Old 4th January 2019, 20:09   #766
CrAzY dRiVeR's Avatar
Thanked: 73,505 Times
re: A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold
Thanks guys for helping, and sorry for my delay. One BHPian also whatsapped me to check if the new alternator is overcharging, incase the fuses are blown.
Here's the scenario -
Checked the voltages to eliminate the last and biggest (budget terms) possibility of alternator or voltage regulator issues.
Battery voltage before tests with engine switched off - 13.13V.
Battery voltage with engine idling - 14.54V.
Battery voltage with engine revved between 1k to 4k rpm slowly - 14.6V maximum.
I think alternator issues can be ruled out. Next up -fuse.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190104_1624142.jpg
The top right most one and the one below it are the headlamp low beam fuses, as per the owners manual - both look fine.
Couldn't check relay fuse and bulbs as my hands struggle for space inside the engine bay. Will check it over the weekend. I suspect it might just be blown bulbs like Arun's case, but since both the beams died at the same moment - don't want to leave a bigger risk unattended.
Originally Posted by nkrishnap View Post
It could be the fuse too. Do check the fuses with the relay wiring kit, both low beams conking together is rare.
Relay kit was done by expert hands , and is safely hidden inside. Will need to check it properly during weekend. Thank you.
Originally Posted by arun_josie View Post
I had faced this same issue too, both low beam conked off simultaneously. In my case it was not the relay kit, just bad luck.
Thank you.
Osram, by any chance? If i remember right - Two times earlier I tried Osram - didn't last much too. Or may be - Amazon sent me fake ones, despite selecting CloudTail India as the seller.
Try this CD.
From the relay kit you will notice 2 30A Fuses. Swap them and then see if Low beams work and high don't. If so, it's the fuse. Buy it and install it yourself.
Couldn't check this today. Will update during the weekend. Thank you.
Originally Posted by gururajrv View Post
I’m a new dad in town and up until wee hours usually.
Congratulations!
Why don’t you go for a retro projector installation which should be a better add on to your car if you travel in the night? Just a suggestion.
Thank you for the kind words. Regarding projectors - Punto is unlikely to see any modifications now, except ensuring proper maintenance.
Reason is that highway, weekend fun etc has been moved to this member of the garage now - https://www.team-bhp.com/forum/super...sys-650-a.html
Main usage for the car is now for office (~35 kms daily), weekend drives inside city whenever wife joins (~100 kms from one end of Bangalore to the other and back on weekends).
CrAzY dRiVeR is offline   (5) Thanks
Old 5th January 2019, 15:05   #767
arun_josie's Avatar
Thanked: 13,535 Times
Yes, it was Osram Night Breaker Plus. I think it lasted for just 3 months.
arun_josie is online now
Old 5th January 2019, 15:21   #768
nkrishnap's Avatar
Thanked: 7,407 Times
Need to check the headlight housing, if there are any vibrations it will conk. I have the same bulbs for over a couple of years now and most of the times the car runs only at night.
Do check for vibrations in the headlight unit.
nkrishnap is offline   (1) Thanks
Old 14th January 2019, 23:12   #769
Tornado's Avatar
Thanked: 38 Times
Hello BHPians,
I bought a Punto which had 33k on the odo few months back. ( this is my 6th car from fiat family. I had a Padmini, 118NE, Palio 1.9, Palio MJD & Uno). I am looking for an after market front break shoes. Does anyone has any good experience besides the OE one?
My friend who has a Punto MJD used local brand once and currently using TVS but he is not happy with performance when compared to the OE break pads. Any suggestions? How is Delphi’s ? It seems as cheaper as 1350 where as OE is around 3.7K . I doubt whether Delphi manufactures break pads for Punto.
Last edited by ampere : 15th January 2019 at 10:31. Reason: post formatted for readability
Tornado is offline
Old 16th January 2019, 08:07   #770
But why?
Isn't it better to source the original ones from 99rpm instead?
Old 16th January 2019, 08:29   #771
Tornado's Avatar
Thanked: 38 Times
I had bad experience with 99rpm.
once ordered single front wheel bearing for my Punto. I ordered the one for ABS variant. After fitting the bearing ABS sensor error was showing up, then we realised it was non- ABS wheel bearing ( the ABS one has a magnetic ring around it ) . I complained but there was no good result and I lost my money- Rs 2100 . Later I got 2 bearings from local shop at Kochi for 900 each ( ABs version),which was fitted perfectly . It’s working great.
Tornado is offline
Old 18th January 2019, 08:06   #772
True. Their customer service is extremely poor - if something goes wrong, they just don't care.
