Old 18th July 2020, 16:27   #46
Rakshith220's Avatar
Thanked: 23 Times
Re: DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio
Originally Posted by noelnelly View Post
After reading through many posts I got to know the Cabin Air Filter is missing in my Honda Amaze and I was tired of the fine dust particles on the dashboard, the foul smell and sometimes dust and smoke entering the car when on fresh air mode. I searched online and found that the cabin filter meant for the Honda City Type 3 or the Old Jazz is compatible with the system on the Honda Brio/Amaze/Mobilio.
Went to the auto parts store and bought the same on the condition that I will come and return it if it didn't fit, he knows me well so he agreed. He specifically asked me not to damage the packaging which is understandable.
The printed MRP was Rs.400, he charged me Rs.350.
My car is currently 2 years old and has some 24k+ kms on the odo.
It was a simple 5 minute DIY job. Depicted here as follows.
Removing the glove box is really simple.
Just push the top on both sides inwards and pull it out. It comes right out.
Attachment 1443268
There are two other hinges at the bottom, all you got to do is pull it out.
Attachment 1443269
Things required.
The Cabin Air Filter.
Attachment 1443270
Attachment 1443271
Attachment 1443272
Cutter and Small Screw Driver/Tester.
Attachment 1443273
Once the glove box is out of the way, the box in question was sealed, so take the cutter and cut any 3 sides, I cut the bottom and the two sides.
Attachment 1443274
Use the small screw driver to open the flap and insert the Cabin Air Filter.
Attachment 1443275
Attachment 1443276
Close the flap and put everything back. Your work is done. Now enjoy the fresh air without worry.
Thank you.
Can you kindly post the dimensions of the cabin filter so that it would help us to purchase correct product! Thanks in advance!
Rakshith220 is offline
Old 18th July 2020, 20:45   #47
Reinhard's Avatar
Thanked: 18,120 Times
For which car are you looking to change the filter? Why not simply procure the OEM spare part from Boodmo.com (unless its unnecessarily pricey over there).
Reinhard is offline   (1) Thanks
Old 19th July 2020, 16:49   #48
Thanked: 23 Times
Already ordered from there yesterday thank you for your concern!
Rakshith220 is offline   (1) Thanks
Old 8th November 2021, 19:17   #49
Installed the cabin air filter today on my brio. These are the parts purchased:
1. Filter element:
https://boodmo.com/catalog/part-elem...lter-38623878/
DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio-filter.jpg
2. Lid
https://boodmo.com/catalog/part-lid_blower-6700893/
DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio-lid.jpg
This is how it looks after installation. The lid gives it a clean look.
DIY: Adding a Cabin Air Filter to the Honda Brio / Amaze / Mobilio-afterinstallation.jpg
0XC0DEB055 is offline   (2) Thanks
Old 8th November 2021, 20:24   #50
bj96's Avatar
Thanked: 1,552 Times
Originally Posted by 0XC0DEB055 View Post
Installed the cabin air filter today on my brio. ...
Excellent update and Thanks for sharing the links. You meant the lid fits nicely cutting off the blind plastic piece on the blower box or it needs some wiggling in? I see two end clips on the lid- do they just click fit on the channel?
Thanks in advance.
-BJ
bj96 is offline
Old 8th November 2021, 21:57   #51
I cut off the plastic piece entirely and removed it, but I think the lid should fit even with the plastic still intact. There's plenty of clearance between the inside of the lid and the filter.
Yes, they just snap into place.
0XC0DEB055 is offline   (1) Thanks
