My 15 year old Skoda Octavia 1.8 Turbo rider needed annual service. Taking it to Authorised Service Station (ASS) does not make sense here, so decided to get it done at my home. I considered WheelsWisdom but they stopped offering to take the cars to ASS, instead they do it in multi brand service centers.
In Pitsop, two kinds of periodic services are available, Basic oil change and Complete service. I went for complete service.
What is included (as per their website)?
Engine Oil Is Drained And Replaced
Oil Filter Replaced
Air Filter Replaced
Spark Plugs Are Cleaned In Case Of Petrol Vehicle
Coolant Is Replaced Or Filled
Brake Oil Is Replaced
Brake Pads Are Removed, Cleaned And Placed Back
Exterior Eco-Wash(Water Less Wash)Interior Vacuum Cleaning
Dashboard And Tyre Polishing
Vehicle Current Condition Is Diagnosed And Reported
Booked the service in their app scheduled for 22 Aug saturday 8:30 am. The app updated my booking by assigning a technician a day before. At around 8 am, the technician called to inform that service is not possible today because some of the items are not available. Rescheduled it for next day morning. But later on he calls and confirms he can come at 3:30. Guy (lets call him M) promptly arrives at 3:30 pm in a Maruti Eeco loaded with items accompanied by another guy R.
R asks for car keys, goes in, releases the bonnet lever, opens the bonnet goes back starts engine and races it immediately. This being a turbo petrol my heart skipped a few beats. Kept running for few mins to warm up the engine. I read somewhere that warming up a little before oil change is a good practice.
Then he opened the engine cover. Checks here and there and asks what is the mileage. When told 95k kms, he says timing belt needs to be changed else there will be newer problems down the line and complaint will come back to them. It completely surprised me. R offered to get it done on the same day in a garage known to him and then change the oil else the oil will be wasted if done later. But I was in no mood for his comments and mainly was afraid of his competency. Asked to go ahead with agreed upon services. He agreed after a few tries.
Lifted up the car with jacks. No jack stand. Went underneath, removed oil drain nut and started draining out oil.
Meanwhile changed air filter with a VIKA model. Part number matches with the outgoing Mann filter.
With a transparent pipe and using mouth he sucked out coolant from the reservoir for 700-800 ml. Cleaned the pipe by whipping it on the ground several times and then used it for brake oil. This time removed around 200-250 ml of brake oil.
Refilled 1 liter coolant from a bottle of Hella brand. Topped up brake oil from a bottle of TVS Girling DOT4 fluid few times until the level didn't go down anymore.
By this time M started with vacuum cleaning the interiors.
Then R sprang the surprise. He was about to pour new engine oil. When asked him did you change the oil filter he said what he brought along is a paper filter and does not match for my car. I was like what
He thought he could go ahead without changing oil filter nobody notices it. Stopped him then and there. Told him to get a filter else not required. He tried to mumble something but when I refused to budge he agreed to come next day with the oil filter and finish the job. Meanwhile refilled the drained out oil and left.
Day 2: M came at noon to continue the remaining part, without R. He brought in a Chinese oil filter and said it will work. Drained oil and after removing the existing filter he found that the chinese model is different. Called someone to bring the correct model. Another guy came and delivered a Purolator brand filter. Meanwhile the car was up on jack. Had to insist again to bring down the car to level ground so that all residual oil is drained out.
Filled 4L of 10W-40 Shell Helix oil. Started the engine and kept it running for some time to check for leaks.
Lifted the car again on the jack to remove the wheels for brake servicing. Just had a look at the brake pads and commented these are good. Did not do anything else. On hindsight I am glad he didnt tinker with the brakes, I didn't have any confidence in him. I asked him to apply grease in the wheel hub. A month back when I tried I could not remove the alloy wheel from the hub, after removing the nuts, as the wheel was completely stuck in the hub.
Did not do any checking of spark plugs. Although it was clearly written it will be done for petrol vehicles.
Vacuum cleaning: Brought a big Bosch cleaner and it did a good job in the interiors.
Exterior water-less wash: Did an okay job with some unknown liquids brought in bisleri bottles.
Dashboard polish: Did a okay job.
When reminded they did not clean the wheels, he again brought out some unknown liquid to polish the tyres and the wheels.
Scanning: Using wireless OBD scanner, started the OBD app in his mobile and showed there were no DTC codes present. The reports later came to me in the app as pdf files.
Finally he marked every task as completed in his app and asked his boss to complete the process. Notification came in my app that service is completed and amount to be paid. Online payment was hassle free.
M then pushes me to rate him 5 stars.
Conclusion:
Will I go for it again? Probably not.
Will I recommend others? For common cars and only for oil change, it is a good option.
Now the questions:
Does it help if some coolant is removed from reservoir and refilled with new?
Does it help if some brake oil is removed from reservoir and refilled with new?
Skoda recommends 5W40 fully synthetic oil. I was given Shell Helix 10W40 synthetic. Will there be any adverse effects?
Update: Drove the car today first time after servicing. There was krrrr sound coming from engine driver side while taking turns. Looked underneath and saw a plastic part under the serpentine belt is broken and hanging free. It touches the belt on taking turns. Most likely they put the jack in the wrong place while lifting the car and broke its brackets.
Emailed Pitstop to attend to it at the earliest.
