| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | LinkBack | Thread Tools |
| | #31 (permalink) | ||||
| BHPian Join Date: Aug 2008 Location: Bangalore
| Quote:
Below link provides all the details that you are looking for to replace the audio system! Octavia-vRS.com - MFD2 Install Guide Quote:
I think if you search on tdiclub forum you will find some details. Quote:
| | #33 (permalink) |
| Under Boost Pressure issue resolved! Blame it on Rat!! It is interesting when you visit your *** with enough data to show them and what I experienced was amazing! So I go there at the service station in the evening, and the response? Sir.... leave the car, we will check and get back to you tomorrow. That didn't happen in my case! So had called up Mr. Patil and reached there in the evening, Mr. Patil was busy (expected, towards closure of business time), a service engineer is assigned, and a curtsy, SA: "What is the problem you are facing with the car sir?" Me: Let me show you..., pulled up my lap top, showed him first the VAG reading (where Boost Pressure Control: Pressure not reached was displayed) SA: Sir, we will check... it may be because of some dust or some thing, sensor might have logged it... Me: I don't think so.. Let me show you some thing more! Pulled up the graph that I had handy! rpm, boost specified and actual all plotted from 2 cars, see previous thread)! Me: This is not a one of problem, I have an issue of Under Boost pressure! Boost pressure never goes beyond 1200 mbar! Seems like a problem?? SA: Yes sir, we will check, but now I cannot say anything more to you sir... you seem to know it very well.. Me: Not really... can you check following? 1. hose pipes connected to EGR is OK. 2. EGR and turbo are OK? SA: yes sir I will check, we will let you know by tomorrow evening... Me: What? No way, it doesn't even take 15 min to check the hose pipe connections... If this is not a problem with hose pipes, I'm not going to leave my car here anyway... SA: Yes sir, we will check... And then again a VAS (Skoda authorized diagnostic machine) testing is done and everything seem to be OK is the verdict by the mechanic who attended... stupid... Me: Can you please check around EGR valve please? there must be either a hose pipe that has come out or loose... And then what he reveals! 3 hose pipes are completely cut by some RAT!! And the dent? Rs. 859/= on the pocket... but a big relief... It would have been a nightmare if it was turbo/EGR problem... By this time, had a good chat with Mr. Patil and we went for a test drive, while I logged the Boost pressure again today! and suddenly every thing seemed just alright... After this, i did feel smoother acceleration compared to before and felt little more powerful like before... Good that my Laura is back and fit again within 2 hours of visit to ***, can you believe it? Lesson: Gathering knowledge about the problem upfront helps get the problem sorted out quickly! OK What is EGR? - Exhaust Gas Recirculation valve. Below details gathered from internet! The EGR valve, or Exhaust Gas Recirculation valve, is a vacuum controlled valve which allows a specific amount of your exhaust back into the intake manifold. This exhaust mixes with the intake air and actually cools the combustion process. Cooler is always better inside your engine. The exhaust your EGR valve recirculates also prevents the formation of Nitrogen related gases. These are referred to as NOX emissions, and are a common cause for failing emissions testing. Unfortunately, your EGR valve can get stuck, causing NOX gases to build up. You'll know if your EGR valve is stuck or malfunctioning because your car will experience symptoms like rough idle and bucking on acceleration. Last edited by anandbhat : 25th October 2009 at 21:58. Reason: Added pictures and graphs |
| | #34 (permalink) |
