Old 28th December 2021, 23:20   #871
MAKMADDY17's Avatar
Thanked: 173 Times
Re: My first car: 2020 Maruti Suzuki XL6 Alpha MT Review
Thanks Shashi, it was a great pleasure meeting you today at Bangalore Airport Parking. Thanks for getting my Smartplay version upgrade done to MD0421.
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-65987bc1d4ba46fa823539cca30a7350.jpeg
MAKMADDY17 is offline   (2) Thanks
Old 29th December 2021, 15:56   #872
Thanked: 11 Times
Hello Shashi,
I want to get the engine underbody protection done for my 2020 XL6 ZETA MT. Could you please summarize the maruti suzuki genuine parts and their respective numbers. Appreciate your help in advance.
Do I need to visit the Maruti Suzuki workshop for getting this latest update? Or is it some sort of OTA update? How to check if my 2020 XL6 is eligible for the upgrade? Please guide. Thanks
Last edited by Aditya : 29th December 2021 at 19:28. Reason: Back to back posts merged
Vgrover3 is offline
Old 29th December 2021, 16:52   #873
Thanked: 295 Times
Originally Posted by Horizon85 View Post
Excellent thread @Leoshashi. This will help so many current and future XL6 owners.
Anyone in Bangalore in need of part number 72822 M 54T00 is welcome to pick it up from me, free of cost. Please DM.
I had the same issue. Only the center one fit. The left and right ones needed drilling in the body which i was not comfortable with.
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-pxl_20211227_071234581.jpg
lxskllr is offline   (3) Thanks
Old 1st January 2022, 20:18   #874
Thanked: 651 Times
Hope to meet BHPian Madtiger soon and experience the setup on his XL6.
Insulating the doors and roof.
Hi Shashi & Madtiger,
Cross posting from another thread, I thought might be relevant. This duster seems to have got the water drain channel blocked. You guys have added insulation to your doors. Hope your additional insulation in the door it does not block the water channels in any way. Do check.
https://www.team-bhp.com/forum/long-...ml#post5225050
aashishnb is offline   (1) Thanks
Old 1st January 2022, 21:57   #875
Leoshashi's Avatar
Thanked: 43,503 Times
Originally Posted by Vgrover3 View Post
Hello Shashi,
Two links which you should study in detail:
Link 1
Link2
Link 2 fixes the jugaad for front which I did using large washers.
You will get it from workshop.
Exactly why I didn't go with the floor covers. Good you didn't get floor drilled. I got front member drilled during engine guard installed only because it's a bolt on part, I can change it any day I wish. And even after a year, when I recently inspected the hole, it was as good as new with zero rust formation.
Thanks for the concern. Any insulation we have added is far away from the water drain channels. The foam which we have used is closed cell foam, which doesn't absorb water, plus any such material is outside the vapour barrier, thus even moisture touching it is not a possibility.
Shashi
Leoshashi is offline
Old 1st January 2022, 22:20   #876
MadTiger's Avatar
Thanked: 435 Times
Hi Aashishnb,
Well the door damping (sound deadening) material is applied on the outer sheet metal. The inner foam and additional damping material is applied to door cover. None of these installation come in way of water egress or ingress. I paid additional attention to avoid installation around factory mounts.
Hope this clears the confusion.
A.
MadTiger is offline   (1) Thanks
Old 1st January 2022, 22:52   #877
Leoshashi's Avatar
Drove the new Automatic Zeta XL6, and my conclusion was, the AT is not only liveable, but is loveable!
-Unlike my XL6 which had dashboard rattles from Day 1, the center trim and HU feels solid in this car. Fingers crossed. I tried pressing the center trim and it didn't creak line mine did before I fixed it. Seems Maruti has taken the feedback and worked on it.
-Due to the upgraded sound insulation my car has, the AT XL6 felt quite noisy and the traffic noise was way higher.
-The car has just 190 km on the odo, and the FE on MID is 14.3kmpl.
-There is a bit of lag but never felt the car to be slow or lacking. Gearbox drops cogs very aggressively and gives the pull required.
-We upgraded the horn to Hella Trumpet, adjusted the Headlight and Fog lamps and the boot floor lid fix was implemented. Still waiting for Alpha's OE camera.
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_180125.jpg
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_180539.jpg
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_180543.jpg
-The AT XL6 is on Bridgestone Ecopias while my car is on upsized Michelin, the difference in ride quality was quite evident.
