Originally Posted by Sheel How is Marengo doing? I am sure it is over 1,50,000 kms. Services/part replacements? Running on Michelins or they wore out?
TIA  |
TIA (Thanks in Anticipation) - That is quite analogous with the typical higher ups in organisations asking politely to initiate action against a request!!
Have no other choice, but to comply!!
So here goes the response.
Marengo is now at around 144.5k. The complete service/part replacement detail is in-line with this post.
Marengo is still running on the Michelins (for Approximately the past 47k) and somehow, they haven't yet earned their first puncture. Though on that part, its purely luck, because my daily drive is usually littered with nails from the various Puja Pandal's, construction shuttering work etc (either they have become more conscious or I have been actually taking care).
Tyre aging is quite consistent, with uniform wear. They performed quite optimally at the recently concluded OTR at Jharkhand/Messanjore, on red soil and some slushy inclines. Highway performance is great (for the mileage) both on wet as well as dry. It is to be noted that the other tyres Marengo has had till now, were all at the trailing end of their life by this milestone. None of the other sets have been subjected to the variety of terrain that these LTX AT2's have sailed through. Yes, some noise have crept in, thats normal, can live with it. However, no steering vibrations even at the upper reaches of the speedometer on this vehicle.
Now coming to the Expense items since the last update at 106800kms
Have put down the expense opportunites alongwith the main items of interest at each such encounter.
25-Apr-15 111053kms Rs 49369.91
Main items
Lower ARM LH – Rs6260
CV Joint – Rs 38601
(It must be noted that on one of the earlier posts, I did mention about Marengo having lost power to its front end, the result of which it was needing momentum to conquer the inclines, hence the "airborne" pic from Samba)
25-Jun-15 120524kms Rs 29079.45
Main items
120k service
Ball Joint Assembly Upper ARM (pair) Rs. 1,442.
Lower Ball Joint (pair) Rs. 1,442.
Bushing Upper Arm (set) Rs. 884.
Bush Lower Arm (pair) Rs. 682.
Front Shock Absorber Rs. 1,572.
Link Stabiliser Bar RH Rs. 639.
Link Stabiliser Bar LH Rs. 737.
Needle Roller Bearing Assembly front Rs. 506.
Outer Balljoint (pair) Rs. 1,578.
20-Jul-15 121582kms Rs 16418
Main items
Alternator – Rs16673
(Alternator charge malfunction indicator in the instrument panel)
14-Oct-15 125521kms Rs 1660.77
Main items
General 125k check
Particle Filter HVAC Compact 471.43 Rs. 495.00
Fog lamp bulb 540.95 Rs. 568.00
07-Mar-16 135822kms Rs 13976.8
Main items
Vacuum Modulator EGR Rs. 1,977.
KIT Pads BIL Rs. 4,115.
Parking Brake Cable W ABS (Pink Cover) Rs. 506.
Relay Wiring Kit Rs. 1,200.
(Check engine light in instrument panel)
17-May-16 137782kms Rs 16048.89
Main items
Reg Elect Front Door LH Rs. 3,060.
Motor Windshield washer RR Rs. 608.
Sensor Wheel Speed Front (Pair) Rs. 3,988.
Battery Rs. 6,305.00
(ABS malfunction indicator in Instrument panel)
15-Jul-16 143086kms Rs 20438.12
Main items
140K Service
Bush upper link chassis (4) Rs. 1,416
Bush lower link axle Rs. 1,552
intermediate shaft assembly RHD Rs. 3,667
(A little directional levitation from the vehicle overall)
So the total maintenance expenses from the start of this post is Rs 146992.
Adding to the previous total of Rs 119252, the total maintenance expenses till date stands at Rs 266243. Cost per Km at Rs 1.86 per km.
However, please note, this represents extreme usage and the fact that the vehicle is out of warranty now. Has seen many trips to places with Gruelling roads and countless OTR's.
So concluding this post with some pictures of the intervening period. This thread wasn't too active, but no lack of action either from the Protagonist of this thread!
Marengo at Spiti
River Bedding at Chitkul
Chilly, Pir-Ki-Gali, on the Mughal Road
Basking in the Moonlight, with the Mt Kanchenjungha in the Background
Some pics from the OTR'S (All conducted by the legendary UBS Sir's "Kolkata Offroaders" group)
The "Table-top" shot by the famous bhp-ian Samba
Yes the front axles work! Pic courtesy a friend "Suprabhat Bandyopadhyay"
The oblique descent right after "Table top", Pic courtesy another friend "Debasish Bose" of "Kolkata on Wheels" Magazine.
Marengo after a recently concluded Messanjore OTR with slushy inclines on Red soil
The Journey continues!!
