One of my friend has already plonked the M1000 engine in the M800. It was a very torquey car with loads of low-end. Would make the car a lot peppier.
Whats more sensible is to put a esteem engine as the dimensions of the zen engine is the same as the esteem engine.
Else, you could save all the engine swap trouble by getting the 12v head of the alto/m800 5 speed on the current bottom. you will however need to change the piston. You can either run FI or a carb. It will sure be a fun car. Thats a 45bhp set-up. |
