Re: Wax, Sealant or Both? Quote:
[*]Is it to be layered over the liquid wax?[*]Is it to be applied on a wet/damp/dry panel?[*]Is it safe to use on matt black plastic parts?[*]Is there a better alternative?
[*] Since this is a sealant you'll need to use it first and then use any wax coating as a topper.
[*] You cannot use it as a drying aid. You'll need to dry the surface before using it.
[*] It can be used on plastic parts.
[*] I've recently purchased this product and didn't like the gloss after using it(maybe all sealants behave this way). The USP of this product is the ease of application. I've used it only once and will update the longevity of the product later.
Lastly, what decision did you take for this product? Are you still using wax coating on your car? |
