Old 15th October 2008, 17:45   #31
greenhorn's Avatar
Thanked: 4,402 Times
the mHawk has VGT, so lag should be lesser then the CRDe
/me needs to find someone with am mhawk/Crde and examine the finer details of the placement
greenhorn is offline
Old 15th October 2008, 18:21   #32
abhik's Avatar
Thanked: 12 Times
There is a pic on the forum of a fellow member's mHAWK, make a search in the gallery section, its white.
abhik is offline
Old 15th October 2008, 18:52   #33
greenhorn's Avatar
now.jpg - Mahindra Scorpio VLX
this one right ?
hmmmmm
Old 15th October 2008, 21:42   #34
abhik's Avatar
Thanked: 12 Times
Yup! Thats the one.
The IC size is a decent one for the engine but an FMIC would be better suited IMO.
There has to be a good advantage point for doing that setup, apart from space.
The engine has been designed by AEL or somthing, of Australia. Same guys who designed the 2.2L engine for TATA. Infact if you match the engine specs they are VERY similar.
Only difference is that TATA has it tuned to 140BHP, probably running higher boost and Mahindra settled for 120BHP probably for efficiency and reliability.
abhik is offline
Old 15th October 2008, 22:16   #35
greenhorn's Avatar
This is what the it looks like under the indica's hood
Old 15th October 2008, 22:38   #36
abhik's Avatar
Thanked: 12 Times
One of my friend has a Turbo Indica and i noticed the air scoop back when he bought it couple of years back. Was interesting but that question always lingered, that if that scoop is actually helping much, if you ever notice the grill blocks smooth air-flow into the scoop.
Need to take a look at the Safari 2.2 VVT's engine bay. A collegue owns one maybe ill check it out.
abhik is offline
Old 15th October 2008, 23:35   #37
badboyscad's Avatar
Thanked: 477 Times
Originally Posted by abhik View Post
Was just thinking that the Indica/Scorpio/Safari/Swift DDiS all run low boost pressures due to reliability and efficiency
low boost pressure? The non-CRDe scorpio runs around 22 psi
check this out:
http://www.team-bhp.com/forum/techni...tml#post177061
Scorpio mHawk engine bay pics:
badboyscad is online now
Old 16th October 2008, 07:09   #38
greenhorn's Avatar
Thanks mate
If its not too much trouble , can i have one of the underside of the hood? Its only partially visible in the 1st pic
Old 16th October 2008, 13:08   #39
badboyscad's Avatar
Thanked: 477 Times
under side of hood:
VGT:
Old 18th October 2008, 15:54   #40
abhik's Avatar
Thanked: 12 Times
22PSI Boost.....Never imagined that! But read elsewhere on the forum that its around 17-18PSI.
My bad! Ill have to get my facts right. But the question of why such a placement of the IC still remains unanswered.
abhik is offline
Old 19th October 2008, 01:25   #41
Thanked: 726 Times
""But the question of why such a placement of the IC still remains unanswered."
forgive me for my ignorance, but such placement as in 'Good' or 'Bad'?
SirAlec is offline
Old 19th October 2008, 07:50   #42
rippergeo
Posts: n/a
would a wire mesh opening on the bonnet above the intercooler help? it would be aesthetically more pleasing than a scoop from the scorpio.
here's a thought- get an FRP bonnet made with the requisite vents for cooling, paint it black,Rice away!
preserve the stock bonnet for when you want to sell the car.
what say? Practical? or pipe dream?
Old 19th October 2008, 09:11   #43
RedMM340's Avatar
Thanked: 34 Times
check this out:
My non-crde motor runs 13-15 psi. I have an Autometer boost gauge set up on the dash which should be reasonably accurate.
RedMM340 is offline
Old 19th October 2008, 09:27   #44
greenhorn's Avatar
Rain/water and other debris entering the engine bay and damaging the intercooler is what I'm afraid of. If that's taken care of , I'm game for anything
Does adding a boost gauge involve a lot of work ? Or is playing around with the turbo's plumbing better left to people who really know what they're doing
Old 19th October 2008, 10:49   #45
Thanked: 9,054 Times
Not a pipe dream, very much practical and this is the best option. Added benefit would be lighter weight.
How do you think rain water is going to damage the intercooler?? Rain water will damage the intercooler as much as rain water will damage the radiator of your car.
Regarding debris getting stuck in between the intercooler fins. Clean the fins when it's dirty or add a fine wire mesh inside the bonnet scoop to prevent debris from getting inside.
Sankar is offline
