Originally Posted by Tanveer_2558
(Post 3965385)
Agreed, But i have got the same response from VW, Skoda, Toyota, Maruti, Mahindra Etc, All of them i remember clearly said maintaining 30-32 PSI is ideal, Even the sales advisor and even folks at the service centre check and maintain 32 PSI when the car visit's for servicing. Maruti Suzuki SX4 ZXI - Tubeless tyres - Always maintained 30- 32 PSI used the stock tyres for 50k Before i decided to change them. Mitsubishi Cedia Sports - Tubeless tyres - Always maintained 30-32 PSI used the tyres for about 45k Before i sold the car. XUV 500 W8 - Tubeless tyres - Always maintained 30-32 PSI used the tyres for about 50k, Then i swapped them. XUV 500 W10 - Tubeless tyres - Always maintained 30-32 PSI, ODO's crossing 25k Mark without any issues. VW Polo 1.2 - Tubeless tyres - Always maintained 30-32 PSI, Used it for 20k before selling the car off. VW Jetta TDI - Tubeless tyres - Always maintained 30-32 PSI, Currently ODO at 27000 Kms. |
(Post 3965385)
Now after using all the above cars, I have had no issues with fuel economy or Increased tyre wear or Grip levels or Even none of them had gone through any suspension work done. My cars are mostly used in city 60% and highway 40% with mostly 2 adults or 4 sometimes, Thats when i used to take the air upto 34PSI. |
(Post 3965385)
What if VW advises tyre pressures for the autobahns through that sticker? |
(Post 3965385)
On the other hand i have seen the air filling guys at the pump increasing the air pressure to 40+ when i try to get the air checked in my XUV, To which i ask them to reduce it, Once a guy rudely told me, "Itna bada gaadi ka main 45 daalta hu", (Its such a big car, I fill in 45 in such cars") |
Originally Posted by alavandar
(Post 3965419)
In all these cases what the user manual say and what is recommended by maker? Could you ever check on that? Could you ever question the service people why their verbal advise is at variance from what is given in book? |
I have no comments. We each can do what pleases each of us with our cars. I go by maker's recommendations and you can go by the "itna bada nahi rakte hai sahab" advise from petrol bunks or advise of the service "advisers" |
Air filling guys go by their instinct / what they repeatedly do and not by knowledge. Well, I being an engineer, I go by printed published advise of the makers. I have done this for years now and I am not let down. All the best and happy motoring. |
Originally Posted by sunsbhp
(Post 3966270)
I had a tad scary situation couple of times in last 2 days; when in 'D'rive mode, but car was stationary because it was a very slight uphill (a typical 5-10 degree incline from road to the gate, and was going thru a regular security check, but didn't shift to 'N'eutral because it's always a 5-7 seconds stop), the Break pedals got stuck (as if the ignition is off). |
Originally Posted by Santoshbhat
(Post 3966280)
Are you sure its not the hill hold control at work here? |
(Post 3966280)
(Post 3966270)
I had a tad scary situation couple of times in last 2 days; when in 'D'rive mode, but car was stationary because it was a very slight uphill (a typical 5-10 degree incline from road to the gate, and was going thru a regular security check, but didn't shift to 'N'eutral because it's always a 5-7 seconds stop), the Break pedals got stuck (as if the ignition is off). If I could recollect the sequence - I had stopped at the gate by applying brakes, and car had halted, slowly release the bakes and it was still stationary, moved my feet to accelerator to move forward, but had to immediately switch back to brakes - and break pedal got stuck! I tried depressing gently few times, but it didn't budge, rather became just immovable. I quickly glanced for any warning/critical indicators and there was none. I tried shifting to 'N' and then back to 'D' quickly, and Break pedals became active again. This happened again the next day (yesterday) while I was on a pretty flat road-side - in a similar sequence! My left hand is always on hand-break since then, and don't feel comfortable. Just wanted to ask around if any of you had similar experience, or have any inputs as to why this might have happened ? Had a hectic day yesterday so didn't really try to simulate the situation, but I think I should try. Inputs and suggestions much appreciated. |
(Post 3966294)
Not sure Santosh, but I would assume the hill-hold shouldn't disable the Brakes, right ? Also, second time it was really on flat surface. |
(Post 3966294)
Originally Posted by F150
