Closed Thread
Old 23rd November 2005, 15:01   #1
Raps's Avatar
Thanked: 35 Times
Alloys & Tyre for Swift
Dear All,
I am planning to upgrade my Swift VXI to 15" Alloys. I am bit confused after the market search being made on these Alloys & Tyres, whether should I go for 14" / 15" Alloys. I have some doubts if I go for 195/60/15 -
How will the ride quality & comfort would be?
After the extensive research made & calculations, I zeroed in for 185/65/15. But I am not able to find the tyres in Bangalore for this ratio. So I decided upon 195/60/15, but the offset for 15" HR alloys is 7J. But the normal stock tyres come with 5.5J.
Is this offset OK, 7J?
Please do share their experiences from Swift guys who are having these profiles fitted.
Thanks a ton in advance.
Cheers,
Pradeep
Raps is offline
Old 23rd November 2005, 15:39   #2
islandman's Avatar
Look No further
http://www.carbibles.com/tyre_bible.html
The above link would provide you all answers you need.
Enter the current tyre specs and select new tyre specs that you may want; check to see that the Difference in circumference iswithin 3%.
After which check the rim sizes supported for that tyre size also available in the link.
Check It First!
If you decide to fatten up the tyres on your car, another consideration should be clearance with bits of your car. There's no point in getting super-fat tyres if they're going to rub against the inside of your wheel arches. Also, on cars with McPherson strut front suspension, there's a very real possibility that the tyre will foul the steering linkage on the suspension.
islandman is offline
Old 24th November 2005, 08:57   #3
Thanked: 31,442 Times
Please check else where in forum where this query has been posted
http://www.team-bhp.com/forum/showth...ighlight=swift
Thread closed
ajmat is offline
Closed Thread
