Old 3rd March 2010, 07:50   #46
headers's Avatar
Thanked: 564 Times
Originally Posted by Otto View Post
that's why you have the same engine with different powers e.g. 90bhp and 110bhp for the same engine - the difference between the two is the size of the injector bores.
take another example - the maruti swift DDis, Tata Manza, Fiat punto and now ever the Grand Vitara Diesel all use the same fiat engine but are with different power ratings. Care to explain that?
I can explain that, but not on the forum.. There are a LOT of subtle differences in the same engine doing duty in these cars and thats why each of them is different in driving.
headers is offline
Old 3rd March 2010, 10:34   #47
Otto's Avatar
Thanked: 109 Times
I'm really glad you came to a point of "The subtle differences" - the same engine with a different power rating due to the size of injectors, transmission, even turbocharger or fuel pump. That's what would make up the subtle differences, wouldn't they?
Otto is offline
Old 3rd March 2010, 11:04   #48
tsk1979's Avatar
Thanked: 23,489 Times
Just because an engine can take twice the stress and power momentarily, does not mean that it can do so at sustained intervals.
for example take the 1.4L Tata dicor.
The engine can easily run at 90bhp sustained. Its designed for that kind of power and torque.
However, if tata tuned the engine to 90bhp, it would shorten the life of the clutch and transmission, so its detuned to around 70bhp.
Same is the case with these boxes. If you are occasionally flooring the pedal with such boxes, its fine, but if you drive with pedal to the metal sustained, it will shorten the life of the components.
tsk1979 is offline
Old 3rd March 2010, 11:22   #49
mobike008's Avatar
Thanked: 17,153 Times
I have been driving pedal to metal for last 15,000+kms with a Pete Box fitted to my Viva CRDi. It is an interesting thought that these boxes shorten the life of the components.
These 15K kms have been pure bliss, substanstial increase in HP and Torque and absolutely no change to FE.
However, the biggest issue with a pete box is excessive smoke emission. It's almost a bloody embarrassment. Hope these box manafacturer find a solution to cut short this smoke emission.
Has anyone done above 50K kms with a box? Come to think of it, who has done maximum kms with a box fitted?
mobike008 is offline
Old 3rd March 2010, 13:16   #50
Otto's Avatar
Thanked: 109 Times
yes, wearing out of related components are a factor, but you can always put in a performance clutch. I was actually just focusing on the engine only. There have been problems with clutches in car engines tuned to a much higher rating, but then again, we're only talking about the tuning box ,aren't we? that kind of increase in power is negligible as compared to increasing the size of injectors, ECU remap, high performance turbo that people subject the same engine to.
The engine still never takes twice the stress in all it's lifetime. That maximum stress is still very much within the safe working limits, unless you overdo something in which case it will go to "limp mode" or as bad luck would have it - a blown engine. Lot of reported cases here, so now, for every engine there are prescriptions to what you can actually take the maximum power upto without ruining the engine and it would almost definitely include a different clutch, brakes, air intakes, turbo, exhaust etc. etc.
Otto is offline
Old 3rd March 2010, 15:24   #51
tsk1979's Avatar
30% increase in power is not "little bit". These tuning boxes can result in the engine outputting 30-40% more power and torque. This puts stress on engine components as well as other components like clutch, gearbox, transmission, differential etc., etc.,
On the other hand, things like free flow, K&N filters have just 2-5% gain if you actually test it on the dynamo.
tsk1979 is offline
Old 3rd March 2010, 15:29   #52
headers's Avatar
Thanked: 564 Times
Well Otto Boy:
We aren't..atleast I am not talking only theoretical engine bit, BUT THE CAR in WHOLE..and Practically.
And whats the point of a Tuning Box if it cant carry the car to that speed
At one point, there is discussion on what tyres provide better grip etc and now you say we are talking only engines
headers is offline
Old 3rd March 2010, 17:04   #53
Otto's Avatar
Thanked: 109 Times
Well Otto Boy:
the car in whole with a tuning box or with additional mods?
I've only been focusing on the topic of this thread for the fear that someone might issue a kickban for going OT.
Anyway, the idea of a tuning box is to improve the engine power at the lower bands. You want a faster car, it's obvious you have to go through a lot of other structural not to mention safety modifications for that kind of modification. That topic can be reserved for elsewhere. Be glad to elucidate on this.
the topic of tyres had NOTHING to do with tuning an engine. Someone was talking about fouling the wheel wells(arches) on his car. I naturally assumed he was lost.
Otto is offline
Old 3rd March 2010, 23:48   #54
ph03n!x's Avatar
Thanked: 6,165 Times
Well, if you re-read my entire post, you would probably see sense
In case it still does not, here is a short form - not all cars ( of the same manufacturer, model and batch) are made the same. Some have a higher tolerance, and some lower. The tires fouling in my car is an example for that.
Where there is a variance in tolerance, manufacturers tend to play it safe - especially on engine and transmission.
I don't think moderators here would unreasonably give a warning / infraction / ban on anyone. I may be comparatively new to the forum, but I have spent time reading threads and seeing moderator actions to understand how things work here, and from what I have seen only extreme cases gather moderator's ire - that too after warnings. Most of how things work here are covered in the ground rules.
ph03n!x is offline
Old 4th March 2010, 00:08   #55
kpzen's Avatar
Thanked: 1,883 Times
1. IIRC, Peter has an Accent CRDi which has clocked 150k kms and still flies ,i'm told
2. Tadukuttan's Elantra has 100k + with the dabba.
3. A Non-tbhpian from Goa has done 80k on Getz
4. Akshay's Innova has done 45k
5. My Getz has done 40k
kpzen is offline
Old 4th March 2010, 00:13   #56
Akshay1234's Avatar
Thanked: 12,914 Times
mine has done 60k, passed 45k a while ago.
Akshay1234 is offline
Old 4th March 2010, 09:49   #57
Otto's Avatar
Thanked: 109 Times
Well then, if you read the reply to that post, you'd also see that the problem with your car was unique, and that size of tyres could easily be used without any fouling. The problem was specific to your car alone.
Otto is offline
Old 4th March 2010, 10:19   #58
Thanked: 852 Times
I've been using a tuning box (not pete's, sorry, I found that they were only the marketers and not designers of the the T/B and were charging WAYYY more than a TB available and just shipped across)
I always thought that the maps would be detuned for Indian conditions (heat, fuel quality, etc). Are you sure they are just acting as importers/distributors and not actually tuning the maps in any way?
pranavt is offline
Old 4th March 2010, 10:52   #59
headers's Avatar
Thanked: 564 Times
I too believe they are just distributors and do NOT tweak the maps.
The only indian ECU remap / piggyback guy is Race Dynamics Karthik of Bangalore fame. He is a member of this forum
He can tweak your ECU as you would want.
headers is offline
Old 4th March 2010, 12:27   #60
mobike008's Avatar
Thats fabulous. Do you guys too have the smoking issue? If yes, have you done anything about it?
