Old 25th January 2021, 10:36   #61
Thanked: 21,452 Times
Re: Turbocharged engines and the idling start / stop system
Originally Posted by venkyhere View Post
what if there is a steep ramp to climb out of parking, on a cold morning ? what will be your take on what to do in that case ?
1) start moving from parked position in 10 seconds and then when engine temp is low, climb the ramp & load the engine
OR
2) idle for 1 min, move out of parked position and climb the ramp & load the engine when engine is slightly warmer
I feel Point 1 is what is better to do unless the ramp is ultra steep and will require revving the nuts.
Idling say 15-20 seconds should set all fluids flowing internally (read engine oil) and since the oil galleries will have some residual oil in there already, flow will be faster and will avoid excessive wear. Idling actually will take longer for the engine to reach the operating temperature and it is best to drive off after 10-15 seconds. I might be wrong in my thinking so please correct me if I'm wrong.
a4anurag is offline
Old 25th January 2021, 10:51   #62
balenoed_'s Avatar
Thanked: 5,679 Times
Originally Posted by Dr.AD View Post
So again, it is not a dumb system that will casually switch off the engine at every single stop. It is a pretty sophisticated system that knows what it is doing.
I second that.
This I double checked with my Scorpio today. On an ideal normal short duration drives, the auto shut off happens in ~3s. While when I did a 50Kms non stop drive and stopped, the auto shut off happened in about ~8s.
balenoed_ is offline   (2) Thanks
Old 25th January 2021, 12:32   #63
Thanked: 62,278 Times
OR
What you need to understand is that on modern engines, especially diesels, a minute of idling hardly does anything for the oil temperature. It won’t make a difference.
So just drive off.
We are talking about cumulative wear over the life span of an engine. So thousands of engine starts. Once doing is not going to make a noticeable difference.
Jeroen
Jeroen is offline   (3) Thanks
Old 25th January 2021, 21:09   #64
Thanked: 5,894 Times
So just drive off.
Jeroen
that's the point I was originally making - the presence of a steep ramp right at the start (say, 20 seconds to reach it, if driven off immediately after crank) is the real deal breaker (wear inducing) here that is going to load the engine (even in 1st gear) when oil is not warm enough, whether idling is followed or not, years and years of doing this will inflict wear.
How will you classify two exactly same cars - one parked in a basement like above and one parked on level ground (which doesn't need to climb a ramp) , each of them starting 365 days a year and driving off in the same manner, for 4/5 years or running 100k odo. Will there be a noticeable difference in wear between the two ? If yes, engine design and oil engineering are still not "fully reliable" yet
venkyhere is offline
Old 25th January 2021, 22:15   #65
Yes, if everything else is identical (the cars are driven in an identical way) there would be a difference in wear. How much is impossible to say. But climbing a ramp, even a steep one, would take a short while only. We are talking about minute cumulative wear. So once a day 10-20 seconds of running a cold engine at a bit of loading is unlikely to be a major problem.
Gut feeling is idling the engine is likely worse than a bit of engine loading anyway.
I am not sure what you mean with engine/oil design and engineering not fully reliable yet. I am not aware of a single design that does not have limitations. Whether it is a car, a plane or a coffeemaker. Take it beyond its normal operating instructions and you are likely to see problems, or additional wear and tear.
You want to push a performance envelop it is just a question of money. How much more expensive can an engine/car be to solve this? In practice it tends to be more of a theoretical problem. Certainly for the first 100-150K kilometers.
So you are wearing the piston rings and the cilinder (liners). To a lesser extend probably bearings/cams/valve stem seals a bit too. How big a problem is that really? The first sign of this kind of wear tends to be oil consumption.
As long as you are not loosing compression you can debate how relevant engine wear, or oil consumption is? We have another thread on oil consumption. Lots of people are very concerned, but on many engines up to 1l of oil consumption per 1000 km is not considered a problem at all. (again, do not believe me, but check your owner manual!).
An engine overhaul is expensive, adding some oil now and then is not.
Jeroen
Jeroen is offline   (2) Thanks
Old 26th January 2021, 21:51   #66
The point is to design it to withstand extreme operating points , while enforcing the working zone to conservative operating points. But it's one of those business decisions where reliability will be the justification for incurring extra design&manufacturing cost, without any extra performance to show for it. Like making a crane to lift 100 tonnes, but mention 50 tonnes on its spec sheet.
Old 21st January 2022, 03:41   #67
Poitive's Avatar
Thanked: 2,824 Times
While the focus on the thread seemed to be on turbos blowing up, following the practice of idling appears to have an effect on how smoothly a car runs. Unverifiable, hence only moderately certain, experience suggests that.
What I remember reading about the subject a decade or two ago was about how the turbo is duly lubricated by the idling while starting and turning off, which tallies well with the experience of a smoother car when this was religiously followed.
As a side note: In older cars especially, on days I did a proper warm up, the car a little smoother. This was repeatedly noticed on long distance journeys. This was also observed by another friend.
Yes, they know more and their decision is not based on your peace of mind, but maximizing profitability.
Remember, even your life is a "pinto analysis" for the manufacturer, where they weigh a safety issues w.r.t whether litigation or a fix will cost more.
So agree with this. I usually changed the engine oil at about 20-25% before recommended schedule, as at that stage I could feel the car getting slightly rougher. Most would not notice the fine change though. After 10 years of use, this one felt smoother than new cars of a higher price point. I agree there would be many other factors at play as well.
How smooth a car feels, especially as compared to how it was when new, is an indicator of how well maintained the engine and related parts are.
PS: Thanks for pointing out the Ford Pinto case.
Poitive is offline   (1) Thanks