| Well, some experiments done!! And the out come? 1. ORVM heating enabled! It is nice... Need to get in the rains to really test it though! 2. Coming home and leaving home enabled! This is quite cool - headlight comes on when you unlock the car for 10sec so that you can see surroundings! - headlight comes on when you switch off the car and open the door to get out! - All this only when it is dark 3. A sound system that adjusted itself to leather upholstry 4. Both Rear fog lights turned on (it is only driver's side that goes on when you switch on rear fog lights) Sounds cool right? It is fun infact!! One can also do following things: - Anti-theft activation - Remote locking/unlocking can be changed to blink+honk or just honk. Default is just blink So just plug in the VAG-COM and change few settings and you're done!! Caution: 1. Never use the absolute values given below in your car. 2. Make sure to check if any error code is generated after every code modified 3. Make sure to note down the default code and modified code (helps in reverting back if there is an DTC generated) 4. Some times error codes show up, but if you clear them, it goes away (I think this is just OK). 5. Below are only what I have tried on one car, may not be applicable to all cars!! 46 - Central conv 07 - Coding Current Code, New Code: 99801A085283007F3F04850500085F01807CA0 99801A085283007F3F04850500C85F01807CA0 Byte9, Bit-2: Comfort closing via Rain Light sensor (rain closing) inactive Byte13, Bit6: Anti Theft System activation confirmation Blink --> Changed Byte13, Bit7: Anti-Theft System activation confirmation (Horn) --> Changed Byte15, Bit0: Anti Theft system deactivated Byte15, Bit1: Anti Theft disarming only via Remote control or immobilizer Byte15, Bit2: Anti Theft active with interntional de-safe/interior monitoring inactive Byte15, Bit3: Anti Theft alrm Delay (15 sec) inactive Byte15, Bit5: Anti Theft system passive arming Byte15, Bit6: Inclination sensor installed Byte15, Bit7: interior monitoring installed Byte16, Bit7: Siren configuration blocked Byte17, Bit5: Tire Pressure Monitoring inactive 56- Radio, 07- Coding: Current Code : 0000400 New Code : 0000420 00XXX?X - 0 = No correction, 1= Sound system with cloth interior, 2=sound system with leather interior 00XXX?X - +1=Active/Rmote supplied antenna, +2=CD-changer/IPOD connections, +4= CAN-Secondary Display 09 - Central Electronics 07 - Coding Current : 41000E030004140043110D000000000000087F075C00000000 0000000000 New : E1000E031004140043110D000000000000087F075C00012000 0000000000 Byte0,Bit1: Xenon Headlights with shutter installed Byte0,Bit2: Footwell lights installed Byte0,Bit3: DRL active (scandinavia) Byte0,Bit4: DRL active (North America) Byte0,Bit5: Assistance Driving Light, Leaving Home active --> Changed Byte0,Bit6: Rain-/Light Sensor installed Byte0,Bit7: Coming Home active --> Changed Byte2,Bit4: Coming Home Mode via (0=personalisation/1=light sensor) --> If light sensor enabled, I get DTC 02390 - Control /Regulation for Ambience Lighting (E400) -- 009 - Open or Short to Ground Byte3,Bit1: Rear Fog lights (0=2 rear fog lights/1=1 rear fog light) Byte4,Bit4: Activation of both Rear Fog lights --> Changed Byte17,Bit4: Daytime Running Light via Fog Lights Byte21,Bit6: Leaving Home Variant (0=LH in LDS/1=not LH in LDS) Byte22,Bit0: Personalization (0=Variant1/1=Variant2) --> Changed Byte23,Bit5: Coming-home Logic (0=Old/1=New) --> Changed 17- Instrument Cluster: 07- Coding Current : 0002101 New : 0002101 : 00??X0X +01=Brake Pad warning, +02=Seatbelt Chime Enable; +04=Washer fluid warning I have tested these on a Laura Ambiente, and it is just fun... Imagine some customizations one can do to his vehicle, without really touching mechanically!! |
| | #35 (permalink) | |
| BHPian | Quote:
my ORVMs don't heat up and don't dim the headlamps of trailing car even though Elegance variant has these features as per the website. a check with the *** told me everything was ok and the ORVMs are programmed to heat only when ambient temperature goes below 20 deg cel. Something that will never happen in Bombay. btw, do you travel to Bombay (for business or other purposes) Anandji?
