Old 25th May 2007, 11:54   #76
Vid6639's Avatar
Thanked: 44,154 Times
Why do you want video? Are you planning to sit in the parking lot and watch movies since you are going to be self driving?
Why not just get a decent pio/kenwood HU with USB at the same price?
Or wait you want video so you can get away with the LCD at home.
Vid6639 is offline
Old 25th May 2007, 12:00   #77
Thanked: 306 Times
Thank you so its final
JVC HU(USB DVD DIVx Giga mp3) 9K
AMP JBL 75.4 12K
Compo 607C 6K
Sub 12" JBL + custom box : 6K
Wiring shiring : 2K
Total cost = 35K
Budget is bust : So no sub initially, sub comes later...
Now I think this thread can be closed.
Ya it is a good setup add the sub later......till then close the thread or more confusion is on the way....like Vid posted why need for VDO Hu....
low_bass_makker is offline
Old 25th May 2007, 12:01   #78
tsk1979's Avatar
Thanked: 23,494 Times
Navin ji please close this thread.
As for Video, what if I get bored while driving? Delhi traffic all buses and trucks very boring.
On this note lets close this thread
tsk1979 is offline
Old 25th May 2007, 17:47   #79
navin's Avatar
Thanked: 9,988 Times
Baba, aap bhi moderator hai! (BTW what is the Hindi word for moderator?) Aap bhi is dhaga ko bandh kar sakte.
Thread closed.
navin is offline
Old 4th June 2007, 23:24   #80
tsk1979's Avatar
Reopening this thread.
I listened to a setup
1. Kenwood CD player(Some expensive CD player without any features)
2. JBL 75.4
3. JBL 12" sub in a aftermarket box
4. GTO 607 Compo in front
I did not like it.
The setup sounded very flatty and bassy.
Sub gives good bass, and tweeters give good treble, but inspite of flat settings on the HU, the guitars sounded deadish.
The base was a little too much.
Currently I have some lousy sony explode coax in rear. The amount of base they give is very bad as far as sound quality is concerned, but slightly less than the sound level I need.
So I am wondering whether I should go for a sub, or go for some very very good Coax in the rear which will give me better base than my current sony Xplode and also play out the 300Hz range bass guitar base.
The subwoofer kindof made the base guitar lousy and the base was all drum base. The slighly higher frequency base was lost. I did not like it at all.
I think a brigher combo will be better for rock.
So how about the best coax under 5K(Grey for rear) and some compos better than GTO 607 for the front?? Please help :(
Amp, same 75.4 should do.
tsk1979 is offline
Old 4th June 2007, 23:55   #81
aseem's Avatar
Thanked: 443 Times
2. JBL 75.4
I did not like it.
Well you never mentioned what kind of box it was... my guess is, that it was ported, thus the bass was overpowering. A good MDF sealed enclosure would give you ideal bass, and kick, without overpowering your mids...
aseem is offline
Old 5th June 2007, 00:13   #82
navin's Avatar
2. JBL 75.4
I did not like it.
Sub gives good bass, and tweeters give good treble, but inspite of flat settings on the HU, the guitars sounded deadish....So I am wondering whether I should go for a sub, or go for some very very good Coax in the rear which will give me better base than my current sony Xplode and also play out the 300Hz range bass guitar base....So how about the best coax under 5K(Grey for rear) and some compos better than GTO 607 for the front?? Please help :(
the significant difference between a pair of 6x9s and a 12" sub is that the 6x9s will not play as loud and wont go as low. In some way the 6x9 might have more attack and will provide more output at say 300Hz. a Sub is only intended to be used below 80 Hz or so.
The system you heard might not have been tuned or installed properly. The sub might be producing more BOOM than tight bass.
Ideally your front speakers shoudl be doing all the work around 300Hz.
navin is offline
Old 5th June 2007, 00:41   #83
iraghava's Avatar
Thanked: 281 Times
What car did you hear this in Tanveer? That also can make a lot of difference apart from the already mentioned Box type.
iraghava is offline
Old 5th June 2007, 08:25   #84
tsk1979's Avatar
This was a speedonlines swift. I think that is supposed to be a very good install.
tsk1979 is offline
Old 5th June 2007, 08:49   #85
hydrashok's Avatar
Thanked: 19 Times
The Swift must have been tuned for the janta taste. I too think it must have been:
1) Bad/Erroneous box design for the sub
2) Bad tuning
3) Both of the above.
Because the equipment mentioned is good, and has been proven in other installs, in fact in the same combination. (Except maybe the Kenwood player -- which we must not fault). And show/demo cars rarely sound good. Yes, I know this is a funny statement as these cars are meant to sell the goods, but with the exception of my installer's personal car, I'm yet to listen to a shop's demo car that sounds good to me. And even my installer's car starts sounding less good to me when the car is setup for demo use in a show.
In your case, getting a good pair of 6x9s and amping them with the 75.4 does sound like a good idea. Unless you want pretty deep bass, the 6x9s should give you the thump and low-end you need. If you're getting GTO 607c in front, go for GTO937s in back. You can always get a sub later and use the (rear channels of the) same amp if you want to.
It could be that you prefer a kind of sound different from that of the kind that the GTOs produce. Listen to other brands if you can, and see. GTOs are great for rock, and that is why I think you should try them out in a proper install. I don't think it would be difficult to get to listen a BHPian's setup with GTOs installed in Noida?
hydrashok is offline
Old 5th June 2007, 10:40   #86
tsk1979's Avatar
I am not cribbing about the sound quality really.
The bass was good, the treble was good. From accuracy and cleanness, even the midrange was good.
But the midrange lacked punch.
In a drum there is this large circular drum on the floor for "boob" and real low sound, and 3 or 4 small drums which are hit by sticks.
In any nice rock song the small drums are very very important, and their sound is like a "tak". That punch was lacking.
Even the vocals in that frequency range(may people can call it screaming) sounded dead.
It was all clean, but the front components failed on the midrange and low midrage(just above bass) response.
Treble was done good by tweeters, and the low base was taken care of by the subwoofer, but the midrange died.
In my indica I have 2 6" and 2 4" and they handle the midrange and top end pretty well but start "breaking" if too much bass is there.
tsk1979 is offline
Old 5th June 2007, 11:04   #87
gunbir's Avatar
Thanked: 33 Times
Tanveer, you have champagne taste on a beer budget. The dynamics you want arent really available at the price point you are looking at. Consider raising the bar and listening to some more expensive stuff.
gunbir is offline
Old 5th June 2007, 11:14   #88
PRADEEP KUMAR's Avatar
Thanked: 29 Times
Folks,
Do we have any expert BHPian in Chennai on ICE installs? just to look up the install we have and advice.
Cheers.
PRADEEP KUMAR is offline
Old 5th June 2007, 11:23   #89
tsk1979's Avatar
Can afford only beer, Hence the 30K budget.
I am willing to sacrifice on the low bass front to get a nice clean mid range and upper bass. If the current setup can't do that. I am willing to part with the subwoofer for now!
tsk1979 is offline
Old 5th June 2007, 11:29   #90
iraghava's Avatar
Thanked: 281 Times
Not likely since the box was made by JB himself according to the specs of the woofer (JBL GT4-12).
iraghava is offline
