Old 24th May 2024, 21:48   #46
Thanked: 432 Times
Re: DIY: Get Android Auto in any Car/Bike for Free (or under 10k)
Please note that the ambient air temperature and the temperature of an object exposed to direct sunlight in that same atmosphere can be very different.
Your temperature probe is away from direct sunlight so would be measuring a temperature that can potentially be a LOT (say by over 5-15 degrees) different than the top of the dashboard thats exposed to direct sunlight for a long time.
Just something to keep in mind during hot summer dries I suppose...
Transmission is offline
Old 24th May 2024, 22:42   #47
dkaile's Avatar
Thanked: 9,090 Times
That photo was taken for convenient comparison with the ambient temperature showing in the speedometer. I had also placed the temperature meter just below the Tab on the dashboard, for a prolonged period of time (15 minutes plus) and did not find the huge deviance you are talking about. The temperature, there too, was hovering around the 25~26 degree mark in the air conditioned car. Also maybe the tab placement in my setup is quite away from the windshield and just above the AC vents, with no direct contact with the dashboard, that it remains so cool and worked with zero issues from morning to night, in this extreme heat. Just for your information.
I also find this lack of trust, from some members, quite amusing, as this is the first time in my life that I am using a Tab and am quite surprised with it's ease of use and am trying to post as unbiased a opinion as possible for my setup. Perhaps people really have had very bad experience with Tabs in the past, maybe due to improper placement in the vehicle or having left it in the sun for too long in a parked car, that it is difficult for them to believe that this solution can really work with proper placement and usage.
Cheers...
dkaile is online now   (1) Thanks
Old 24th May 2024, 23:20   #48
Thanked: 432 Times
You shouldn't assume nobody has experience with these things though
I just mentioned since I have had some (okay a bit more than some) experience with something similar in the past - with cameras (mostly turned off, sometimes turned on) and knowing how hot their surface gets (just like the dashboard surface) can get even when not in use after a couple of hours in the sun, and how that heat does seep into the batteries inside them with time.
I have seen this effect be very noticeable after 2-3 hours of driving under the hot sun in my go pros (black), phones (silver, black), my dashcam (black) and finally on my own hands and legs when the sun is on them while the AC is at the lowest settings and its chilly inside... So much so that I now occasionally blast air via the front windscreen defogger outlets onto them to keep them cool when in active use (only the go pros need that though, and they are known to get hot under use even outside of a car to be honest).
Parking under the hot sun - even for a quick 30 min lunch break - is a whole another can of worms.
I think most phones (and probably tablets too) have temperature sensors inside them (developer options > Power monitoring for example) that you can also use to get a temperature measurement from inside the device (which again wont be the peak temperature, but it may be a good data point for you)
Anyways, all is well if you are happy with the setup. Stay safe
Old 24th May 2024, 23:34   #49
dkaile's Avatar
You shouldn't assume nobody has experience with these things though :
Absolutely not buddy. I am also trying this for the first time in my life and learning as I am going along from feedback such as yours. So I am now a little perplexed, as to why I have had a trouble free experience so far, if what you and some others have tried to point out about the heat. Maybe it's early days for me. Or maybe my 12 year old Superb has extra high quality UV cut glass that it is keeping the interiors so cool, or the soft rubberized dashboard top has very little heat absorbing qualities. Or my Tab is mounted at least 18 inches away from the windshield mount. Or it's just above the AC vents keeping the Tab cool. Even the aluminum back of the Tab was quite cool even after 2~3 hours of usage. Or I haven't left my tab in a parked car under direct sunlight and never will.
So, I too am learning, please do not get me wrong.
Cheers...
Old 25th May 2024, 23:20   #50
Thanked: 432 Times
No worries
I think it might have something to do with the positioning of the tab you have - maybe its got just enough airflow to keep it cool (all my issues were when there was no airflow on the device) - or it could also be the glass as you surmise.
If your tab is cool to the touch after a couple of hours of usage in the sun, then I dont think anything I said earlier holds since its clearly not getting heated up in your case...
Transmission is offline   (1) Thanks
Old 26th May 2024, 10:33   #51
Self Driven's Avatar
Thanked: 214 Times
So got the tab hooked up with suction cup type holder. The suction is strong and good enough to hold the 9" tab in place
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img_20240526_100644.jpg
Fixed the tab to the rectangular magnetic holder with the given metal plate slid between the tab and the transparent cover of the tab
Tab attached and Android auto working in map and music windows
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img_20240526_100506.jpg
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img_20240526_100943.jpg
This set up is strictly for the OCD people who remember that the tab is in harsh sun and take it up along with them when exiting the car as much as possible or put it in the glove box
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img_20240526_100751.jpg
Self Driven is offline   (3) Thanks
Old 27th May 2024, 21:26   #52
Joe367's Avatar
Thanked: 549 Times
Cheers...
I can see how this could become handy in many situations. But I have left my car in open area way too many times - in hospitals , at church, shoping markets. I've had phone overheating and turning off, air freshener melting into dashboard etc😅. Also carrying around a tab is too much of a hassle for me.
Joe367 is offline
Old 27th May 2024, 21:50   #53
TorqueIndia's Avatar
Thanked: 2,977 Times
My 8" tab setup too working fine, tried the headunit reloaded app again after seeing you guys and its working very well for wireless Android auto connectivity.
Also I'm having the carlink kit for apple carplay, which works seamless too.