__________________ Merc ✇ E280 CDI Elegance (W211) ⎮ Octavia ⎮ Laura 1.9 2009FL Eleg A/T (first FL Laura on T-BHP) ⎮ 2xBaleno ⎮ Indica Vista ⎮ 2xZen | |
| | #36 (permalink) |
| BHPian Join Date: Aug 2009 Location: mumbai
Infractions: 0/2 (8) | 'coming home and leaving home" lights can be switch on in a laura ambient? **** that would be so AWESOME, i thought only the l&k get that feature, thats te feature i m dying for but i guess in the L&K laura the lights will only come ON in the night as the L&K has auto light asist(light sensor) which the ambient & elegance dont have, so in the ambient model the 'coming home and leaving home" must be coming on in the day too?? thanks.. Last edited by Berj79 : 26th October 2009 at 03:04. |
| | #37 (permalink) | ||
| Quote:
I now have the coming home/leaving home feature enabled on my car, without auto light assist! Quote:
--> you need to set the ORVM electric adjustment knob to defrog position. 2. To dim the trailing car's headlight, I think this works only on inside rear view mirror, and not ORVM AFAIK. 3. Typically service station guys wouldn't be knowing it... (may be they are not taught to know it!), I had checked this before to no avail, had to get myself into it when I borrowed the cable from a friend, Androdev. Akki, I don't travel to Mumbai, unless for a family function. ![]() | ||
| | #38 (permalink) | |
Infractions: 0/2 (8) | Quote:
thanks.. | |
| | #39 (permalink) |
| Yes, I could do that. Only thing that I was trying was TPM, without any success, but I think for TPM to work, it needs few mods both on the air valve on tyres, and display. Since I don't have a dot matrix display, several features that need dot matrix to work, can't be made to work. |
| | #40 (permalink) | |
| Quote:
Retrofitted multifunctional steering on vRS (a lot of pics) - BRISKODA - The Skoda Forums | |
| | #41 (permalink) | |
| | #42 (permalink) | ||||
| BHPian | Quote:
![]() 2. On the Ambiente (old and FL), only IRVM dims but on the Elegance FL, all three mirrors (IRVM + 2 ORVMs) dim. 3. How much does this VAG-COM cable cost? Where to buy? Do we need to purchase any software to run this? ![]() Quote:
__________________ Merc ✇ E280 CDI Elegance (W211) ⎮ Octavia ⎮ Laura 1.9 2009FL Eleg A/T (first FL Laura on T-BHP) ⎮ 2xBaleno ⎮ Indica Vista ⎮ 2xZen | ||||
| | #43 (permalink) | |
| BHPian | Quote:
| | #44 (permalink) | |
i got the 1.8tsi ambient as only ambient trim is available for it, i also want to get the coming home ligts feature active in my car, as i always wanted this feature & always envied L&K owners![]() thanks.. | |
| | #45 (permalink) |
| When you put reverse gear, you would not like: - ICE playing the song loud! - Do you get irritated at times when the continuous beep of a fixed frequency which, though you get cautious about the obstacle? - Volume of the parktronics beeps are too high? Here is a solution! Change following, to change the frequency of the buzz and volume! 76- Park Assist 10- Adaptation Rear Buzzer volume - default=7, New value = 4 --> Volume is now reduced! Rear Buzzer Freq - default=2, New=4, --> frequency reduced from high frequency to little lower frequency, better for ears! Another trick! Do you want to adjust the parking light brightness? Oh yes, if it is less bright, save some battery current drained, if it is less bright, increase the brightness to see your car from further distance! Change following: 09 - Central Electronics 07 - Coding Byte11, Decimal 0 to 70 changed --> Brightness reduced to 70% (front) Byte12, Decimal 0 to 70 changed --> Brightness reduced to 70% (rear) Use caution, mentioned in the previous post! |
| Thread Tools | |
Similar Threads | ||||
| The Tata Safari 2.2L technical/Other problems/solutions Thread | dadu | Technical Stuff | 1908 | 21st March 2010 14:18 |
| Skoda Laura issues/problems | ranjithbalan | Technical Stuff | 45 | 16th March 2010 11:42 |
| FFE problems and solutions | harishnayak | Modifications & Accessories | 31 | 26th December 2009 22:52 |
| Problems with my Skoda Laura. And the resolution. | ACM | Long-Term Ownership Reviews | 35 | 19th May 2009 09:58 |
| Tacho problems. Is this the solutions? | adman77 | Modifications & Accessories | 3 | 21st November 2008 16:53 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653
Caution:
