Team-BHP > Motorbikes
Old 18th February 2010, 22:49   #31
mc_anup's Avatar
Hi Deepak,
The bike looks gr8, man. what grabbed my attention was your rear wheels. What size are those tyres? It seemed the same size as my FZ16, 160/60 r17. Lemme know, cause I have been wanting to get discs on my rear wheels for some time now.
Anup
mc_anup is offline
Old 19th February 2010, 00:31   #32
abhayshanu's Avatar
Thanked: 326 Times
Your bike is just amazing, any time you want to sell it, im ready to take it off your hands
abhayshanu is offline
Old 19th February 2010, 01:23   #33
jsmonu's Avatar
That is one helluva kicker D!! Amazing efforts and what's come out of it..! Kudos to you bro.. Keep it clean.. and ride it hard..! (but safe)
jsmonu is offline
Old 19th February 2010, 15:38   #34
DeepakMenon's Avatar
Thanked: 182 Times
It is 4.5*17 rear wheel of suzuki rgv 250; and yes i am running a 160; but not a great tire.. need something better
You can fix a disc on any rim; just a matter of getting the design straight
PS not so sure of a 160 on a FZ16 as the use a 4*17 rim; and 150 would be the best bet anything more you can end up runing the tire profile
And lastly why do you want a anchor on you bike? the stock 140 is one of the lightest tires i have come across; most of 160 you get are not Michellins or any good brand so are heavy and FZ16 does not produce that much power
DeepakMenon is offline
Old 19th February 2010, 18:18   #35
mc_anup's Avatar
Tires on FZ16
Hi Deepak,
The stock tires on an FZ16, is an MRF Revs 160/60 R17. Ride quality is good but could be better.
I plan to move to a michellin or bridgestone, but my priority is getting a disc on, without losing the current rim dimension.
Anup
mc_anup is offline
Old 20th February 2010, 22:21   #36
Hi Deepak,
Firstly congrats for a great bike
As you have mentioned that this is a 250 converted into 350, now the question is your Pipes are of 250 or 350. And if this is a 250 pipes than dont you think that the bike runs hotter as 250 pipes are more restrective.
Champ111 is offline
Old 21st February 2010, 16:31   #37
Thanked: 2,262 Times
Originally Posted by mc_anup View Post
Hi Deepak,
Anup
You can retain the drum and still fit a rear disc on. You need a foundation on the drum which will hold the disc in place.
Cheers,
Jay
JayPrashanth is offline
Old 22nd February 2010, 21:43   #38
Thanked: 182 Times
Good question !!
yes a 250 pipe tends to run hotter than 350 pipe; but there various types of pipe designs; the one that runs real bad is the one that looks like 31K
Mine is altogether different peice visually it looks like the 1UA however mine has detacble cans; you can modifly the exhaust to cope it a bit
So mine some bit of work is done; and i am not facing any over heating issue whatsoever;
But yes i know i can get another few BHP by making a better pipe.. but that is for a later day
Old 24th February 2010, 21:48   #39
what is the sprocket size you are using and are you using the stock radiator or got some build.
Champ111 is offline
Old 25th February 2010, 13:29   #40
Thanked: 182 Times
I am running 17:42
the stock is 17:39
Currently i am running stock radiator; though i have a 3XV radiator [New] lying, not getting time to fit it. Though the stock handles the heat; however 3XV is new, hold more capacity, is a curve radiator and most important the radiator capy is more accessible unlike stock RZ which is under the tank !!!
Champ : you seem to know these machines a bit; what do you ride?
Old 25th February 2010, 22:01   #41
Deepak,
I have a couple of 2strokes.
BIKES
RZ350 (31k cylinders)
RD350 (US Barrels)
RXZ 4speed converted into 5 Speed
Lambretta 1972 Model all Orignal with Orignal Paint
Suzuki Shogun (In a very Bad Shape waiting for a rebuild)
Bajaj Sunny
CARS
Baleno Lxi
Maruti 800 Automatic
Wagon R Lx
Omni
Champ111 is offline
Old 25th February 2010, 22:04   #42
Thanked: 182 Times
Love to see snaps of your 31K; so have you kept it stock?
Cool let me know if you ever need help on your RZ
Old 25th February 2010, 22:43   #43
Thanks a Ton Deepak, will surely ask for a help if stuck somewhere.
There have been a couple of Changes in the bike.
Carbs: 28mm RD400
A bit of changes in Expansion
TDR Reeds
Stage1 Ported
RZ500 shocks,
RZ500 Callipers front and rear,
RZ500 Front wheel 16inch
Front fairing from Fazer
Head modified to match Squish
and some more small one not able to recall them as of now.
Champ111 is offline
Old 26th February 2010, 17:38   #44
Thanked: 182 Times
Cool; where did you get the work done?
What kind of PIston; Crank are u running?
You should throw the stock running gear; make some money while you do it and upgrade the suspension; the stock gear is not so great unless to spend $500 + to change all internals [As they are more than 20 year old]
What ignition? Stock? Apparately 31K has the best curve [51L marking on CDI]
Those pipes are not 31K pipes; they are either 1UA or the same i have [The end cans should have 51L stamped on them] if yes then you would be running hot unless you do some mods as they are rz250r pipes;
Last question what chain are you running?
Nice Stanc eyour bike's got
Old 26th February 2010, 17:44   #45
Thanked: 182 Times
EDIT : Sorry guys double Post !!
