Old 5th August 2014, 00:28   #121
khoj's Avatar
Thanked: 1,287 Times
re: Suzuki Baleno it is! EDIT : Now beyond 163,000 km!
I have heard of NTN/NBK, but NMK is new, to me atleast. Suggest you do a second check including at the local MSM, a big gap it is between 3750 & 500.
Originally Posted by wanderernomad View Post
they are NMK Make and are MGP. Anyone has any idea or experience of using them?
Last edited by Samurai : 25th November 2018 at 11:03. Reason: Please stick to English
khoj is offline
Old 21st February 2015, 22:23   #122
wanderernomad's Avatar
Thanked: 1,276 Times
The original clutch was changed on 27 Jan 2015 with the odometer reading 128640 kms. The change was done at the bosh workshop at Gurgaon. MASS quoted 12000 while the bosh guys did it for about 9000 inr.
wanderernomad is offline   (1) Thanks
Old 31st March 2015, 18:35   #123
Hello Peeps ! i want to get my Baleno dented & painted by a good workshop !
I live in Delhi/NCR, Please help me find a good one !
Dev-Gun is offline
Old 31st March 2015, 23:23   #124
khoj's Avatar
Refer the NCR directory, it s a treasure trove of information. One only has to explore the forum extensively.
khoj is offline
Old 4th September 2015, 13:02   #125
The car is going smooth and had the treads changed to Michellin XM2+ @ 4750 each 185/65/14 at an odo reading of 1,52,000 kms. rest all is well though the leakage in the steering rack is still not got corrected and needs to be regularly topped with the steering fluid. About 100 ml is used every 5000 kms or so.
Edit: Mods to please edit the title to now beyond 1.5 K kms.
wanderernomad is offline   (3) Thanks
Old 31st March 2016, 17:34   #126
The steering leak was addressed at BOSH service centre in Gurgaon but now the khat khat sound from the steering has become more pronounced plus it has become hard as well. What could be the reason? The odo about a fortnight back.
Suzuki Baleno it is! EDIT : Now beyond 275,000 km!-img_20160319_190708180.jpg
Old 31st March 2016, 22:45   #127
Mr.Boss's Avatar
Thanked: 7,464 Times
Steering tight : One reason could be over tightening of rack play adjustment nut at the back side of rack assembly. This is usually done my mechanics whenever steering noise is reported. Other reason could be blocked piping, I came across a similar case in Ikon where the metal tubes were bent when removing the steering gear and after changing the pipe steering effort reduced drastically.
Mr.Boss is offline   (1) Thanks
Old 21st August 2017, 17:37   #128
antlerroad's Avatar
Thanked: 48 Times
Spoke to Ishaan and he recommended Mahajan Autos at Lajpat Nagar. Checked with them and he quoted Rs 500 each. Checked back with Ishaan who assured of the genuineness and picked up the bearings, they are NMK Make and are MGP. Anyone has any idea or experience of using them?
I was not aware that NMK make is MGP. I recently changed the wheel bearing, the original Made in Japan to NMK.
By the way, it is performing good. Will have to wait and see
Suzuki Baleno it is! EDIT : Now beyond 275,000 km!-j1.jpg
Suzuki Baleno it is! EDIT : Now beyond 275,000 km!-j2.jpg
antlerroad is offline   (1) Thanks
Old 24th November 2018, 20:58   #129
Re: Suzuki Baleno it is! EDIT : Now beyond 163,000 km!
The Baleno is now at 2,35,000 KMs and still going strong. Has accumulated a few dents and nicks on the exterior so debating if its worth giving her a respray at this stage.
wanderernomad is offline   (5) Thanks
Old 5th January 2021, 11:33   #130
Tgo
Tgo's Avatar
Thanked: 3,789 Times
Would love to hear what happened next? Is the car still with you?
Tgo is offline
Old 8th January 2021, 12:36   #131
Yes mate still with us and going strong. Though now and with the lockdown the running has not been much and is at 245000 only.
wanderernomad is offline   (4) Thanks
Old 8th January 2021, 19:13   #132
supremeBaleno's Avatar
Thanked: 2,699 Times
2.5lakh kms & going strong. Awesome.
The original clutch was changed on 27 Jan 2015 with the odometer reading 128640 kms. MASS quoted 12000 while the bosh guys did it for about 9000 inr.
My 15.5 years old & 1.1lakh kms run Baleno still has the original clutch and no sign of needing a replacement anytime soon. Helps that no one else drives it but me.
supremeBaleno is offline   (1) Thanks
Old 8th January 2021, 19:29   #133
balenoed_'s Avatar
Thanked: 5,358 Times
... is at 245000 only.
The highest ODO of a Baleno that I so far knew of was of mine only - 1.7L kms. Glad to see there is someone way ahead.
balenoed_ is offline   (2) Thanks
Old 2nd February 2021, 17:31   #134
re: Suzuki Baleno it is! EDIT : Now beyond 275,000 km!
My reading is 2,77,*** now. The car has come to me now a days and will post a picture of the Odo soon.
Old 17th February 2021, 10:41   #135
The current reading in the Baleno stands at 277,143 Kms. Planning to give the old girl a thorough overhaul soon to bring it up to the mark. A few glitches, aesthetic ones, need to be sorted out.
Suzuki Baleno it is! EDIT : Now beyond 275,000 km!-whatsapp-image-20210217-10.36.13.jpeg
wanderernomad is offline   (8) Thanks
