Old 26th September 2012, 22:35   #1
Thanked: 305 Times
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Hello guys !!
It has been a year my ground pounding machine was dismantled. The car could not take the beating lots of stuff came loose...the roof was torn apart here is the pic of the same !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-dsc_0979medium1.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-dsc_0980medium1.jpg
And also the car was 6 years old already. So had to sell it off before I have to give away for scrap rate !!!!
Anyways I have bought a new car again, Maruti Swift as I had lots of stuff still which could be changed/replaced without any issue and I know the vehicle inside out.
Here are few pic of the car in raw shape.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-car11.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-car21.jpg
Have done vinyl of the Hood, Roof and boot, along the a-b-c pillars of the car. Few pics...
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-car31.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-car4medium1.jpg
List of Equipment
Source -> Kenwood KOS-A300
Processor -> Alpine PXA - H 701 With controller
Amp for High -> ????
Amp for Mids -> ????
Amp for Subs -> ????
Highs -> ?????
Mids -> ????
Subs -> SMD 18 inches #59 and #60
Alternator -> Mechman 220 amps
Batteries -> Northstar NSB 170 (about 600+ ah combined )
Wiring -> welding copper cable 0/1 and 0/2 runs with copper busbars
Rca -> Sommer cable with Neutrik Connectors
Enclosure -> 1 inch MDF with lots and lots of Reisn (approx 15-18 kgs with 5 kgs glass...solid as rock)
The weight of the car is 1010 kgs. Will take the final weight when the install is complete !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120915_180528medium1.jpg
low_bass_makker is offline   (6) Thanks
Old 26th September 2012, 22:49   #2
Thanked: 305 Times
Re: LBM`s Groundpounder V2.0 !!!
Ok then, the first upgrade the HO alternator. I have the Mechman 220 amps alternator so plan to use it for the time being, will add another when the setup is complete. Planned to use approx 10k+ rms this time. I know this alternator would be a bottle neck for the same but still....here are few pics...
The stock one was 70 Amps only...
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120913_112145medium1.jpg
The both alternators.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_114351medium1.jpg
The sizes were a little different so had to machine the arms to make the alternator fit...here are few pics of the same...
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_114339medium1.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_114329medium1.jpg
Machining being done to match the stock alternator dimensions
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_124222medium1.jpg
The other side !!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_125036medium1.jpg
The machining was done on a FLOOR BORING MACHINE !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_124248medium1.jpg
Cover after machine.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_130559medium1.jpg
After assembly !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_131601medium1.jpg
0/1 gauge wiring connected !!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_133933medium1.jpg
The location !!!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_131631medium1.jpg
Installed !!!.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120915_141650medium1.jpg
Checked , up and running !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120912_154457medium1.jpg
All the removal , dis-assembly and re-assembly, re-install was done myself !! Except the machining for that I had the machine operator !!!!
low_bass_makker is offline   (10) Thanks
Old 26th September 2012, 22:58   #3
Thanked: 305 Times
The car interior stripped !!!
Continue....
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120913_144943medium1.jpg
Base size check !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120913_185411medium1.jpg
Base installed..Could not add more bolts in the front because of the fuel tank underneath. Will hold it from the front at the later stage
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120914_181256medium1.jpg
Rear wall mounting support !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120914_182715medium1.jpg
The enclosure will be filled with resin and glass fiber and that to lots of it to make it strong !!!
Back wall installed
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120914_193201medium1.jpg
From the front, Back wall !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120914_193106medium1.jpg
This install cannot be done without this !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_123138medium1.jpg
Side walls mocked up !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_124233medium1.jpg
Setting the base up !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_130242medium1.jpg
Driver side installed
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_131422medium1.jpg
Left Side !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_131438medium1.jpg
Both Sides !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_140243medium1.jpg
Old 26th September 2012, 23:23   #4
Thanked: 305 Times
Port layout made !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_144243medium1.jpg
Mocked up before fitting !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_145032medium1.jpg
One side done !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_145539medium1.jpg
The other side mocked up !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_151549medium1.jpg
Fixed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_151608medium1.jpg
I will be using blockers (closing port vents) to tune the enclosure !!! I have tuned the stock one close to 32 hz, and can go as low as 22 hz still with port area of 7.6 sqinch per cuft !!!
Port inside the enclosure !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_153735medium1.jpg
Mocked up at position !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_154241medium1.jpg
Installed and checking for bracing options !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120916_174120medium1.jpg
Finally planned to go this way, one soild one inside..Marking done !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120918_220654medium1.jpg
Cutting done !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120918_222455medium1.jpg
Installed
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120918_223300medium1.jpg
Further bracing done for more strength
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120918_234112medium1.jpg
Fiber work coming up next along with CNC Laser cut amp rack !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120919_175043medium_zps322f18951.jpg
Old 26th September 2012, 23:52   #5
Thanked: 305 Times
These two are going in this ride !!!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-401032_4184486904818_951162138_n_zps3d931.jpg
Along with this !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120920_185822medium_zpsff6a13621.jpg
Resin work done !!!! It is as solid as a rock !!! Looks it will sound tight !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120920_175441medium_zpsf36576121.jpg
Trimmed and ready to install the front baffle. The front baffle will be 2 inch thick !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_011913medium_zps85d534981.jpg
The amp rack base mocked up !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-amprack_zpsa9c425031.jpg
Finished and ready !!! The batteries and the copper bus bars will be going underneath the same !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_000622medium_zpsf56965671.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_000633medium_zps359dd67b1.jpg
I will be using this method to install the subs. I cannot think of any other which can handle the weight of the sub (75lbs-34kgs each) !!! Also the same will be reinforcing the whole wall for added strength !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-25708_1298288831670_5143391_n_zpsa36264a1.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-25708_1298288751668_7373602_n_zps6ade24a1.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-25708_1298288791669_7575149_n_zps3ed4a401.jpg
As you can see in the pics I have done this in the year 2007 !!! Long time back !!!
