Old 25th January 2009, 00:44   #1
Thanked: 82 Times
Honda Type 1 City - ECU pinout info needed
I'm trying to put together a tuning solution for my friend who is located in mysore. The vehicle is a 1.5L Type 1 Honda City (1998 I believe).
We will go with either a megasquirt or a chipped stock honda ECU.
I'm sure someone here has played around with the stock ECU. I'd appreciate a pinout diagram or at least a picture of what the ECU looks like so I can google the part number.
ananthkamath is offline
Old 25th January 2009, 00:50   #2
Ford Rocam's Avatar
Thanked: 23 Times
Its OBD2B, with conversion harness to OBD1 will give lot of options viz chrome/Hondata which i think you must be aware. you will need an OBD1 ECU though.
Ford Rocam is offline
Old 25th January 2009, 07:38   #3
Thanked: 82 Times
ahh obd2, that sucks. i was thinking of getting an OBD-1 P28 ECU and using crome for tuning. do you happen to have a pic of the ECU or is it possible to take one?
Old 27th January 2009, 02:37   #4
Thanked: 82 Times
anybody, please? someone out there might have messed with this ECU?
Old 27th January 2009, 03:55   #5
iraghava's Avatar
Thanked: 281 Times
Ananth - AFAIK the only people on the forum to have played around with OHC's ECU are Ford Rocam & Viper. It's best you PM them for more info.
iraghava is offline
Old 28th January 2009, 09:16   #6
Thanked: 82 Times
thanks for the tip man. I'll be sure to do that.
As a side note, I would like to point out that the Modifications forum is a joke. How are wiper blades and door handles "Under the Hood" ???????
Old 28th January 2009, 10:18   #7
Ford Rocam's Avatar
Thanked: 23 Times
You can still use that by getting a conversion harness, chrome is used mostly on all chipped OHC's here done by Tuned i chips, most cars on forum including vipers beast runs on chrome.
i will try to get the actual pic for the same, but i think you can find it on the net itself.
Old 30th January 2009, 02:20   #8
Thanked: 82 Times
thanks man, appreciate it. A pic of the connectors would be nice because I can then start building the harness. I know boomslang and some others make the harness, but why spend $100 on something I can make for $10?
Old 30th January 2009, 03:04   #9
iraghava's Avatar
Thanked: 281 Times
I would've helped there Ananth but sadly my car ois no longer with me. Will see if I can arrange a pic from any of my friends cars.
iraghava is offline
Old 30th January 2009, 11:04   #10
Thanked: 82 Times
That would be great Ishan. Depending on how things go I might be able to put together a solution for other interested people as well.
Rocam, what ECU do you use on your car?
Old 30th January 2009, 12:18   #11
Ford Rocam's Avatar
Thanked: 23 Times
I am using OBD1 P30 with Hondata S300
Old 30th January 2009, 12:31   #12
viper's Avatar
Thanked: 20 Times
HI Annath,
Here are some old pics of my ECU and Wiring connectors when the car was still a 1.5 Vtec. Hope they are of help to you.
Viper
viper is offline
Old 30th January 2009, 12:40   #13
ImmortalZ's Avatar
Thanked: 601 Times
Here are two pages I found :
ECU Pin-out Diagrams :: Innovate Motorsports Application Notes
ECU Pinouts
Tell me which exact ECU you need help with and I'll try to get you what you need.
ImmortalZ is offline
Old 30th January 2009, 13:14   #14
leadf00t's Avatar
Thanked: 15 Times
dhanno is no longer with you???
kab kyun kaise ??? bhaiyyaji bataiye.
leadf00t is offline
Old 30th January 2009, 14:59   #15
navin's Avatar
Thanked: 9,970 Times
I guess there was a point in the life of the car when the tyres were worth more than the car. :-)
navin is offline
