Old 8th October 2009, 16:25   #1
vigneshnr's Avatar
Thanked: 195 Times
Upgrading ICE on i20 - lot of doubts !!
Hi
I've booked a i20 magna in bangalore. I love thumping music with good bass.
I've a opinion that OE ICE wont be as exciting.. so the dealer suggested some add ons
1. JBL 12" Sub woofer - JBL GT5-1204BR - 10k
2. 4 ch amplifier - JBL GT5-S644 - 5k
3. Connector unit - 4k
(The prices are just indicative)
I'm a complete novice in this matter.
I've some doubts
1. Will this configuration complement the OE system?
2. Is this woofer over powered to shadow the speaker output ?
3. I've taken a 4ch amp - (in case in future i need to use up for better speakers) can i route the output to the OE speakers itself instead of adding any more.
4. Is this connector a necessity ? It is quoted as expensive as a amp.
vigneshnr is offline
Old 9th October 2009, 00:34   #2
Invinsible's Avatar
Thanked: 62 Times
Originally Posted by vigneshnr View Post
Hi
I've some doubts
First of all let's hear what's your overall budget. Secondly, OE speakers are not rated good enough to handle the power from the amplifier. There are many options that one can figure out. Most common one would be to upgrade the front speakers to 2 way components, add a sub and a 4channel amp for the same. If you need rear fill you could always shift the front speakers to the rear and power them with the HU.
Invinsible is offline
Old 9th October 2009, 04:00   #3
abhinav.gupta88's Avatar
Thanked: 341 Times
1. No it wont.
2. Yes, it will
3. you can but they might be damaged, they are not designed to play on amps.
4. Yes, if you wish to retain the HU.
What i would advice is if you want to retain the hu, change the speakers 1st ( atleast front), add a sub a 4 channel. ( you'll need the line-in convertor)
However the sound quality wont be too good if some local line convertor is used.
What you'll need is a good convertor or change the HU.
abhinav.gupta88 is offline
Old 9th October 2009, 07:16   #4
vigneshnr's Avatar
Thanked: 195 Times
- my budget is around 20k.
can u suggest speakers to go for in this case. How good is the amp & woofer suggested?
Old 9th October 2009, 07:23   #5
vigneshnr's Avatar
Thanked: 195 Times
Originally Posted by abhinav.gupta88 View Post
1. No it wont.
2. Yes, it will
Oh my god.. I would've ended up in disaster. I want to retain the HU. Can u suggest any line-in converter.. (also speakers)
Are the woofer/ amp good ones ?
Old 10th October 2009, 21:40   #6
vigneshnr's Avatar
Thanked: 195 Times
Hi
this evening i got a call from the showroom.. tat my car has arrived..
reached there.. highly excited.. Gleaming Black.
Finally installed this config.. thanks to the Gurus - Abhinav & invinsible
Front 2 components - JBL GTO608C
retained the rear door stock speakers.
Sounded awesome for me.. will take delivery on monday
Old 19th October 2009, 20:31   #7
thegame's Avatar
Congrats Vignesh! That setup will give you enough thump. Was the sub installed in a sealed box?
thegame is offline
Old 19th October 2009, 22:10   #8
navin's Avatar
Thanked: 9,957 Times
4k is a bit much for a pair of speaker level to line level adapters.
Well done. That was fast.
navin is offline
Old 20th October 2009, 09:44   #9
Sound_Affects's Avatar
even 10k for the JBL GT5-1204BR is on the higher side.
Sound_Affects is offline
Old 20th October 2009, 13:22   #10
rudrah's Avatar
Thanked: 48 Times
Congrats on the car and ICE setup.
How much you got the JBL GT5-S644 Amp for, with B/W or w/o?
rudrah is offline
Old 28th October 2009, 12:11   #11
vigneshnr's Avatar
Thanked: 195 Times
Thanks, yes it comes in a sealed box.
Thump is awesome.. AR Rehman.. Fat Boy Slims.. Black Eyed Peas playin LIVE and traffic woes just disappear.
India JBL
Old 28th October 2009, 12:15   #12
vigneshnr's Avatar
Thanked: 195 Times
Thanks.. Overall i managed some discounts. But happy for the service levels of the showroom guys.
Old 28th October 2009, 12:22   #13
vigneshnr's Avatar
Thanked: 195 Times
its with b/w as i picked from the dealer. I got a overall bargain on the package.
Amp would be 4.5 k i suppose
Old 31st October 2009, 21:46   #14
sohail99's Avatar
Thanked: 235 Times
I have booked i20 Asta(o)
and was just looking to replace the stock component speakers(Rear)
Budget - Approx 10K
Which ones would be best as replacement components?
PS - Don't want any Amp or anything for now!
will do a full ICE overhaul later!
sohail99 is offline
Old 31st October 2009, 23:32   #15
DerAlte's Avatar
Thanked: 2,920 Times
Not sure you have expressed it right:
* Are you sure the i20 comes with components in the rear? If at all, they are usually coax!
* Why would you want to replace rear speakers and not the front? If you will do the driving, and not sit in the back seat, one would expect you to replace the front speakers with better components
* Infinity, JBL, Blaupunkt, Illusion, Bull, ... any of these brands you will be able to get a pair of components AND a pair of coaxes to replace all the stock speakers in the i20
DerAlte is offline