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-pxl_20240526_100032203.jpg
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-pxl_20240526_095833944.jpg
Here is a short video on the setup :
TorqueIndia is offline   (1) Thanks
Old 28th May 2024, 12:24   #54
BikerKeeda's Avatar
Thanked: 384 Times
I was thinking of sharing same post, I have been using Samsung A8 tab in my Bolero Neo. (Purchased it from Dubai for 8000 INR)
I was not in favor of changing the stock system because I like the stock look (Personal Preference). So I decided to get a tab with sim slot and use it as infotainment system.
I used 2 magnetic mounts above the stock screen which looks neat when Tab is not attached to the dash, and I have the metal plates pasted on the tablet cover on top left and right side.
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-whatsapp-image-20240523-2.28.09-pm.jpeg
Magnet Mounts perform fantastic and has good hold, it has not given me any problem till now, on road as well as off the road.
Link: https://amzn.in/d/4F8lACy
I wanted to use the built in speakers, mic and steering mounted controls for my phone so I connect the phone to the stock system via bluetooth so I can answer the calls on the go.
I have a Pagaria bluetooth adapter for my tab which draws power from built-in USB port and is connected to the system via AUX cable, so I keep AUX source selected.
Link: https://amzn.in/d/eWLWLI6
This setup looks neat and clean and gives me a freedom of even sending a tab to back seat if my co-passengers want to take control of the playlist.
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-whatsapp-image-20240523-2.28.09-pm-1.jpeg
Pros:
1- Gives me full freedom of using a tab instead of limited functionalities.
2- Very handy to use and can be easily passed on to the passengers at back seat.
3- With split screen I can use 2 applications e.g Youtube music, Google Maps.
4- Looks cool, and everyone likes the idea.
5- Stock look is maintained.
6- I can still use my phone with the built in system.
Cons:
1- Can not use the steering mounted controls to skip or forward the tracks.
2- Needs charging so the wire looks messy when it is charging, but I will be buying something like : https://amzn.in/d/9qE0b9L to solve the problem.
3- Being basic tab, the speed is SO-SO and not very good, but it is manageable because I don't expect multitasking on it.
4- No Apple Carplay. I would like to ask if there is a way I can use Apple Carplay on android tab?
5- Extra money spent on Bluetooth adapter and magnet mounts.
6- Need to have a data pack of it's own or hotspot
I know there are a list of cons, however, I am still happy with the setup and I would recommend it to whoever is interested.
BikerKeeda is offline   (1) Thanks
Old 28th May 2024, 14:46   #55
dkaile's Avatar
Originally Posted by BikerKeeda View Post
Cons:
Since, from what I infer from your post, your car already has bluetooth and steering controls, then why are you using the tab as a standalone with data pack, when you can just connect it to your main phone via wifi Hotspot (no need for any sim on your tab) and get full functionality, like I have been doing. You will also use up less battery without data and your tab will last a full day without charging. And then you will also get full steering control on android auto, and music and calls streaming through your car's bluetooth to your speakers. Also for apple carplay, I have listed a solution a few posts back and also the same solution is being used by TeamBhp member torqueindia's recent post. Kindly go through them.
Cheers...
Old 17th June 2024, 18:01   #56
Arwin07's Avatar
Thanked: 926 Times
Thanks to the OP, I added Android Auto to my 5 year old car. The setup is perfect. My concern was that in case of an accident, will the tablet withstand 3-5G force or will it become a missile and hit the occupants?
I added two 3M double sided tapes as 3rd layer of protection to withstand load in the structure. I have highlighted the 3M tape as '3'.
Cheers.
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img20240617wa0011.jpg
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img20240617wa0012.jpg
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-img20240617wa0013.jpg
Arwin07 is offline   (1) Thanks
Old 18th June 2024, 09:57   #57
dkaile's Avatar
Thanks and nice setup. For all such incidents as highlighted in your quoted post, kindly do your own due diligence, as any such information provided here is in good faith and all such modifications that you do to your car is at your own risk.
Cheers...
Old 21st October 2024, 16:30   #58
Joe367's Avatar
Thanked: 549 Times
I saw this product recently on Amazon and thought many people who are following this thread would find it useful. I'm not affiliated to this product or Amazon, just wanted to add this as an option for people who don't already have a tablet or spare phone with them.
https://amzn.in/d/3qJNCNh
DIY: Get Android Auto in any Car/Bike for Free (or under 10k)-screenshot_20241021161804.png
Plimpton portable wireless Android auto/Apple carplay screen.
This one is a 7 inch unit. They also have listed a 9 inch unit. It can be purchased for 5841 rupees right now if you have an ICICI or Axis bank credit card. It is much cheaper compared to an android tablet and it doesn't have an inbuilt battery - so you can just leave it in the car even if parked under direct sunlight. From the reviews I've watched on YouTube the device seem to decent and quite responsive compared to Android head units. It even has AUX for audio output and also an FM - transmitter if your car's stock unit doesn't have an AUX port.
Joe367 is offline   (3) Thanks
Old 21st October 2024, 21:02   #59
KAKAN's Avatar
Thanked: 52 Times
Attachment 2671031
What a curious coincidence, haha. I just opened this thread in search of opinions of these devices, since I'm thinking of buying one. My glass isn't UV protected or anything, so the dashboard can get hot during summer heat. So, I ended up between Plimpton and JXL and was wondering which could be a better buy. I'm leaning a bit towards Plimpton since it's just a mounted unit and I can take it out if needed, and would not have to fiddle too much with it. The car is also ancient, so I can't really mount 2DIN displays into it, only single DIN.
KAKAN is offline   (1) Thanks
Old 12th February 2025, 16:53   #60
Thanked: 11 Times
Has anyone used this? Also can we hardwire this screen, as opposed to using 12V socket?
balphanso is offline
