Old 6th July 2013, 23:29   #76
Fortuner71's Avatar
Thanked: 345 Times
11K Kms and no issues . Got a call from Tata motors as well as the dealer . The front suspension springs were replaced under warranty . On enquiry they said its a proactive measure as they had complaints of some oil leakage in some storme's . Overall the beast is running well with 4x4 being used every weekend . Attaching 2 pics of the beast
Fortuner71 is offline   (8) Thanks
Old 7th August 2013, 22:00   #77
Fortuner71's Avatar
Thanked: 345 Times
13k and beast is performing well . Fixing hella 3003 next week to aid night highway runs .
Fortuner71 is offline   (11) Thanks
Old 8th August 2013, 07:51   #78
kaviprem's Avatar
Thanked: 975 Times
Re: Windy, Cloudy & Finally a Storme
What beach is this ? Storme and Shore go well
kaviprem is offline   (1) Thanks
Old 8th August 2013, 08:31   #79
ajay_satpute's Avatar
Thanked: 1,711 Times
Your Storme is looking is really good. Glad to hear that you have not faced any issues. The front suspension spring replacement is a secret recall or what? Are they doing this for all Stormes or certain batch?
Looks like you realized that you should add the 'got bBHP?' sticker between the 11k and 13k readings. Don't worry, the stickers are only enhancing the beauty much more.
Wishing you many more happy miles.
Cheers!
ajay_satpute is offline   (1) Thanks
Old 8th August 2013, 10:15   #80
Fortuner71's Avatar
Thanked: 345 Times
KRS back waters , I go there everyweekend almost to give my GSD a swim .
Old 8th August 2013, 10:19   #81
Fortuner71's Avatar
Thanked: 345 Times
Cheers!
Thanks . I was told that all initial batch of storme's have been re-called for replacement of the front suspension springs. This seems to be proactive measure after they found leaks in some of them .
Old 8th August 2013, 10:30   #82
Thanked: 2,816 Times
A leak in the spring??
Also, can you please post pictures of your gear knob in its current condition? I have seen the gear knobs of the Storme losing their beige cover on all test drive cars and hence want to take a second look at yours.
Finally, thank you for maintaining the most up to date Storme ownership thread on TBHP.
n.devdath is offline
Old 8th August 2013, 10:35   #83
tsk1979's Avatar
Thanked: 23,484 Times
Planning to dispose off your storme in 2-3 years? If not, make sure you clean underbody after every outing. Salt water and cars do not mix very well.
Even with underbody rust treatment, if you venture into sea water, make sure underbody gets a thorough wash
tsk1979 is offline   (2) Thanks
Old 8th August 2013, 10:56   #84
Fortuner71's Avatar
Thanked: 345 Times
TSK thanks this is not salt water . Its the cauvery river. I get the under body cleaned atleast once in 2 months .
Old 8th August 2013, 11:09   #85
tsk1979's Avatar
I thought it was some beach. That said, how clean is the river. Are there industries upstream? If so, then go for an underbody wash (even if not fully thorough) after every dip.
Also, open your tailgate, and spray WD40 or apply grease along the lower edge. Tata metal edges rust fast. Appying spray every 15 days will ensure long life.
Old 8th August 2013, 11:13   #86
ampere's Avatar
Thanked: 13,612 Times
Its natural territory of KRS Dam in Mysore. Dont think there are any industries.
Some how strangely for the dam waters here, they are referred as back waters. A term which is mainly used for sea waters.
@Fortuner71
Nice to see Cauvery full. Some thing which we only see once in a while!
ampere is offline
Old 8th August 2013, 11:15   #87
Fortuner71's Avatar
Thanked: 345 Times
Thanks TSK , yes will do as adviced. River is pretty clean and these waters are the backwaters from the dam .
Old 17th August 2013, 13:29   #88
Fortuner71's Avatar
Thanked: 345 Times
Hella 3003 installed . 14 k done beast doing well
Fortuner71 is offline   (6) Thanks
Old 17th August 2013, 14:58   #89
Blow Horn Ok's Avatar
Thanked: 996 Times
The beast looks even more majestic. How did you mount the brackets for the lamps and installed the switch? Was any drilling or cutting required in the bumper and dash board? Please share some installation pics if you have.
Blow Horn Ok is offline
Old 17th August 2013, 15:06   #90
Fortuner71's Avatar
Thanked: 345 Times
No cutting involved will send you pics very solid and no shake whatsoever 😃
Fortuner71 is offline   (1) Thanks
