the comfortline came with beige ?
White and Black colors come with Beige interior
Heaven blue and silver come with dark leather interior(This is dark black unlike the grey ones)
i read the spec on the comfortline included electrically folding RVMs
Yes it does come with Electrically folding RVM's that also has a puddle light.
call the "Jetty" (Yeti), or waiting for the new VW sometime later this year
Dont know if i can help you but here is my take. I started of with Yeti in mind, drove a superb and laura, then drove the Jetta and never looked back. The salesman said the new Jetta may arrive in India only sometime around December or Jan 2012. Also me and my wife never liked the front grill of the new Jetta. We just went ahead and picked the 2010 Jetta and we are not planning to worry abt new models. We get to drive a Jetta that will remain a Jetta for another few years. Its a tough decision but I dont regret it. 2012 Jetta may look even better compared to 2011 and we may keep waiting for ever.
Review continued:-
I wanted to at least drive the car on the Highway before commenting on the performance. We did a 200km drive this Sunday and here are my initial impressions.
Steering - The steering is perfect. The response is great at low speeds as well as high speed. At low speed city driving the steering is so soft and reminds me of driving a Hyundai. At high speeds the overall dynamics of the car makes you feel like you are still driving inside the city with so much ease and pleasure to operate the car. The response is very impressive even at 100kmph when you want to make the quick move towards the left or right lane.
Seats - Seats are very comfortable. Lumbar support only adds to the sitting pleasure. Head rest is pretty good and is not too far back from the seat. One need not strain too much to maintain the straight neck position one needs to compromise on the view to rest ones head. Seats come with storage compartments and overall feels very snuggly. Has lots of legs space.
Visibility - The car is quite easy to operate with very good overall visibility. The A pillar or the C/D pillars do not hinder drivers view of the traffic. One part that is completely difficult to judge is the rear of the car. On highways it’s never a problem But while parking the rear of the car requires some getting used to, to understand the distance from the driver.
On the highway the rear view mirrors combined with the side mirrors provide enough coverage of the traffic around to make your moves safe and steady.
Front seats storage space.
Rear Seats
Engine - The performance of the engine is already reviewed across the web. All I can say is the engine always feels like there is lot left in it. Even at 100 you can be sure to surge ahead with very little effort giving that extra confidence to complete your overtakes or quick jump out of the traffic. The engine is quite from inside. At 100KMPH the engine spins at around 1800 RPM. This translates to one of the smoothing rides at 100kmph. In comparison the same feeling sinks in, in my swift VDI at around 75KMPH. Cruising at 100-120 does not feel like pushing the engine. At any point you are almost always below 3000RPM. Unless one consciously pushes the engine beyond 3000 RPM driving madly at lower gears I don’t think anybody can perform the gradual running in for this engine. The power is well packed that one hardly needs to push this car. For enthusiasts it could be a different story. For most of us the engine has everything one needs to work around in the city or do a highway trip with very little effort.
RPM and Speed
Fuel efficiency
Note:- These are very initial impressions. More on oil consumption and maintenance to follow. Transmission - The 5 speed transmission definitely feels adequate. A sixth speed is not required unless one needs to do consistently over 120KMPH for a long period of time with very little noise from the engine. This would only help run the engine at lower RPM to achieve those speeds. The gear ratios are almost similar to swift. There is an indicator in the display unit that advices one to shift down or shift up based on the speed/rpm and this is definitely accurate. One can definitely follow the guide to downshift. Up shifting is based on the needs. The gear shifting is smooth and easy.
Suspension - The suspension is on the stiffer side which is a known fact. How does it translate daily commute is what I can give here based on my 600km experience so far. The stiffer suspension is a blessing driving inside the city. The car glides over bad roads. At appropriate speed nothing filters into the cabin. There is no wayward body movements while riding over speed breakers(should I say body roll). There is a distinctive "Thud" if you drive a little faster over these bumps or speed breakers. The ground clearance is not an hindrance so far. I take almost all the known roads inside the city and I may have avoided roads that may test the suspension and GC. On the highway the ride is almost like gliding. The imperfections in roads like uneven flat surfaces causes a very mild shake. It’s not even noticeable to my wife. I am just being picky here. There is absolutely no body roll at 100kmph. Taking those curves and flyovers at 100kmph is very safe and easy. There is not even a single situation in the highway where you feel like driving at 100kmph. The suspension holds fantastically well taking the car around the corners with ease. The confidence one has can be compared to driving any car at 50kmph around those corners.
Brakes - Brakes are very assuring. The power the car carries needs to be supplemented with good braking system. The brakes hold the car in straight line all the time. I have only driven up to 120kmph and braking at that speed slows down the car fantastically well with no signs of struggle or worry. Brakes just adds lots of assurance to the drive, that one can be absolutely safe cruising at 100kmph (provided other drivers are sane and driving safe like us).
Ride quality overall - Personally five stars. The car is superbly build that no external sound/noise filters into the cabin. This includes the oncoming traffic and the bad roads that usually send all sorts of noises into the cabin. The air-conditioning system works really well with air-75 and v-cool films adding more protection from the sun. The sound system blends well with the cabin. Storage space is more than adequate to carry the “munchables” and drinks. Cruise control is a blessing these days where there are more open roads. The chances of sleeping inside the cabin while riding is more due to the perfect ride quality. At 100kmph the car drives like a dream with exceptional ride quality and cornering ability. The Car always stays in ones control and eats highway with so much ease and grace. The suspension is set really well to enhance cornering and never once did I feel to take my legs of the pedal while taking a sharp corner or overtaking a truck around a corner. The car stays in its track at speeds upto 100kmph as I did not exceed that speed.
more to follow after this........