The rings placed to take marking.
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_143214medium_zpsdc940e201.jpg
One hole cut !!! Perfect fit in the iron ring !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_151446medium_zpsb64369a01.jpg
Both holes cut, Checking the subs holes are okay !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_152943medium_zps01d9d7de1.jpg
Mocking the rings and the sub
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_153303medium_zps437e7f911.jpg
One sub installed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_171510medium_zps1667b9d91.jpg
Other beast waiting to be installed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_171820medium_zpsdaa3bdcd1.jpg
Both done and the rings are also screwed in so that they remain in place when we install the front face of the enclosure !!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_181434medium_zps82389ded1.jpg
Face ready to be installed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120922_182528medium_zps2088dadc1.jpg
low_bass_makker is offline   (9) Thanks
Old 27th September 2012, 00:01   #6
Thanked: 305 Times
Front Baffle inside the ride !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_012210medium_zps1793766e1.jpg
Installed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_143448medium_zps931adbf01.jpg
Fellow Ice lovers helped me a lot in installing these subs !!!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-helpers_zpscd7c7f901.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_154621medium_zpsed8236de1.jpg
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_154214medium_zps4067eea41.jpg
One installed !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_154208medium_zpsd9da87b91.jpg
Both done !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120923_154836medium_zps8d5739de1.jpg
So finally presenting the WALL !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-20120924_180716_zps5830ff8e1.jpg
Lots of work has yet to be done on the front face of the wall !!! More pics coming up !!!
low_bass_makker is offline   (7) Thanks
Old 27th September 2012, 00:05   #7
Thanked: 305 Times
More details on the cooper busbar coming up next along with the battery details
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-busbar1.jpg
Total of four (4) will be going in !!! Other two will be arriving soon !!! At least I will fire up the setup with these two !!! One more thing I need to add here is that the batteries are 5 x 12.5 x 22 inch in dimensions (very odd size) and each battery weights just 58 kgs !!! (58 kgs x 4 = 232 kgs) !!!
For those who need info about these here is a link of the same ...
http://www.northstarbattery.com/batt...blue/index.php
These are not the normal wet type lead acid battery it is a sealed one with AGM technology these batteries are used by pros worldwide !! And these are not designed in USA, They are MADE IN USA !!!
LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)-battery1.jpg
low_bass_makker is offline   (16) Thanks
Old 27th September 2012, 20:47   #8
Thanked: 300,940 Times
re: LBM's Ground Pounder V2.0! EDIT : Windshield cracked (Page 7)
Thread moved from the Assembly Line to the Sound off & Show off Section. Thanks for sharing!
GTO is offline   (1) Thanks
Old 28th September 2012, 00:16   #9
SJD@NewDelhi's Avatar
Thanked: 226 Times
Looks cool until we get to hear the roar of the devil By the way, it would be nice if you included the cost for the whole setup and the time it consumed until completion of the project?
Cheerz!
SJD
SJD@NewDelhi is offline
Old 28th September 2012, 01:37   #10
ghpk's Avatar
Thanked: 211 Times
That's some devil kind stuff inside a Hatch !
The Sub Itself looks to be heavier than my weight.
I am sure one would be able to feel the music from C.P. to Lajpat Nagar :-)
I wish I could be close to your place to assist you and get first hand experience with such extreeme I.C.E. Stuff.
Hats off LBM Sir Ji.......
ghpk is offline
Old 28th September 2012, 02:44   #11
Thanked: 305 Times
Cost I have not calculated but it would a big one !!!
It took me about 20 days to reach at this stage, a day or two I will able to fire it up !!!
Thanks for such kind comments !!
Each sub weights about 35 kgs. I have also done a weight check again. The weight of the enclosure is approx 70-75kgs, that is wood and fiber work only !!!
low_bass_makker is offline   (3) Thanks
Old 28th September 2012, 04:50   #12
nitrous's Avatar
Thanked: 325 Times
Good stuff, LBM.
What have you planned to do to the cars mechanicals to handle the massive increase in weight?
The rear springs and damper selection is important there's a drastic weight increase there. If you run stock damper, you will need new rear dampers every month.
I would suggest Swift diesel springs+struts up front and Dzire springs+dampers at the rear. This is the farthest you can go with OEM stuff.
nitrous is offline   (2) Thanks
Old 28th September 2012, 07:38   #13
blackfire_9's Avatar
Thanked: 191 Times
Congratulations on the new ride & the fresh ICE setup. Must be a whole lot of fun, especially since you will be getting a setup after a gap of one year
I have only heard & seen videos of your previous car on TeamBHP/Youtube, but it would be great if I can actually witness the "Ground Pounder" in person some day. Good luck with the install
blackfire_9 is offline
Old 28th September 2012, 08:29   #14
ghodlur's Avatar
Thanked: 4,207 Times
OMG LBM, thats some real heavy stuff in your car. Would love to see the Ground Pounder after the completion.
BTW how much weight is expected to be increased due to the ICE? Also will it be legal on the road..
How is the rear view vision being planned due to the wall?
ghodlur is offline
Old 28th September 2012, 08:51   #15
Thanked: 7 Times
Very interesting thread, i will stay tuned for more updates, LBM are those steve meade designs subs? any specific reasons for choosing those over other spl subs, one other thing when you alter the existing power/ charging system does it effect other electrical equipments like AC, bulbs etc do share in detail if you can and please do clean the car after the install,
makanaka is offline