(Post 3966334)
It is indeed the hill hold control at work. Don't worry about the brakes, just drive off from stand still. The brakes are not disabled, instead the car is holding the brake for you. If the wait time is more than few seconds, better to come to N and use hand brake. |
Originally Posted by graaja
(Post 3966354)
It is the hill hold function in action. When hill hold gets activated, when you remove your foot from the brake pedal, the car will hold the brake for you. |
Originally Posted by differential
(Post 3967803)
All else was fine. Have done about 1000km so far. This morning on my way to work, I noticed that the car was idling at 1K rpm. Thought that was a few hundred more than usual, with the AC switched off. My dad had taken the car this afternoon and suddenly noticed large amount of smoke from the exhaust with burning smell. Luckily, he had reached his destination and quickly got out of the car and switched it off. The AC fan continued to run for sometime before it switched off. No smoke from the engine compartment. These were the info I got from him. But, am really really annoyed and worried that such a thing should happen in the first place! What could be the problem? The senior service person thinks it might be some sulphur related problem due to fuel. But, I don't think so. Same petrol station for all our cars for the past 10 yrs and no such issue for any vehicle from Omni to BMW. I thought the diesels were the trouble free ones. Has any such problem been reported. |
Originally Posted by akshay1234
(Post 3967807)
Seems to be the DPF regeneration. If you have been using the car for relatively short trips, and not really opened it up on a long drive then this happens. Had noticed it once or twice with the Yeti too. The engine idles at 1-1.1k rpm, and some whitish smoke comes out of the exhaust. |
(Post 3967812)
That is something the service chaps are considering. Honestly have not done a long trip sans the one 160 km trip a couple of days after delivery. But the quantity of smoke was a LOT. Like those really old metro buses. And the burning smell. I hope it's nothing major. Fingers crossed. |
(Post 3967852)
Take the car out for a spin, redline it in 2nd and 3rd gear a couple of times. I'm sure you will see a large amount of black smoke the first 2-3 times you redline the car. After that there should be none. That'll also take care of the DPF. |
(Post 3966294)
(Post 3966270)
(Post 3967803)
I hope I am very very wrong. But am wondering whether I have been given a LEMON. I was quite happy with my month old Jetta barring the cruise control problem. I took it up with the service dept at VW Coimbatore. They were not very sure about the exclamation mark next to the cruise control and have opened a complaint and have assured me that they will contact VW and get back. This was about a week ago and am waiting to hear from them. All else was fine. Have done about 1000km so far. This morning on my way to work, I noticed that the car was idling at 1K rpm. Thought that was a few hundred more than usual, with the AC switched off. My dad had taken the car this afternoon and suddenly noticed large amount of smoke from the exhaust with burning smell. Luckily, he had reached his destination and quickly got out of the car and switched it off. The AC fan continued to run for sometime before it switched off. No smoke from the engine compartment. These were the info I got from him. Quickly, contacted VW RSA and the dealership. I was surprised that my chassis no was not on the RSA database. But the RSA person was clear that he will arrange a pick up within an hour and I could send a copy of my invoice tomorrow to cross check. Good job I would say! Mean while, I contacted a senior at VW Service and I was reassured that the car would be picked up and looked into at the earliest and they offered to co ordinate with the RSA and hasten things. True to their word, the car was on a flat bed within the next 30 min. Efficient indeed. But, am really really annoyed and worried that such a thing should happen in the first place! What could be the problem? The senior service person thinks it might be some sulphur related problem due to fuel. But, I don't think so. Same petrol station for all our cars for the past 10 yrs and no such issue for any vehicle from Omni to BMW. I thought the diesels were the trouble free ones. Has any such problem been reported. Any opinions and suggestions? Pardon my long rambling, but this is the first time I ve had an issue with any of my cars and am really pi***d! |
