Old 21st July 2009, 19:22   #91
Blue Thunder's Avatar
Thanked: 386 Times
Originally Posted by ex670c View Post
4) Paint Touch Up - Next Week.
your steed definitely needs this pronto ! In fact , not just a touch-up, it would look awesome if it underwent a full paint job. Hope that is also in the pipeline.
Blue Thunder is offline
Old 21st July 2009, 19:44   #92
discoverwild's Avatar
Thanked: 3,650 Times
Off-Road you can feel the additional traction, but coupled with the front LSD, the steering is very hard.
Arka
Hi Arka,
Thanks for the update. Power steering, next?
discoverwild is offline
Old 22nd July 2009, 11:44   #93
vinod_nookala's Avatar
Thanked: 430 Times
Hi Guys,
The MM540XD has been upgraded in following departments.
2) 4 Core Radiator - Tomorrow (the OEM Radiator has become weak, plus I wanted additional cooling, keeping the chennai weather in mind)
3) Seat Belts - Next Week
After the re-tread and brand new tubes the Lockers are hardly noticed on road.
Arka
Well arka,
Congratulations on your successful installation of rear lockers. I guess your's is the only jeep in india to feature this.
4 core radiator is a good idea i have done it recently. My engine is running about 10 degrees cooler in city traffic @70. Hopefully it will stay at about 80-90 degrees in palar sand. Best is to go for 550 army radiator new /reconditioned even though it requires some grill modification. Next week i plan to join you for recee we can test my radiator then
wearing a seat belt in a jeep looks cool to me as many dont expect to have them I just got them fitted. Well about paint touch up just change the door colour of yours to body colour along with some touch ups on body where there are welding marks. Will do it for now. Anyhow you intend to paint it completely up next year.
Arka i suggest you to remove LSD from you front diff as you already have rear locker. The marginal advantage that you get with it off road isnt worth the trouble. Worst case yours is 3 wheel drive, just one wheel less with your LSD up front in a complete slippery condition. When 3 wheels are deep in mud fourth wheel traction can do little to pull rest 3 wheels out. Your recent stuck in palar is a good example.
The advantage -
1. easier steering- You will not end up breaking it
2. tighter turning radius- the main moto of changing to current set up
You can offset the disadvatage of no LSD up front by better set of tyres which you are already planning to up grade to.
vinod_nookala is offline
Old 22nd July 2009, 11:52   #94
star_aqua's Avatar
Thanked: 92 Times
I think Suresh's JEEP also features this?
star_aqua is offline
Old 22nd July 2009, 12:01   #95
ex670c's Avatar
Thanked: 2,007 Times
Power-Steering
The advantage -
Hi Vinod,
You are making fun of my front LSD, wait till I convert to Power Steering and Front Locker.
I have OKBJ Front unit, why not a Power-Steering upgrade.
Even in 2WD road use the steering becomes demanding with the Lockers, even the turning radius has reduced from under an I10 to Lesser than Ford Fiesta .
Will go in for a set of Mud-Terrains as OTR Set
Arka
PS - Suresh has a Auburn Gear LSD.
ex670c is offline
Old 22nd July 2009, 12:10   #96
Thanked: 430 Times
Now this is fun!!:-)))
Hi Vinod,
Powersteering? Wasnt that for non macho people? Anyway power steering makes sence as you already have required mechanicals for that setup. Will definately make life easier.
Well, so when is your A/C upgrade happening? Doesnt rear locker and front locker combine generate enough heat inside the cabin? Arka is finally getting civilised ...hahaha:-)))))
Old 22nd July 2009, 12:22   #97
ex670c's Avatar
Machismo & Heat
Hi Vinod,
I decided to leave the mantle of machismo, no contenders here.
The Lockers generate less heat compared to the LSD.
I'm saving the A/C mods for a Bolero/Armada Grand Project.
Arka
ex670c is offline
Old 22nd July 2009, 12:37   #98
Thanked: 430 Times
Arka
Woww this is news to me. I thought you were begining to work on CJ500 NGCS project. I can imagine what you intend to build on NGCS Armada Grand platform alreadyGood luck. Hope to see it by next palar.
Old 22nd July 2009, 14:06   #99
Alfa_Kilo's Avatar
Thanked: 13 Times
@Arka
You could install hub locks in the front to reduce wear on the LSD. They will make a small difference to the steering too.
Alfa_Kilo is offline
Old 22nd July 2009, 14:39   #100
ex670c's Avatar
Free-Wheling Hubs & LSD
Originally Posted by Alfa_Kilo View Post
@Arka
Hi Abhimanyu,
I learned that the hard way in March 2008, destroyed a front short axle, and then fitted a FW Hub.
In November 2008, the FW Hub was fitted to the OKBJ Axle.
Arka
ex670c is offline
Old 22nd July 2009, 16:24   #101
ram.west's Avatar
Thanked: 28 Times
OT: Hey arka! what happen to you 1 ton project?? Any updates??
ram.west is offline
Old 22nd July 2009, 23:15   #102
Alfa_Kilo's Avatar
Thanked: 13 Times
Hi Abhimanyu,
Arka
Ok, but dont go for a locker on the front axle even with FW hubs. When turning on a hard surface, the locker drives only the inside wheel. This will cause a lot of steering problems with massive torque steer and pulsation due to the non CV joins in the axle. It will also make things very interesting on black ice. Se if you can get 30 spline shafts imported...
Old 23rd July 2009, 10:15   #103
ex670c's Avatar
Front Axle
Hi Abhimanyu,
In 2WD mode with FW Hubs the lockers will not create any problem.
But in 4WD it is as you mentioned.
The Auto-Lockers are Dog-Clutch LSDs, or very aggressive LSD for straight line driving or very Slow LSD for turning situations
Any particular reason for 30Splines? The Selectable Lockers are expensive and not worth the headache, Installation and then custom axles, cost as much as MM540.
Arka
ex670c is offline
Old 23rd July 2009, 17:51   #104
Alfa_Kilo's Avatar
Thanked: 13 Times
The Lockers, strictly speaking are not differentials, as they do not distribute power between the two wheels. The locker 'unlocks' one (outer) wheel during a turn and lets it spin faster (effectively freewheeling) than the crown gear. It makes the vehicle one wheel drive during a turn, hence the understeer (inside rear wheel pushing against the turn). On a slick surface, like ice, when the inner wheel overcomes grip, there could be very violent (spectacular for some) transition from understeer to oversteer.
A locker on the front axle may make turning very difficult offroad.
Old 24th July 2009, 14:58   #105
ex670c's Avatar
Nice Explanation
Hi Abhimanyu,
Nice explanation, will be careful in icy conditions.
When the JEEP had two LSDs, the steering is not very hard off-road, but with a rear locker and front LSD, its very hard.
Arka
ex670c is offline