Old 24th January 2019, 20:40   #773
Some random pics. Didn't take these pics to share on the thread, just casually took a couple of days back because I was happy with the gloss on the car -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190122_223548_959.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190124_202005_968.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190123_090656.jpg
Realized last week that the interiors were professionally detailed 1 lakh kms ago, and it surely has started to show this age. Decided it give a shot myself before getting any professional work done. Time to scrub some clean microfibers dirty. Product bought -
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-screenshot_20190124202538.png
CrAzY dRiVeR is offline   (4) Thanks
Old 4th February 2019, 16:28   #774
Tornado's Avatar
Thanked: 38 Times
Fitted Valeo’s swift diesel clutch and release bearing of Indica vista quadrajet to Punto MJD (75bhp). When I compared the new ones with OE parts taken out , those were exactly the same make.
After the clutch change , it’s more than 7500km , it’s absolutely fine .
I replaced the front break pads with motherson pads. When I researched I cloud see that motherson has partnership with Magneti Marelli. But breakpads might not be a part of the jv. I feel that the bite is bit slower as I need to press the pedal bit more to get strong bite when compared to the OE. I think it’s better to stick with OE or performance break pads.
Atleast you will have a psychological effect of safety feeling
Last edited by moralfibre : 11th February 2019 at 09:54. Reason: Back to back posts.
Tornado is offline   (2) Thanks
Old 9th February 2019, 01:09   #775
Finally got time to clean the interiors properly today. Needed a little more than half bottle of the Sonax Interior Cleaner mentioned above.
Front Passenger Seat - Before. Accidentally kept a packet on the seat while trying to move my bag to make space for the cover on the floormat, but didn't notice the oil stain it made on the seat in just a few seconds.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_091501_1600.jpg
Front Passenger Seat - After
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_092848_1600.jpg
Co-driver seat backside - Before
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_092038_1600.jpg
Co-driver seat backside - After
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_092412_1600.jpg
Rear bench - Before
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_092946_1600.jpg
Reach bench - After. though some portions are yet to dry properly.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_093228_1600.jpg
Driver's seat - After Yet to dry, as evident in the picture.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_095332_1600.jpg
Doorpads - Cleaning in progress.
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_094940_1600.jpg
End result (Fabric cleaning only).
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_095220_1600.jpg
Closer look at the fabric
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_095032_1600.jpg
Now that the fabric looks fresh, the plastics feel out of place. Time for Meguiar's Natural Shine treatment. Meanwhile, could not resist clicking these two random pics on the way back home from office, the second one being as random as it can get - cause it's just clicked when I was having a cup of tea in the opposite shop!
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_210226_800.jpg
A thin line between genius and insanity - Fiat Grande Punto 90HP - 2,00,000 km up! Edit: Sold-img_20190208_213853_800.jpg
CrAzY dRiVeR is offline   (10) Thanks
Old 9th February 2019, 09:50   #776
Any suggestions on what would be the resale value of the car now? FIAT, 7 years, 1.74L kms since purchase?
There are a couple of my friends who appreciate how painstakingly the car has been maintained, and I already have a request from one if he could purchase the car as the backup vehicle at home.
PS: I know the value will be pathetic, just can't figure out what is realistic and fair since it can't be Rs 0.00/-
Online sites like Cars24 are not helpful since they club all cars above 1L kms usage into one bracket - and the value they qoute is roughly 2.5L before inspections - which I don't think is realistic.
Old 9th February 2019, 11:51   #777
Geo_Ipe's Avatar
Thanked: 2,904 Times
The things in bold are the only things buyers are going to point out when negotiating! Also, news that Fiat is going to shut shop will not be helping you much.
2.5 lac looks like a good deal to me at first glance. Try to find a fellow enthusiast if you're Keen on selling. I'd recommend you keep it as a second car, provided parking space is not an issue.
Geo_Ipe is offline   (1) Thanks
Old 9th February 2019, 11:59   #778
Just to clarify - I meant 2.5L is way unrealistic on the higher side, not lower.
Their online estimates only have one option - greated than 1L kms, but the mental barrier between 1L kms and 1.75L kms is huge. And like you said, the news of FIAT's future isn't going to help either.
Can only explore the Cars24 option only when I'm ready to handover the vehicle - but just wanted to get a couple of suggestions on what's a realistic price before that.
Old 9th February 2019, 14:48   #779
ashis89's Avatar
Thanked: 11,001 Times
For a well maintained car like yours, I would say 2L is a fair price. This is after considering Fiat and high running. The arguments in favour are a thoroughly maintained and fully loaded car.
ashis89 is offline   (1) Thanks
Old 9th February 2019, 23:51   #780
fully loaded car.
Time flies so fast. Fully loaded in 2012, is barebones in 2019.
Even something as simple as rear parking sensors were only available in the i20 Asta back then, IIRC.
