Hi All,
I have a 2004 TATA SAFARI TCIC.
This is my first post in the forum, and I think it may be useful to somebody.
I have collected this information from Team-BHP and other sources and my experience. If any mistakes, feel free to correct me.
Every 10-20,000 kms
Oil Filter-Long Turbo: (10,000 kms): 157
Air filter: 380
Fuel filter (MICO – Diesel Element Felt Type): 135*2 = 270
Wheel Alignment, Balancing & Rotation (10,000 kms): 375 - 500
Engine Oil (Mobil 1 Delvac MX Multigrade) (10,000 kms): 1440
Wiper Blades: (Change to Bosch) – 200 per Blade (total 3 blades)
Car Electricity Checkup: 500
Car Wash (10,000 kms): 300-350
Labour: 1000 - 2000
Every 30-40,000 kms
Engine COOLANT Fill: 1800 (Topup/One Ltr with Water: 240)
Power steering fluid (30,000 kms):
Transmission Oil (30,000 kms):
GearBox / differential oil (30,000 kms):
Brake line bleeding and fluid topup (30,000 kms): 128 + 250(labour)
Clean Throttle body & chambers inside the TB (30,000 kms): 300
Check PCV valve.
Check valve clearance and adjustment
Check ignition timing.
Check brake pads. Replace if necessary. Brake Pads (front set): 1784
Front Brake Disc Fading + Brake pad install: 750
Check distributor cap, roter and ignition wiring.
Fuel injectors Cleaning - Rs. 1000
Fuel pump and Filter cleaning: Rs. 600
CLEAN CATALYTIC CONVERTER: 100
Check and Clean Spark plugs:
Specials (if necessary):
Timing Belt: 998
Timing Tens Ball Bearing (SKF 6203) – 4*135 - 540
Timing Tens Ball Bearing (SKF 6204) – 2*175 - 350
Timing Belt Cover: 340
Power Steering Belt: 210
Battery Alternator Belt: 183
BRAKE Pad Set: 992
Accelerator Cable: 124
Glow Plug: 396
Fan Belt: 1113
Car Polishing: 500
A/C gas recharging: 2000
A/C compressor OIL Change & A/C coil cleaning: 500
A/C Belt – 110 / 280
A/C Idler – 957
Change all hose pipes:
Cylinder Head Gasket - 2353
B Mounting – 192
Pressure Plate - 2251
Ball Joint Lower – 587
Ball Joint Upper – 405
Cross Link – 2493
Combination Switch - 750
Front Shock Absorber – 832
Rear Shock Absorber – 1076
Head Light Assembly – 2500
Radiator cleaning.-200rs
Engine Flushout. - 400 rs
Gearbox flushout. - 400 rs
Exhaust system cleaning.- 350 rs
Fog Lamps Bulbs H3 – 2*38 = 76
Power Window Regulator CAMCO w/o Motor – 1250
Decarbonozation/Engine Flushing - 2000/-
Tata Reconditioned Engines (483 TC Short Block) / engine overhauling 38683 (on exchange)
Safari TC Bare Engine 28668
Brake Booster & TMC Assembly: 11500 (Rs. 6500 in TVS, Same BrakesIndia Booster)
Imported Clutch Plate & Assembly - 6000
Suspension O/H 35-40,000km
Labour: 1250
Bush set: 800/set (5000 TOTAL)
Brake O/H 40-50,000km
Labour : 3000
Brake pads: 785/set
Brake shoes: 280/set
Master cylinder kit: 306
Caliper kit: 533
Wheel cylinder kit: 86
Brake disc:
Steering O/H 80,000km+
Labour : 2000
Drag link: 1347
Ball joints: 2070/set
Tie-rod ends: 1062/set
Clutch overhaul: 60,000km
Labour : 2000
Clutch Cover assembly/Pressure Plate: 3080
Clutch Plate/Disc: 3696
Release bearing: 750
Clutch master cylinder kit: 265
Wheel bearings
Labour : 1000
Front Inner – 2*329=658
Front Ourer = 2*376=752
Rear: 480/set
Correct me, if I am wrong
*bump*
Great information here ibm_jennifer.
cya
R
Thanks Rehaan & Team-Bhp.
