Search this Thread | ![]() 99,459 views |
![]() | #91 | |
BHPian ![]() Join Date: Aug 2019 Location: Jharkhand
Thanked: 435 Times
| Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer Quote:
![]() | #92 |
Team-BHP Support ![]() ![]() Join Date: Apr 2013 Location: Madras
Thanked: 20,682 Times
| Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer |
The following BHPian Thanks Gannu_1 for this useful post: | hmansari |
![]() | #93 | |
Newbie ![]() Join Date: Feb 2022 Location: NCJ | SBC
Thanked: 39 Times
This issue of Oil Dilution is higher in MT vehicles as compared to AT vehicles. One main reason for this is that lower engine speed in Idle. Whereas in AT the engine speed is comparatively higher as it is needed to run the torque-converter. If your driving route has more idle zone (bumper to bumper traffic, leaving the vehicle idle etc.) or the average vehicle speed is less than 25kph, the regeneration interval could be lower. In such cases, multiple regen would be triggered by EMS within every 150-200 km. This could lead to mixing fuel with oil and lead to Oil dilution. Also, in such low vehicle speeds, if you are in higher gear, the engine would not be able to produce sufficient temperature for completing the regeneration with in the time frame and hence would be cut-off and soot might not have completely burned. These are just possibilities for higher oil dilution and lower RI. I am not sure how your driving pattern is, but please rise this issue with the Mahindra service team. Higher Oil dilution could lead to damage of internal engine components mainly Connecting Rod. Sure, I just wanted to connect with his privately to know his driving pattern and a little more about the vehicle so that I could guide him better. | |
The following BHPian Thanks arj2695 for this useful post: | pacman2881 |
![]() | #94 | ||
Thanked: 435 Times
Regarding oil dilution, as you have explained and as I also learned, it happens mainly due to the regen process. Frequently aborted regen due to short trips dumps more diesel in the engine oil.When the technicians drained engine oil from my car, they found 7 litres, i.e., 1 litre in excess. I verified from multiple sources in the Mahindra dealer network that this much mixing is permissible. In fact, Mahindra has recommended changing engine oil at 10 km instead of 20 km when driving in city conditions. So I have decided to regularly change the oil at 10K now. Regarding DPF clogging never faced DPF clogging during 17800km and 1 year of ownership. I have described my driving pattern in the above-quoted post. It was after this EMS flashing that I faced two warnings. Another Bhpian and two more Facebook group users have also reported the same. I took the car to the service centre yesterday, and the following happened: 1) They outright denied that it was happening due to the EMS software update. Note that this has never happened before with the same driving pattern. 2) They checked the soot mass, and it came to 10 g collected in 36km. Last time, there were 19g collected in 168km. They concluded that the car is generating excess soot, and they'll have to check the fuel system, air intake system, EGR, turbo, etc. At first I didn't allow them to take apart my car as I knew they would create more problems in the process, but later I allowed them to check the air filter, diesel filter, turbo, and throttle body. I have attached photos here. They said that the air filter and diesel filter choked, and that would also cause excessive soot generation. I agreed to change those parts as the 20K service is coming up anyway. 3) Regarding diesel quality, they said that diesel quality is fine, but it's not BS6 diesel. That is a surprise in itself, as the last refill was from my regular diesel bunk, and it has never caused any issues before. I have attached a picture of the diesel sample they took.All this time, they denied that a bad EMS configuration might be responsible for excess soot generation.Please note that the only time I had to refill at an unknown diesel pump was during my Nepal trip last month. That was two refills ago.After doing all this, they asked me to use the car to see if DPF warnings were coming now or not. Now, my doubt in all this fiasco is: 1) Why did this all start just after EMS flashed? Everything else was the same as before, and I never faced any issues. 2) There is a possibility that Mahindra has tweaked regeneration parameters to reduce the number of aborted regeneration cycles. Even if it is so, is it normal to receive a DPF warning every 150km? I mean, the car is not even trying to perform regen during normal running and is straight away asking the user to perform it. 3) Do you think that the choked(?) air filter, diesel filter, and diesel quality might be causing excess soot generation and it might just be a coincidence and the EMS thing has nothing to do with this all? I might be overanalyzing all this, but I can't shake this off as the car was fine until now, and I can't help but blame the software update for all this. Last edited by sbm : 4th July 2023 at 14:31. | ||
![]() | #95 | ||||
Thanked: 39 Times
It is not normal to get DPF clogging warning every 150 km. DPF warning would only come up if the regeneration has not happen even after reaching the maximum soot limit. As they have replaced the filters, please keep an eye on how the vehicle performs. If it is still performing the same, then software might be the culprit. But, it would be hard to make service team believe it. Please do escalate to higher MnM team. | ||||
![]() | #96 | |
Thanked: 435 Times
