Old 27th April 2006, 12:12   #1
diven_b's Avatar
short shifter for my corolla
hey guys,
i needed some info on short shifters....i needed it for my corolla.
where can i get in bombay?how much does it cost?how much time does installation take? and is it really worth putting it??
diven_b is offline
Old 27th April 2006, 12:47   #2
Thanked: 9 Times
Try this link.
http://www.twmperformance.com/shorts...rtshifters.htm
2L8uLoose is offline
Old 27th April 2006, 13:37   #3
khanak's Avatar
Thanked: 370 Times
whts a short shifter?
khanak is offline
Old 27th April 2006, 13:53   #4
ghostrider4385's Avatar
Thanked: 12 Times
It's a gear stick that's about an inch shorter than your OE stick. Shorter the stick, lesser is the distance to throw the stick into which ever gear, hence better is the reaction. It's only meant for the supposedly hardcore racing drivers.
Godspeed.
Alok.
ghostrider4385 is offline
Old 27th April 2006, 14:06   #5
Thanked: 19 Times
Will a short shifter fix the notchy gearing problems in Optra, or does that require a whole new gearbox?
Boom Shiva is offline
Old 27th April 2006, 14:15   #6
diven_b's Avatar
hey boom shiva,
even the corolla got notchy gearing,and i dont know if a short shifter will take care of that,but i sure to hope so.but shorter & quicker shifts is all i care about
diven_b is offline
Old 27th April 2006, 21:04   #7
Hi Guys,
I saw traffic coming to our site from this thread so I thought I'd stop in and hopefully answer your questions. Here's a quote from our site explaining what a short shifter is:
The geometry of a short shifter differs from the stock shifter in order to reduce the distance that the upper section where your shift knob threads on needs to move to achieve the same degree of movement in the lower section where the shift rod or shifter cables attach. This ensures that although your hand is moving a shorter distance, the transmission is still fully engaged in every gear. The main pivot point, or fulcrum of the shifter lever is re-positioned on the shaft in such a way that the lower section which connects to the shift rod or shifter cables is longer than stock, resulting in the desired effect. A TWM short shifter is carefully designed to create the optimal throw length, angular shift throw, and shift knob height resulting in the ultimate short shifter.
Here's the link with diagrams actually explaining the above paragraph graphically: What is a short shifter?
I hope this helps!
Thanks,
Kevin
TWM Performance
TWM Perfomance is offline
Old 27th April 2006, 22:31   #8
autopsyche's Avatar
Thanked: 36 Times
Thanks Kevin, that was some good information for a lot of us here. Im sure a lot of professionals on this forum can source some stuff from you.
Cheers,
Arush
www.autopsyche.com
autopsyche is offline
Old 12th August 2011, 16:36   #9
kolimuttai's Avatar
Re: short shifter for my corolla
Hello, Sorry about digging up this old post, thanks to TBHP's search (really nice).
I am thinking of getting a twm short shifter for my 2003, 1.5L petrol lancer.
here it is : Mitsubishi Lancer Short Shifter - TWM Performance Lancer Short Shifters
I wanted to know if some one tried it here in India and how does it work with respect to our day to day usage.
~Koliappan.
kolimuttai is offline
