1:72 Panavia Tornado GR.1A Royal Air Force No.2 (AC) Sqn, ZA371, Norway, 1995(Hobbymaster)
Designed in collaboration with Britain, West Germany and Italy, the two seater Panavia Tornado attack & reconnaissance fighter was first flown on August 14th, 1974 and is thought by many to be the most important military aircraft in Western European history. Nicknamed "The Flying Fin" because of its large tail fin and the "Tonka" by the British, the Tornado has a variable wing sweep design and is capable of taking off and landing on short airstrips. It is equipped with terrain-following radar, which allows for hands-off, low-level flight in any weather. There are three primary versions: an electronic combat/reconnaissance version( Tornado ECR), an interceptor (Tornado ADV) and a highly versatile strike fighter-bomber capable of carrying almost all of NATO's air-launched weapons(Tornado GR.1-4).
For shorter take-off and landing distances, the Tornado can sweep its wings forwards to the 25-degree position, and deploy its full-span flaps and leading edge slats to allow the aircraft to fly at lower speeds. These features, in combination with the thrust reverser-equipped engines, give the Tornado excellent low-speed handling and landing characteristics.
The RAF Tornado made its combat debut as part of Operation Granby, the British contribution to the Gulf War in 1991. This saw 49 RAF Tornado GR1s deploy to Muharraq Airfield in Bahrain and to Tabuk Air Base and Dhahran Airfield in Saudi Arabia.18 Tornado F3s were deployed to provide air cover, the threat of their long range missiles being a deterrent to Iraqi pilots, who would avoid combat when approached. Early on in the conflict, the GR1s targeted military airfields across Iraq, deploying a mixture of 450 kg (1,000 lb) unguided bombs in loft-bombing attacks and specialised JP233 runway denial weapons. On 17 January 1991, the first Tornado to be lost was shot down by an Iraqi SA-14 missile following a failed low-level bombing run
During Operation Granby in the First Gulf War, Flt Lt Nichol's first mission, on 17 January 1991, was part of a formation on an ultra-low-level Strike sortie against Ar Ruma his Panavia Tornado GR1 that was being flown by his pilot Sqn Ldr John Peters. Their Tornado ZD791 was critically damaged by n Iraqi shoulder-launched SA-14 surface-to-air missile, and both ofbthem were captured by Iraqi forces.
After capture both Peters & Nichol was shown, bruised, on Iraqi television. They were tortured in the Abu Ghraib prison. They were released by the Iraqis at the end of the Gulf War.
On 19 January, another RAF Tornado was shot down during an intensive raid on Tallil Air Base. The impact of the Tornado strikes upon Iraqi airfields is difficult to determine.[215][216] A total of six RAF Tornados were lost in the conflict, four while delivering unguided bombs, one after delivering JP233, and one trying to deliver laser-guided bombs.
No.2 (AC - Army Co-operation) Squadron
No.II (AC) Squadron received their first Tornados by mid-December 1988. During "Operation Desert Storm" the unit performed was awarded "Battle Honors".
Tornado GR.1A
The Tornado GR.1 was the first Tornado version to enter service with the Royal Air Force (RAF) in 1982. The RAF used the Tornado from the 1980s until 2019.
The Tornado GR.1A was a dedicated reconnaissance version of the GR.1 with the 27 mm cannons being replaced with sideways looking infrared sensors and another forward looking sensor being placed under the fuselage. It also had the capability to carry reconnaissance pods under the fuselage.
The GR.1A has no canon so reconnaissance equipment could be mounted. There were 30 GR.1As built and ZA371/C serial 172/BS053/3085 was one. For NATO Arctic Exercises in Norway a temporary white paint covers the usual green.
General characteristics
Crew: 2
Length: 16.72 m (54 ft 10 in)
Wingspan: 13.91 m (45 ft 8 in) at 25° sweep
Swept wingspan: 8.60 m (28 ft 3 in) swept at 67° sweep
Height: 5.95 m (19 ft 6 in)
Wing area: 26.6 m2 (286 sq ft)
Empty weight: 13,890 kg (30,622 lb)
Gross weight: 20,240 kg (44,622 lb)
Powerplant: 2 × Turbo-Union RB199-34R Mk 103 afterburning 3-spool turbofan, 43.8 kN (9,800 lbf) thrust each dry, 76.8 kN (17,300 lbf) with afterburner
Performance
Maximum speed: 2,400 km/h (1,500 mph, 1,300 kn) at 9,000 m (30,000 ft)
1,482 km/h (921 mph; 800 kn) IAS near sea level
Maximum speed: Mach 2.2
Combat range: 3,148 km (1,956 mi, 1,700 nmi) Combat radius Hi-Lo-Hi >850 nmi (>1574 km), combat radius Lo-Lo-Lo >500 nmi (>926 km), Hi-Hi-Hi with 1 hour loiter >700 nmi (> 1296 km)
Ferry range: 3,890 km (2,420 mi, 2,100 nmi)
Service ceiling: 15,240 m (50,000 ft)
Rate of climb: 77 m/s (15,100 ft/min)
Wing loading: 767 kg/m2 (157 lb/sq ft)
Thrust/weight: 0.77
Armament
Guns: deleted
Hardpoints: 3 × under-fuselage and 4 × under-wing pylon stations[e] with a capacity of 9,000 kg (19,800 lb), with provisions to carry combinations of:
Missiles:
2 × AIM-9 Sidewinder (AIM-9B / AIM-9G / AIM-9L) (GR.1) or AIM-132 ASRAAM air-to-air missiles for self-defence (GR.4)
12 × Brimstone air-to-surface missile; or
2 × Storm Shadow cruise missile
9 × ALARM anti-radiation missile
Bombs:
5 × 500 lb (230 kg) Paveway IV; or
3 × 1,000 lb (450 kg) (UK Mk 20) Paveway II/Enhanced Paveway II; or
2 × 2,000 lb (910 kg) Paveway III (GBU-24)/Enhanced Paveway III (EGBU-24); or
BL755 cluster bombs; or
Up to 2 × JP233 or MW-1 munitions dispensers (for runway cratering operations)
Up to 4 × B61 or WE.177 tactical nuclear weapons
Other: Up to 4 × drop tanks for ferry flight/extended range/flight time
Avionics
RAPTOR aerial reconnaissance pod
Rafael LITENING targeting pod; or
TIALD laser designator pod
GEC Sky Shadow electronic countermeasure pod
BOZ counter-measures pod
250 Kg GP bombs, 2250L Drop tanks and 2 X AIM-9 Sidewinders for self defense
Sky Shadow ECM pod
BOZ Chaff/Flare dispenser pod
Notice the IR sensors on the underside of the aircraft near and behind the nose landing gear door. On the GR.1A, these sensors replaced the Mauser BK-27 of the GR.1.
