Team-BHP > Motorbikes
Old 6th March 2025, 10:42   #511
Thanked: 93 Times
Re: Honda NX500 launched at 5.9 lakhs
To add; I had my first scare on the bike today.
On sudden braking the front just wouldn't engage, and I had to swerve sharply to avoid hitting a car. The hazard lights came on by themselves (Honda emergency response) and I couldn't switch them off as there is no physical control. Took 5 minutes for an auto-reset and everything was back to normal. This experience shook me up badly.
I know the feeling. Happened a few times where I squeezed the front brake lever but didn't feel the bike react at all. I had to release the lever and pull it back again for the brakes to work. Fortunately, never happened in a sticky situation where I didn't have enough time. It's quite scary though.
On a different note, that rear tyre looks good as new. How many kilometers have you clocked so far?
on2wheels is offline
Old 6th March 2025, 11:06   #512
Sebring's Avatar
Thanked: 12,194 Times
Infractions: 0/1 (7)
Originally Posted by on2wheels View Post
I know the feeling. Happened a few times where I squeezed the front brake lever but didn't feel the bike react at all. I had to release the lever and pull it back again for the brakes to work. Fortunately, never happened in a sticky situation where I didn't have enough time. It's quite scary though. On a different note, that rear tyre looks good as new. How many kilometers have you clocked so far?
So there is a problem. Honda dismissed saying its a bubble.
I've done under 7000. And no I dont speed
Sebring is offline   (1) Thanks
Old 6th March 2025, 11:35   #513
b16h22's Avatar
Thanked: 2,818 Times
You should take the bike to a service center and insist them to do a proper brake bleed. It is a life threatening issue and what if this happens when you are panic braking? Also ask them to check the Master Cylinder.
b16h22 is offline   (1) Thanks
Old 12th March 2025, 11:14   #514
Thanked: 98 Times
Anyone has idea if we can change handlebar of NX to a wider one ? any option available ? finding the stock handlebar to be a little too narrow. Also any info on availability of a quickshifter for NX500 ? Strongly feel that a wider handlebar & QS will greatly improve this otherwise well sorted bike.
pankajbhoir46 is online now
Old 12th March 2025, 16:29   #515
Thanked: 361 Times
Originally Posted by pankajbhoir46 View Post
Anyone has idea if we can change handlebar of NX to a wider one ? any option available ? finding the stock handlebar to be a little too narrow. Also any info on availability of a quick shifter for NX500 ? Strongly feel that a wider handlebar & QS will greatly improve this otherwise well sorted bike.
NX500 does not get a quick shifter. Quick shifter is not listed as an official OEM part anywhere. So you will need for 3rd party made quick shifters for the NX500.
Regarding the handlebar, you can try out the Transalp handlebar. But check whether this handle bar fouls with the wind screen or any other component and the cable have adequate slack.
skviknaraj is online now
Old 14th March 2025, 16:10   #516
Sebring's Avatar
TWINNING!
With the blazing hot sun above
(you can feel the heat in this pic).
But still, Boy what fun!
(With my friend and fellow flat mate)
Sebring is offline   (7) Thanks
Old 28th March 2025, 09:45   #517
Thanked: 93 Times
Where did the last 2 pages of this forum go?
on2wheels is offline   (4) Thanks
Old 28th March 2025, 10:32   #518
CrAzY dRiVeR's Avatar
Thanked: 79,243 Times
To the dedicated thread for the side- pulling issues.
Mod Note: Please continue the issue discussion in the new thread and all other ownership updates here as usual.
https://www.team-bhp.com/forum/motor...ml#post5947197 (Brand-new Honda NX500 pulling/falling to the right)
CrAzY dRiVeR is offline   (2) Thanks
Old 2nd May 2025, 20:27   #519
minzanurag's Avatar
Thanked: 264 Times
Carbon Racing has announced their prices and is currently on pre-order- https://carbonracing.in/collections/...00-accessories
I read through the forum but couldn't find a good feedback on aftermarket accessories esp. the engine and fairing guard, main stand - From what I heard is they tend to vibrate after couple of thousand kilometers. Is this true?
Also, any feedback on the quality of the materials used for making the frames? Anyone observed rust formation, etc.
I might purchase radiator guard and sump guard but would really go ahead with fairing guard and main stand only if credible positive feedback is available. Better still, if any other aftermarket vendors are there with better products and preferably bit less expensive than the OEM ones.
Thanks,
A
minzanurag is offline
Old 8th May 2025, 11:05   #520
Thanked: 93 Times
Thanks,
A
You have plenty of options available now for the NX500 from both Indian and international manufacturers. Indian brands: Carbon Racing, Zana, Moto Torque and a few more. International brands: SW-Motech, Hepco & Becker, SRC etc. And then you have the Honda accessories.
I've been using the following Carbon Racing parts for several months now:
- Top & bottom crash bars
- Bash plate
- Top rack
- Radiator grill
- Centre stand
- Fender extender
- Pull-back handlebar riser
- Windshield height extender
My experience using these have been really good. They are well made and very sturdy. They've not made any effect of the vibrations. On the downside, in order to make these parts strong, they're made them very heavy and added to the overall weight of the bike. And that has reduced the already low ground clearance.
If you're on a tight budget, you'll have to look at Indian options. I'd suggest you look at the specifications and compare the weight. But if you can afford, go for anny of the international brands.
on2wheels is offline   (1) Thanks