I still looking for the comments/corrections from other Safari TCIC owners as this information may have some mistakes...
Whew..... Where was thread hidden ???
Useful Info for TCIC Safari Owners !!
Now someone needs to update about 2.2L's!
I hope all 2.2s are under Company warranty here!
Good to see this.. Can you tell whether yours is still under warranty?
Also is labour not free under warranty?
Wow, didn't know that this thread existed. Great info there Jennifer.
Any idea how much a rear spoiler will cost (painting included) for the TCIC Safari?
How did you spoil that?
Ok, here are some price list for the SAFARI DICOR:
TATA Safari Dicor:
air filter 421
oil filter 182
fuel filter 6434
wiper blads 210
timing belt 991
fan belt 572
front brake pads 1396
A/C evaporator coil 4183
radiator hose set 640
front strut/shock absorber 832
front brake disc 1283
front suspension lower arm 3291
clutch & pressure plate 7524
clutch release bearing 1422
front bumper 10,161
wheel rim (each) 2136
front fender 2703
bonnet 8409
radiator 12,363
front door 16,901
tailgate 14,249
headlight assembly (each) 3,535
tail light assembly (each) 776
front windscreen glass 5310
side mirror with casing 3634
Here is the version 2.0 of my List.
TATA SAFARI - SERVICE PRICE Ver 2.0
Every 10-20,000 kms
Air filter: 380
Oil Filter-Long Turbo OEM: 157
Engine Oil (Mobil 1 Delvac MX Multigrade) (7.7 ltr): 1440
Fuel filters (MICO – Diesel Element Felt Type): 135*2 = 270
Wheel Alignment, Balancing & Rotation (10,000 kms): Rs. 375
Every 30-40,000 kms
Change Engine COOLANT: Rs. 1800 (Rs. 240 if One Ltr Wurth(?) mixed with RO Water)
Topup/Change Power steering fluid (30,000 kms):
Change Transfer case Oil (40,000 kms):
Change GearBox Oil (40,000 kms):
Change AXLE Oil (40,000 kms):
Replace Brake Pads (front set): 1784
Front Brake Disc Fading + Brake pad install labor: 750
Check and Clean/Change Spark plugs (40,000 kms): Rs. 300 - 1200
Check PCV valve.
Timing Belt (1,00,000 kms):: 915 (Gates India GD100)
Fan Belt: 1113
BRAKE Pad Set: 992
Glow Plug: 396
Car Polishing: 500
A/C gas recharging: 600 (2*750mg HAMMA R134a)
A/C Overhaul, compressor OIL Change & Gas fill labor: 2000
A/C Evaporator Cooling Coil Change: Rs. 4200 (SUBROS) Rs. 2450 in Cool Sales, Chennai
A/C Gas Hose Pipe/High Pressure : Rs. 1100
A/C Idler – 957
A/C Compressor Pulley: 440
A/C Compressor Clutch: 5700
A/C Switch Controls(HVAC): 3300 for LX, Rs. 5500 for EX
HVAC Unit (front): 12,200 (SUBROS)
HVAC Unit (2 Ton Roof): 12,700 (SUBROS)
A/C Compressor: 27,000
A/C Condenser: 9200
A/C Blower Fan: 650
B Mounting – 192
Cross Link – 2493
Power Window Regulator CAMCO with Motor – 2450
Radiator Flush – Rs. 200 (Rs. 500 for Tectaloy)
Engine(Oil) Flushout. – Rs. 759 (BG 105)
Gearbox flushout. – Rs. 400
Exhaust system & CATALYTIC CONVERTER cleaning - Rs. 350