As mentioned in my previous posts, my XUV 700 diesel MT (as well as many others) started receiving DPF clogged warnings every 150–160 km after an EMS update. I was really worried at the beginning and ran to the service center for a solution, but they were unable to offer any. They checked certain things and let me off. As of now, the warnings keep coming at the same interval, but I am less intimated by them now. I have seen that the car starts giving signs that it's trying to perform regen, as at around 2000 rpm, fuel supply feels like getting interrupted, which I believe is happening due to the post-injection of diesel. If I am unable to keep the car running for 5–10 km at that time, it tries again in the next cycle. Even if the next cycle is short and regen is terminated, the REGEN needed warning comes on. I then drive the car at 2k rpm for around 10–15 minutes, and the warning goes away. I now recall that even before the said EMS update, this interruption in fuel supply was felt sometimes, but I used to think that it was a software glitch and didn't care about it much. I believe the car was completing regeneration in multiple attempts back then, rather than throwing up a warning after two or three failed attempts. Also, whenever I have done a fairly long trip of this duration, the warning does not come for another 100–150 km. I have now accepted that it's due to the usage pattern that these warnings are coming frequently, and since the vehicle is running fine, I have let the issue take a backseat, though I will get the car checked at a bigger dealership once the car completes 25000km. @arj2695 Please comment on my observations. Also, I have another concern in mind. Since my diesel car is being used primarily for short trips, I am thinking of performing preventive maintenance earlier and changing the oil every 5000 km, as frequent regeneration will cause oil dilution with diesel. As per my understanding, I should get EGR cleaning done more frequently. Can you guide me on this aspect, i.e., how to maintain diesel engines if used in short cycles? I would also like to connect through mail. Can you please allow email contact in your profile if you don't mind? Thanks ![]() | |
The following 2 BHPians Thank sbm for this useful post: | arj2695, hmansari |
![]() | #97 | ||
Thanked: 39 Times
From my experience, the 150-160km interval between two subsequent regeneration is rather low. If your average velocity is always less than 25kph, then there is a high possibility for such a low interval. One of the reasons for this is that sufficient temperature would not be available for completing a successful regeneration which could prolong a regeneration (which could cause oil dilution) and also limit the actual soot burnt off from the system. This causes the next interval to be reduced as well. About you being able to feel interruption in fuel supply is not usual. In general, the difference between when in regeneration and when not should be very minimal (slight variation in engine note and also mild perceptible heat near the Pedal area). So, I am rather confused when you say that you can fuel supply interruption. Quote:
The best idea would be to just take the vehicle for a spin where you can reach allowable safe speeds (constantly) for at least less than 20 minutes when you feel you have clocked the usual regeneration mark. Last edited by arj2695 : 21st February 2024 at 21:59. Reason: Fixed the broken font tags | ||
![]() | #98 | |||||
Thanked: 435 Times
Also, I have read on the Innova thread that in city use, it performs active regen every 200km or so and also indicates the level of dpf choking along with indications when regen is going on. That also confirms my suspicions that it might just be normal behavior in my car. As both the cars have similar sized engines may be I can draw some parallel from there. | |||||
![]() | #99 | |
Senior - BHPian Join Date: Jul 2006 Location: Bombay
Thanked: 2,415 Times
EGT design also has an important role into this especially in Indian conditions, which many OEMs are finding out now. Passive Regen occurs when the DPF is operating at 250-400degC temperature, when the Nitrogen Oxides in the exhaust react with the Soot particles to generate CO2. This temperature is present when driving at more than 20kmph and at sightly higher average engine rpms as I said in previous question. So if you're driving at decent speeds the DPF will observe good passive regen. .[/quote] Can you please elaborate on this part in bold? How does Nitrogen oxide react with soot to generate CO2 ? I'm not sure I understand this. | |
![]() | #100 |
Newbie Join Date: Jan 2023 Location: Jaipur
| Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer Good day I am planning to buy the XUV 700 Diesel AWD model. The only hindrance is that the vehicle would be idle for almost 6 months a year. Does this idle time lead to unwanted effects on DPF, etc? Thanks. Last edited by navin : 31st October 2024 at 16:54. Reason: typos |
![]() | #101 | ||
Thanked: 39 Times
Regeneration of Soot particles is an oxidation process where Combustible carbon in the DPF is oxidized to CO2. Now this reaction can occur with oxygen or nitrogen dioxide
The below Chemical equations might help you to understand this better. 1. Oxidation by Oxygen C + O2 --> CO2 2. Oxidation by Nitrogen dioxide a. NO + (1/2)O2 <--> NO2 (Happens first) b. When reacting with Carbon, first NO2 degenerates i.e NO2 --> NO + O (free active oxygen) c. C + O (active oxygen) --> CO d. CO + (1/2)O2 --> CO2 (Further Oxidation) One might ask why the Oxidation by Oxygen requires more temperature as compared to the other more complex Oxidation by Nitrogen dioxide. Because, more temperature is need to break O-O bonds on Oxygen as compared to NO2. I hope this helps. Just to get the question correct, is it continuous non-usage or intermittent non-usage amounting to six months of total non-usage. But, this should not be an issue for DPF, but other components could harm the performance of DPF. Last edited by arj2695 : 1st November 2024 at 12:10. Reason: Symbols used in equations were misrepresented. Added one more quote | ||
![]() | #102 |
BANNED | Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer I'm staying in the hilly part of the city which has steep and narrow roads which i have to travel on a daily basis. I don't have either access or usage of Highway roads where I can do 60+ on a sustained basis. Can a small diesel hatch (altroz) or a diesel csuv , (sonnet/venue/Nexon/3x0) engine handle such Daily usage without dpf errors? Asking as I'm finding it hard to manage with petrol cars, my diesel indica which is able to handle this with ease is getting old and used bs4 cars are getting crazy expensive in my area |
![]() | #103 | |
Distinguished - BHPian ![]() ![]() | Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer Quote:
![]() | #104 |
| Re: All your questions about DPF & BS6 Diesel answered by a Diesel Calibration Engineer [quote= Just to get the question correct, is it continuous non-usage or intermittent non-usage amounting to six months of total non-usage. But, this should not be an issue for DPF, but other components could harm the performance of DPF.[/QUOTE] The non-usage would be for 4-5 months continuously as I would be on my job onboard ship. |
