Part 7
13. Lower / Raise driver window with remote key
The VWs of the past used to have all four one touch windows & this feature was available from the factory. The Virtus has only driver window one touch. So, it is only possible to raise or lower the driver window from the remote key, which is sad.
Steps – - Start VCDS, after connecting to car (with ignition on) & laptop
- Click on Select button under Control Modules
- Click on 09 Cent. Elect.
- Click on 16 Security Access and enter 31347. You should get a pop-up that it is accepted.
- Click on 10 Adaptations
- Change the following channels from Not Active to Active
- IDE02021-ZV Komfort (Fensterheber)-Comfort closing
- IDE02022-ZV Komfort (Fensterheber)-Comfort opening
- ENG149202-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_oeffnen
- ENG149206-ZV Komfort (Fensterheber)-Fahrertuerbedienung_Fensterheber_schliessen
- ENG149201-ZV Komfort (Fensterheber)-Funk_Komfort_oeffnen
- ENG149205-ZV Komfort (Fensterheber)-Funk_Komfort_schliessen
- ENG149198-ZV Komfort (Fensterheber)-Komfortbedienung_global
- Select channel ZV Komfort (Fensterheber)-Menuesteuerung_Komfortbedienung_einstellbar
- Change value from Not Active to Adjustable
- Click Do It
14. Change Infotainment Screen theme color
Unlike the instrument cluser which has configurable RGB values, giving 16777216 possible colors, the Infotainment Screen just has 4 themes. Blue, Blue with different font, Red (OE) and Orange. The car comes configured with Red from factory. Coming from Fiat, I chose Orange. I then had to go back & tweak the instrument cluster (part 2, sl# 4) to try and match the colours.
Steps - - Start VCDS, after connecting to car (with ignition on) & laptop
- Click on 5F - Information Electr.
- Change value of channel ENG248479-function_configuration_hmi-Skinning to 3
- Click Do It
Final outcome. I have reduced the brightness all the way down, as that is how I like it
15. Enable Off Road Menu in Infotainment Screen
This displays Wheel angle, Altitude and Oil Temperature. Here is how to enable it
- Change value of channel ENG117566-Vehicle menu operation-menu_display_compass to Activated
- Change value of channel ENG117568-Vehicle menu operation-menu_display_compass_over_threshold_high to Activated
- Change value of channel ENG117732-Vehicle function list BAP-compass_0x15 to Activated
- Change value of channel ENG117733-Vehicle function list BAP-compass_0x15_msg_bus to Comfort data bus
- Click Do It
Here is what it looks like. Also displays Coolant temperature as a bar on the LHS and Fuel as a bar on the RHS of the screen
16. Enable Sports Menu in Infotainment Screen
This displays Turbo Boost, Engine RPM and Vehicle Speed. Here is how to enable it
- Change value of channel ENG126148-Vehicle menu operation-menu_display_SportHMI to Activated
- Change value of channel ENG126149-Vehicle menu operation-menu_display_SportHMI_over_threshold_high to Activated
- Click Do It
Here is what it looks like. Also displays Throttle position as a bar below the dials. The are two more bar displays below the TPS bar, which displays Fuel on the LHS and Coolant Temperature on the RHS. Sports is always RED, no matter what your infotainment screen theme is.
After enabling Sl# 15 and Sl#16, the dashboard display in the Infotainment screen looks like this -
17. Enable Controls for Climate Control in Infotainment Screen
This enables additional screens in the Infotainment screens to control the ACC. This is a multi-step adaptation.
- Click on 08 - Auto HVAC
- Click on Long Coding
- Click on Long Coding Helper
- Bowse to Byte 4 and check the box next to Display via BAP
- Browse to Byte 12 and check the box next to Operation via BAP
- Close the Long Coding Helper pop-up and click Do It on the main screen
- Now click on Done Go Back
- Change value of channel ENG117526-Vehicle menu operation-menu_display_clima_configuration to Activated
- Change value of channel ENG117528-Vehicle menu operation-menu_display_clima_configuration_over_threshold_hi gh to Activated
- Change value of channel ENG117692-Vehicle function list BAP-climatic_master_0x01 to Activated
- Change value of channel ENG117693-Vehicle function list BAP-climatic_master_0x01_msg_bus to Comfort data bus
- Click Do It
Additionally, you also get a menu under Car -> Settings, labelled
Climate. This allows you to switch between
Soft,
Normal and
Aggressive cooling modes
Please note that after making changes to Control Module 5F - Information Electr. you will need to switch off ignition, lock the car and wait for a few minutes (I wait 5 minutes) to allow the Infotainment unit to power down comepletely & reboot, for the changes to take effect.
PS: I have also enabled Tear Drop Wiping and Eco Tips display, but haven't had a chance to test them yet. Will share the details after I test them and confirm that they are working as expected.
PPS: That blue graph like thingie on the pics is the reflection from theInstrument Cluster Bezel and not any kind of adaptation