Fuel Injectors Cleaning – Rs. 500
Fuel pump cleaning and Filter Change: Rs. 600
Soft Decarbonozation - 1450/- (Bardahl S1&S2/ includes Carbon Cleaning & Injector cleaning)
Hard Decarbonozation - 2278/- (BG 244/includes Carbon Cleaning, Injector cleaning, Fuel system cleaning)
Safari TC Bare Engine (on exchange): 28668
TATA Safari New Engine with Starter Motor & Clutch: Rs. 1, 68, 500
Safari TC New Bare Engine: Rs. 1, 07, 700
TARA SAFARI Complete Body Shell: 1, 80, 000
Half Block: 61,000
Cylinder Crankcase: 25,000
Distributor Pump: 43,000 (Mico)
Intercooler: 12,695
TurboCharger: 24,000
Alternator 3SA45 - 135A: 16,700 (LUCAS)
Starter Motor: 9000 (Lucas)
Radiator: 6373
Engine Cooling Fan with DC Motor: 4259
Fan Pulley: 445
Catalytic Converter: 14,470
Silencer with Exhaust Pipe: 1500
Power Steering Gear Box – RHD: 19,000 (ZF) or 17,000 (Rane)
Power Steering Pump 80 Bar: 11,300 (ZF) or 8600 (Rane)
Fuel Filter: 2051 (MICO – Not the element)
Fuel Tank: 2860
Water Pump: 1000
Oil Pump: 1300
Oil Cooler: 1800
Front Windshield: 7500
Rear Glass: 1100(LX) 2200 (EX with Demister)
Door Glass: 900
Side Window Glass: 680
Dashboard: 28,000
Front Door: 12,500
Rear Door: 10,500
Tail Door: 8600
OVRM: Rs. 2200 (each)
Roof Rail: Rs. 1000 (each)
Brake Booster & TMC Assembly: Rs. 11,500 (Rs. 6,500 in TVS/Same OEM Product)
Front Shock Absorber: Rs. 900/each
Shock Absorber Upper Wishbone: 2878/each
Shock Absorber Lower Wishbone: 3828/each
Rear Suspension Spring: 846
Rear Shock Absorber: Rs. 912 (cabriel)
SAFARI Switch Kit (All dashboard switches): Rs. 847
TATA Safari TCIC Complete Wiring Kit: For LX: Rs. 15,000 and for EX: Rs. 21,000
Clutch Plate & Assembly (Imported/Korian) – Rs. 6000
OEM Clutch Plate & Assembly – Rs. 4300 + 3200
Fog Lamp Assembly: Rs. 388/each
Head lamp Assembly: Rs. 2100+230/each
Spoiler Stop Lamp: Rs. 1430
Rear Cluster Lamp (taillight/stoplight): Rs. 630/each
Front Bumper: 9999
Front Grill: 600
Bonnet: 6100
A/C Compressor: 27,000 ? - Is this true :Shockked:
Thats a second hand Maruti cost incase, we need to replace.
Has anybody have an idea, how long this lasts on Safari ................ I need to sell it off befor the deadline :uncontrol
Im sure a brand new safari AC compressor can be found for 1/2 or 1/3rd the cost mentioned in the list above.
I am 100% sure, the SUBROS A/C Compressor(Model No. 10PA17C, TATA Part No: 2699 8340 01 09) cost you Rs. 27,477 where DELPHI A/C Compressor cost you Rs. 20,000
But you can buy a reconditioned/new A/C Compressor from TATA around 5k-10k on "EXCHANGE"
But remember, the above price is TATA Price.
I can still help you to buy a BRAND NEW SUBROS A/C Compressor(Model No. 10PA17C, TATA Part No: 2699 8340 01 09) directly from SUBROS for Rs. 18,000.
And note that I too can help you buy a LOCAL Brand (new) 173cc TATA Safari Compressor for Rs. 9000
