Old 7th September 2008, 12:09   #16
khan_sultan's Avatar
Thanked: 6,469 Times
Originally Posted by aadix View Post
hey khan,
i dont think the pcd is the same for the gypsy and the safari/scorpio and if they do fit, max value for the alloys would be about 8 to 10k.
Ok. so what would be the PCD for the Gypsy?
Would 16 " 114.3 PCD alloys fit in the Gypsy? (I know they are 16" and not 15")
Cheers,
khan_sultan is offline
Old 7th September 2008, 12:41   #17
PatchyBoy's Avatar
Thanked: 2,161 Times
Khan,
AFAIK, it will not fit.
Gypsy - 139.7 pcd
Safari/Scorpio - 160pcd
Sorry to spoil your party.
Cheers,
Rajan
PatchyBoy is offline
Old 7th September 2008, 12:49   #18
Originally Posted by PatchyBoy View Post
Khan,
Gypsy - 139.7 pcd
Cheers,
Rajan
Rajan,
I had a look at Aura's website and they have alloys for scorpio that have the PCD between 139.7 - 160.
See the pictures below.
Question: Is the same wheel ok for PDC between 139.7 - 160 OR does this mean that in the same pattern you get these alloys in the PDC ranges from 139.7 - 160?
Old 7th September 2008, 13:04   #19
Samurai's Avatar
Thanked: 49,769 Times
That means this particular design is available in both 139.7mm and 160mm PCD, it is not a range. So you can't use former scorpio/safari alloy.
Samurai is offline
Old 7th September 2008, 13:18   #20
ohhh.. that helps..
have to think of some other innovative ideas now to see what wheels can go in the gypsy that will take 235+ or 30x tyres.
Old 10th September 2008, 09:52   #21
Now where in Bangalore can I get my hands on these alloys (mentioned in first post of this thread) for my Gypsy? I don't mind if they are old/new.
I would need 8 or 8.5J 15" size.
Cheers,
Old 10th September 2008, 11:31   #22
Thanked: 322,103 Times
Khan_sultan, these three-spokes are a very common design for Jeeps & Gypsies. Any large tyre shop will be able to source them for you. A set of 5 new should cost you <20K.
GTO is offline
Old 10th September 2008, 12:21   #23
Samurai's Avatar
Shahnawaz, the wheel rim width depends on the tyre size you are planning to put. The 8.5J is really high, it is more appropriate for tyre width of 275mm or more. What tyre size are you thinking?
In addition, you need lot more room in the wheel arch and wheels will be much heavier. If you had boatload torque like CRDi engine that wouldn't be an issue.
Samurai is offline
Old 10th September 2008, 13:05   #24
Sharath, I will be putting in atleast 30x9.5 or most probably 31x10.5 tyres. So 8J is what I need at least. I know this will require mods to suspension/wheel arches etc, so that all will be done. no issues there.
I also know that the heavy wheel + upsizing will have a -ve effect on torque but I will address that through other mechanical mods that I have planned.
Old 10th September 2008, 14:44   #25
Samurai's Avatar
For 31x10.5 size, 8J should be fine. I am looking for 7J since I don't want to go beyond 235mm for the tyres. I remember somebody telling me it is better to undersize the alloys widthwise for off-road purpose. If the alloy is too wide it might start hitting the rocks and get damaged.
Samurai is offline
Old 10th September 2008, 15:07   #26
lohithrao's Avatar
Thanked: 226 Times
Khan bhai, why dont you try with Iyengar and sons, Indiranagar. i think i saw a semilar looking rim there.
lohithrao is offline
