Old 20th May 2006, 16:42   #1
Knight Rider's Avatar
Thanked: 28 Times
Help required in changing the HU
My present setup is Jvc kdg305 Hu, sony 4 channel amp, pio 800w sub, and 2 pio450w speakers, Planning to change the HU, The one that I have in mind is pio6850 retailing at 8800 in Bangalore.
Suggestions required
Knight Rider is offline
Old 20th May 2006, 16:45   #2
jkdas's Avatar
Thanked: 1,497 Times
Budget kya hai. Wht do u like abt ur music. Want another amp? Want dolphins? Or rpm meter?
@8.8k teh 6850 is fine. I was quoted a bit more at Tvm.
jkdas is offline
Old 20th May 2006, 16:48   #3
Thanked: 28 Times
Thanks Jk. Budjet is 9k. Not a fan of dolphins tho......... I like deep bass mostly listen to trance.
Rpm meter???
Old 20th May 2006, 17:22   #4
Bass&Trouble's Avatar
Thanked: 137 Times
Rpm meter???
Just changing the head-unit isn't going to drastically enhance your listening experience. Though the 6850 will give you the ability to control your sub better than the JVC.
I think the Pioneer 800W that you mention is a DVC. If you aren't doing this already, try driving the 6x9s just off the rear channels of the head unit, and use the bridged outputs of the Sony amp to dedicatedly drive your sub. And maybe get a front component set at some later time. Then you can get a monoblock for the sub, and use the 4 channel to drive all 4 speakers. Add some nice snazzy cables, and you're ready to rock.
Well almost, cos then we'd express displeasure about your sub and rear speakers and then you could go out and change them too. At the end of it all, we'd all be a very satisfied bunch of blokes here at the community to have relieved someone of a ****load of cash, all in the name of gratifying car audio.
P.S. You don't have to take everything I say around here very seriously. No one does, and it's been better for them that way.
Bass&Trouble is offline
Old 20th May 2006, 17:50   #5
Thanked: 28 Times
That's a really nice writeup bass & Trouble, Liked it very much.
I have bridged the channels right now.. so it drives the sub as well as the speakers, I just completed a reinstall from audiofusion in bangalore, Got custom enclosures for the speakers and ported enclosure for the sub, the cabling has been changed with the fuse. Really neat stuff. No vibrations at all
Old 20th May 2006, 20:46   #6
jkdas's Avatar
Even I may get a Pio 6850 sometime later.
jkdas is offline
Old 20th May 2006, 20:56   #7
Thanked: 28 Times
Jk, What was the RPM meter about????
Can you change the dolphins to something else in a 6850?? Also do you think I should drive my 6*9's direct from the HU and buy two component speakers and drive them using the amp??
Old 20th May 2006, 21:08   #8
jkdas's Avatar
8850 has a rpm meter screen saver and hence.
http://www.team-bhp.com/forum/car-en...-look-out.html
I thought you had an amp! Yup, drive the compos frm teh amp and the 6x9 frm the HU. Bridge the other 2 channel for sub.
jkdas is offline
Old 21st May 2006, 16:53   #9
Thanked: 28 Times
Well, After getting all the feedbacks, I am planning to put one more amp and two component speakers as well, What would you guys suggest? Entry level only.
Suggestions please
Old 21st May 2006, 17:12   #10
jkdas's Avatar
Suggestions please
which car?
6k compos + 5k amp +2k instal (and rca ) = 13k max
u can get it done within 10k if u can source a good amp for less tahn 4k. Good RCA woudl cost 750/cable. Maybe you may need only one.
jkdas is offline
Old 21st May 2006, 17:17   #11
Thanked: 28 Times
Alto, Jk, Spoke to anwar in auto fusion, told me 4300 for the amp and 2600 for the speakers, and 8800 for the HU
RCA wiring has been done already , All entry level sony two channel amp and jbl compo's
What do you think?
Old 21st May 2006, 17:29   #12
jkdas's Avatar
whT 2600 for compos? For 4300 you can get 4 channel sony 504!
jkdas is offline
Old 21st May 2006, 17:56   #13
Thanked: 28 Times
Emmm. I think I got confused between the Two, Shoud be the other way around..
Working on a sunday can have an effect on your brain I guess...
Old 21st May 2006, 18:09   #14
jkdas's Avatar
If its for compos and amp and if teh price is teh other way round ! spendid.
jkdas is offline
Old 21st May 2006, 18:23   #15
Thanked: 28 Times
Do you get any other amps with that price?? and how does sony amp and jbl compos sound??
