Re: Petrolhead turns dieselhead - BNW Fiat Grande Punto Emotion comes home. EDIT: 62K km done in 5 y Last weekend, the following jobs were done on the Punto:
1) Replaced the faulty link rods (left & right)
2) Replaced the Brake pad set. the car had run only 29k kms since last change at 36k kms. I guess the bad roads, bumper to bumper traffic during the last monsoon was the major reason for the same.
3) Steering wheel buttons were serviced as there was some issue in operating the same
4) There was coolant leakage from the EGR assembly which had reduced the level in the coolant tank to less than the min mark. The EGR assy was removed, some hoses were found to be very stiff which were replaced. The metal pipe section had seen severe corrosion but due to part unavailability was serviced and put back. Coolant tank was topped up, will need to closely monitor the coolant level.
5) There was some malfunction in the right side turn indicator which was serviced.
6) There was a play in the rear seat mounting which was loose in the clip which holds the seat firmly. The seat section was covered with some tape to ensure a snug fit.
7) The LH Ac vent was damaged during the latest detailing, this will need replacement. |
