Old 8th July 2010, 17:38   #31
crazyjeeperk's Avatar
cool my friend.. you really have some interesting things here. looking forward for more pics of your progress. congrats for your work
crazyjeeperk is offline
Old 8th July 2010, 19:12   #32
Thanked: 705 Times
Nicely documented. Good going friend!
Another thing I forgot to tell you is that the oil filter will foul with the steering link rod. You will have to use a smaller filter (Isuzu).
jyobeb is offline
Old 8th July 2010, 20:14   #33
Jassy1313's Avatar
Thanked: 979 Times
Impressive but if you are going with such an engine then why so simple mod?
May be you will land up doing something really amazing, but still try something different..
BY THE WAY IS THIS FOR YOUR OWN OR CUSTOMER'S DEMAND?
Jassy1313 is offline
Old 8th July 2010, 21:15   #34
Ricky_63's Avatar
Thanked: 520 Times
Reading about all these nice (wonderful is more apt) builds, gets me all worked up & I WANT to own one such off road monster.
Being totally unaware of this side of the automotive world, may I ask what a 550 with a Scorpio Engine & the works cost ??
Very interesting thread !! All the best for your build
Ricky_63 is offline
Old 8th July 2010, 23:03   #35
1100D's Avatar
Thanked: 4,117 Times
Are the BA10 and the NGT 530 equal in length? From pictures though, it does not appear so.
1100D is offline
Old 9th July 2010, 11:59   #36
randeep04's Avatar
Thanked: 22 Times
Hey Allan, Great going man. Another amazing Jeep project from your side.
Looking forward to the finished product.
Cheers !!!
Randeep
randeep04 is offline
Old 9th July 2010, 12:21   #37
sreerajunnithan's Avatar
Thanked: 13 Times
Allan, i don't know if you realized, but you hit a jackpot with that Borg Warner Manual TC. Now you can have OEM Fully floating rear axle from Bolero without tampering your prop shaft angle!!!! Same goes for front axle also. How did you source it? You are second one who has this TC after Jyobeb!!! All MWB Jeeps are handicaped for a FFRA only because of that offset rear differential (Unless you do some modifications).
--Sree--
sreerajunnithan is offline
Old 9th July 2010, 12:47   #38
Thanked: 76 Times
sree,
most of our fully floating rear axles comes with 19 spline
diff locks for this is very difficult to source
i might retain the semi floating axle for now but get the diff shifted to the left offcentre as compared to where it is now(right)
i have a 30 spline difflock lying, and im dying to use it
sourced these throught a lot of finding and calls
xtreme power is offline
Old 9th July 2010, 14:34   #39
Thanked: 13 Times
Originally Posted by xtreme power View Post
sree,
Allan if you are talking about Manual Diff lock like Gurkha, i agree with your point. I am really skeptical about lockers in semi floating axels. Considering you have a military axle, it should be better, i heard they are much stronger than Civilian ones.
Second point, instead of shifting your diff to left, why don't you use a T-18 transfer case (I know its old tech)? I have a T-18 mated to BA-10 in my Jeep.
--Sree--
Old 9th July 2010, 15:15   #40
Red Liner's Avatar
Thanked: 19,315 Times
--Sree--
And to further clarify, Sree's jeep is a MM550 (like yours).
Red Liner is offline
Old 10th July 2010, 20:28   #41
Thanked: 76 Times
well the borgwarner is imho a better transfer case,
i just removed the axles and differential from the right offset 550,
also purchased the left offset diff housing
shall assemble this tomorow
since im doing all this hands on, i must im super excited
shall post pics later tonight
Old 11th July 2010, 17:46   #42
Thanked: 110 Times
Rear Disc Brakes
Hi Allan,Great Going
Why dont you come out with a rear disc brake (all 4 disc) version in this one??
Should be possible right?
joshguy is offline
Old 11th July 2010, 21:42   #43
Thanked: 76 Times
left offset differential is ready
only left to fit in the axles
pictures tomorrow when i get some free time
cant believe i worked on a sunday
thanks arka for the unintentional push
Old 12th July 2010, 17:44   #44
Thanked: 76 Times
the old diff orientation of the 550
the 550 differential removal along with the axles
xtreme power is offline   (1) Thanks
Old 12th July 2010, 17:45   #45
Thanked: 76 Times
the two diff housings
550 and 2wd 540 with the axles
the assembly into the 540 diff
the new orientation
