lol.
Originally Posted by Bass&Trouble View Post
There should be small plastic caps on the speaker terminals where the banana is to be shoved in. Did you remove those?
And do the banana pins you use have some sort of springy mechanism running along their length? If yes, pushing a bit harder could help.
This time while setting up the home theatre, I decided to take couple of close-up snaps of the connectors, which are clearly not banana plug terminals.
Does anyone still think these are banana plug terminals?
Samurai is offline
Old 24th June 2009, 09:52   #49
navin's Avatar
Thanked: 9,968 Times
Samu can you stuff the banana plug in the hole in the center of the terminal?
navin is offline
Old 10th July 2009, 21:24   #50
mohit's Avatar
Thanked: 168 Times
Curious question: So I got myself a new Home theater (Denon 789 and
Energy C-50 HT Speakers
) and got a 100' spool of 12 AWG speaker cable which is radio shack grade for $10. Would using such thick cable for this setup be a total overkill? My rear speakers would take a 30' run as the wire will have to go along walls and doors.
I am newbie when it comes to this and am still looking at options to get other cable brands.
mohit is offline
Old 10th July 2009, 22:03   #51
naughty001
Posts: n/a
@ Samurai - those are definitely screw on type terminals. My old Pioneer A400x from around 15 years back had something like that. they will not accept banana plugs in any form or shape, nor will you be able to use any type of spade termination, all you can do is to use bare wire there unfortunately
Old 13th July 2009, 06:48   #52
mohit's Avatar
Thanked: 168 Times
A bump and a rephrase: I can't get any 14 or 16 AWG thats of better quality. Is there any harm in using a thicker gauge cable?
mohit is offline