-AT gets these two extra screens in the MID:
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_195927.jpg
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_195932.jpg
In short, the AT is a very competent package and for those who want even more comfort, should surely try it. It won't set your pulses racing but it surely won't disappoint you. Efficiency too is respectable.
Signing off with a pic of both the cars:
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-20220101_200325.jpg
Shashi
Leoshashi is offline   (29) Thanks
Old 2nd January 2022, 11:38   #878
Thanked: 101 Times
Hi Shashi, just happened to see this part number on Boodmo: 72421M73R10 and it says “Cover, Engine Under Side RH”
What is this which is available at just 180/- ?
Says compatible for Ertiga and XL6.
B-Taurus is offline
Old 2nd January 2022, 12:07   #879
Leoshashi's Avatar
They are these side flanks which are preinstalled from factory:
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-2018marutiertiga13.jpg
Leoshashi is offline   (3) Thanks
Old 3rd January 2022, 17:20   #880
k_ajay's Avatar
Thanked: 1,142 Times
Shashi
Sorry, may be just me (who isn't in tune with product updates), but when you refereed to new Automatic Zeta, is it the same 4 speed auto gearbox (that this product was selling with)? Or is the XL6 going to come up an updated AT gearbox (5 or 6 speed)?
k_ajay is offline
Old 3rd January 2022, 17:58   #881
Leoshashi's Avatar
Yes the one which came in our family has the 4 Speed AT. There are rumours that future Marutis will get K15C engine with 6 speed AMT option, let's see if the XL6 gets it or not. But compared to AMTs, the 4 Speed AT is far superior, number of gear ratios be damned.
Shashi
Leoshashi is offline   (8) Thanks
Old 3rd January 2022, 19:31   #882
k_ajay's Avatar
Shashi
Thank you for the clarification, Leoshashi. As a flag bearer owner of the XL6 experience, I got 1 more query to ask. How effective is the air blower housed in the roof, for 2nd and 3rd row?
In hot summer months, will family seated in 2nd and 3rd rows (when they do), be able to sit comfortably with just the air blower, without cooling coil for the 2 rows?
k_ajay is offline   (1) Thanks
Old 3rd January 2022, 19:39   #883
Thanked: 385 Times
Will be a disaster if the new auto box expected in the updated brezza is an AMT. Will be good if they bring AMT in LXi/VXi and 6 speed TC in ZXi/ZXi+
NICHE is offline   (1) Thanks
Old 3rd January 2022, 19:48   #884
Leoshashi's Avatar
Sorry but you are wrong here, It's not just a blower unit but a full fledged cooling coil made by Subros, housed on the roof. It sucks cold air from front, cools it even further and throws it to rear. This entire theory of mere blower unit was circulated by some self proclaimed Youtuber expert, which is still being believed.
I've mentioned it many times, including first page and will mention again. Here is the layout of the entire HVAC system:
My first car: 2020 Maruti Suzuki XL6 Alpha MT Review-ac3.png
As you can see, the rear cooling unit is connected to refrigerants line. The rear system is a slave unit which works only when AC is activated from front.
Throw is sufficient, it has 4 vents. I aim the outer two towards middle row passengers while the middle two vents are directed towards last row. The middle aisle in between captain seats helps, and there is absolutely no issue of cooling at rear when both front and rear ACs are turned on.
Shashi
Leoshashi is offline   (24) Thanks
Old 4th January 2022, 17:45   #885
k_ajay's Avatar
I've mentioned it many times, including first page and will mention again......
Throw is sufficient, it has 4 vents........... and there is absolutely no issue of cooling at rear when both front and rear ACs are turned on.
Shashi
Hi Shashi, well one of those scenarios where I’m quite happy to be wrong. Because a proper AC for the rear passengers, helps consider the XL6.
But you’d be surprised (or not), that even Maruti showroom guys inform customers that it’s only a ‘blower’ unit, not an AC. My friend picked up an XL6 manual Zeta (?) on Diwali day, last year. And while selling him the car and also during handing over the vehicle, the showroom staff confirmed to him its a blower unit (I had asked him to get a confirmation from them, while taking delivery).
So glad to see it is a proper AC unit. And my bad, that I couldn’t see this confirmation in the earlier pages of your ownership thread. Thanks again!
